Cyl. #4 no compression, rings or headgasket?
Old Sep 1, 2007 | 02:09 PM
J Rob's Avatar
* B A N N E D *
Default Cyl. #4 no compression, rings or headgasket?
I just did a swap in my civic and turns out cyl 4 is reading 0 - 30 psi and is skipping when it runs. is there a way to tell whether its the headgasket or piston rings without ripping apart the motor? Theres no coolant in the oil and it doesnt seem to be smoking. There was some oil on the spark plug when i took it out, and there was oil on cyl. #3 too but that cyl. had good compression... im hoping its just the headgasket...
Old Sep 1, 2007 | 02:19 PM
89s1's Avatar
Default Re: Cyl. #4 no compression, rings or headgasket? (J Rob)
any smoke out the exhaust? and if so, what colour and smell does it have.
Old Sep 1, 2007 | 05:57 PM
builthatch's Avatar
MiG-21 superfan
leakdown test will tell you where it's compromised.
Old Sep 1, 2007 | 07:47 PM
sublimate's Avatar
Sounds more like a burned valve to me.
But you'll need a leakdown test to know.
Jstew
Apr 22, 2010 04:55 AM
Destructive-
Aug 21, 2009 08:24 PM
RedCd5TX
May 10, 2008 06:14 AM
-HONDA-
12
Dec 19, 2006 10:43 PM
Dodger2940
Aug 18, 2002 01:06 AM
