That is the coolest thing I have every seen! Dang it if I only had the money and the skill to build something like that. I NEVER thought of that.. I had dreamed of doing a NS-X setup in a Crx. but never a S2K setup in a Hatch.... effing awesome
NOOOOOOO That hatch drifting is the sickest thing I've ever seeeen. The swap in that looks so clean too I wonder how long it took them
Thanks guys, yeah it took me a couple of days, no sweat really.
*did a little research on stock EG suspension.
Most people just say they're all the same.
92-95 3DR Civic Si
51601-SR0-A53 SHOCK ABSORBER ASSY., R. FR.
51602-SR0-A53 SHOCK ABSORBER ASSY., L. FR.
52610-SR0-Y21 SHOCK ABSORBER ASSY., RR.
51401-SR0-N02 SPRING, FR. (NHK SPRING)
52441-SR0-N02 SPRING, RR. (NHK SPRING
(unable to order front shocks separately)
52611-SR0-B01 SHOCK ABSORBER UNIT, RR.
92-95 Civic 3DR CX, DX, VX
51601-SR0-A33 SHOCK ABSORBER ASSY., R. FR.
51602-SR0-A33 SHOCK ABSORBER ASSY., L. FR.
51401-SR0-K01 SPRING, FR. (MITSUBISHI)
52441-SR0-N02 SPRING, RR. (NHK SPRING)
So this shows that there is a difference in the front suspension of the Si but the rear suspension is the same between all HB models. I'm guessing slightly stiffer front springs and shocks for the Si.
92-95 3DR Civic Si
Me too. I just have shocks and theyre pretty bouncy but theyre probably blown. Stock suspension is most likely better than what I have I would say.
Anyone here know what could be causing the shaking on my steering wheel? I know my suspension is **** but I would like to know whats old that needs replacement. Its really shaky on bumps and when ripping through gears. Thanks!
Your shaking problem could be unbalanced tires, diff tire pressures, bent rim, CV joints, bent control arm?, or even possibly your blown stock shocks lol
I would guess unbalanced tires or CV joints. Even if the CV boots are not ripped they can still be bad. My car just hammers drivers side axels for some reason, I have one right now that makes god awful noises and the boot is just fine. I get a wobble under acceleration btw untill I replace the axel.
It could even be if you have a rebuilt axel that was not balanced properly.
