91 honda accord leaks. Passenger side where the ecu is.
Old 01-26-2004, 10:23 PM
ada105's Avatar
Default 91 honda accord leaks. Passenger side where the ecu is.
Well i have been trying to find where this leak is coming from but no luck. One day i just noticed that the floor by the ecu was wet and I reached my hands in there and all the wire were wet too. I have tried pouring water over the whole car to see where the leak was coming from but still no luck. the sun roof dumps are not clogged.
Are there any comon places where these cars leak? let me know I have to fix this soon because it is still raining down here.
Old 01-26-2004, 11:02 PM
Farts in the shower
The_Todd's Avatar
Default Re: 91 honda accord leaks. Passenger side where the ecu is. (ada105)
I would say check your firewall.....and get some foam sealant there are a lot of factory drilled holes and they should come with plugs, but after time they might work themselves free, at least its a good starting point.
Old 01-27-2004, 08:59 AM
biggs2.3's Avatar
are you running your a/c? if you are it could be that your condensation drain is cloged i don't know exactly where that is but that could be that cause of your drip.
Old 01-27-2004, 09:32 AM
Accord94DX's Avatar
Default Re: 91 honda accord leaks. Passenger side where the ecu is. (biggs2.2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by biggs2.2 &raquo;</TD></TR><TR><TD CLASS="quote">are you running your a/c? if you are it could be that your condensation drain is cloged i don't know exactly where that is but that could be that cause of your drip.</TD></TR></TABLE>
bingo. the drain is clogged, you need to blow some pressurized air up the drain tube located underneath the car a little bit behind your power steering rack. It will be either clear or black rubber, about 1/2"-3/4" big
Old 01-27-2004, 12:29 PM
ada105's Avatar
I don't think it is the ac. I only leaks when it rains.
Old 01-27-2004, 02:01 PM
Accord94DX's Avatar
Default Re: (ada105)
do you use your defroster when it is raining?
Old 01-27-2004, 03:04 PM
Mike813's Avatar
My car leaked because i pulled the hose out and forgot to put it back i nwhile i was wiring my system... check the hose for any damage or could be clogged with leaves.. and if u say it only leaks when it rains, maybe the o ring kinda thing fell off...
Old 01-27-2004, 03:05 PM
iam7head's Avatar
Default Re: (Mike813)
mine did the samething when the tiny coolant house got clogged, it just burst out
rachelle2019
09-13-2017 04:21 PM
JeffyHfx
05-19-2008 07:41 AM
cmb7684
05-01-2008 06:20 AM
2 quik
08-05-2004 05:47 PM
4crx4me
05-26-2003 12:32 PM
Quick Reply: 91 honda accord leaks. Passenger side where the ecu is.
