Old Feb 24, 2009 | 07:28 AM
  #7576
rclark's Avatar
Originally Posted by outlawracer1
I'm going to check it out today. I hope it isn't anything major. The tire is starting to ware on the inside and I never had that problem before.
toe or caster does that to tires
Old Feb 24, 2009 | 07:43 AM
  #7577
outlawracer1's Avatar
So what do you think I need to replace to get back to where it was?
Old Feb 24, 2009 | 07:46 AM
  #7578
shifts's Avatar
set your toe back to 0 i believe. or atleast the closest to 0.
Old Feb 24, 2009 | 07:50 AM
  #7579
The thing is I have no idea what I'm doing when it comes to that. Like how do I set it back to 0? I know about engines not how to setup suspension. My bad.
Old Feb 24, 2009 | 08:07 AM
  #7580
shifts's Avatar
alignment shops can do it. im in the same boat. i know a lil about suspension but to actually do it is another story.
Old Feb 24, 2009 | 08:21 AM
  #7581
I mean I have an idea of what needs to be done but I don't know if I would mess it up so I will take it to super autobacks later today. I hope they can do it.
Old Feb 24, 2009 | 08:34 AM
  #7582
Mashimaro's Avatar
take it to an alignment shop and get them to set it back up to the way you want it. they will give you a report of a before and after.
check your caster though...i'm kinda worried that you may have bent something in that pothole incident (ie: pushed the wheel back a bit towards the mudflap). if you have a chance, take a good look at your SW388 as well. I had a friend bend one on a pothole before :S
Old Feb 24, 2009 | 08:38 AM
  #7583
rclark's Avatar
it could be as simple as an alignment problem, but im with this guy if it was a big bang you very well could have bent something so have a good damn look under there and at your wheel as well. sw388s are pretty soft wheels (and light, so thats good) but you really gotta be careful.
Old Feb 24, 2009 | 08:47 AM
  #7584
I just checked the wheel. It is fine. As far as the wheel to the mudflap it is the same as the other one. The only difference is the camber is a lot more on the left than on the right.
Old Feb 24, 2009 | 08:54 AM
  #7585
Mashimaro's Avatar
HOLY TIRE CHORDS!! damn dood, i'd stop running that tire if i were you!!!!
do you have any knocking noises when you hit bumps on that side? if it's just camber, there's a possibility of bent arms...
Old Feb 24, 2009 | 08:56 AM
  #7586
Rok_Stok's Avatar
ahhhh SW388.
Expect to see one of these on my rear window in the next month.... and for a good reason.
Old Feb 24, 2009 | 08:59 AM
  #7587
Yeah I get what you mean. The tires were at there point to be replaced anyway. I was driving in the canyon when it happened and I gues that just took it to the limit. After seeing the tire I know I was lucky that I even made it home. I already bought new tires for it but before I install them I want to fix the camber.
Old Feb 24, 2009 | 09:01 AM
  #7588
Rotten Egg's Avatar
dude ur not supposed to run the tires that low on the wire bro....
Old Feb 24, 2009 | 09:11 AM
  #7589
They weren't that low when I started driving. 300 miles of driving after I hit the pot hole. I don"t drive my car like this.
Old Feb 24, 2009 | 09:15 AM
  #7590
Mashimaro's Avatar
good man! glad to see you're ontop of it
i wonder how your toe was to have inner wear like that though...you must've been toe'd out by quite a bit?
Old Feb 24, 2009 | 09:16 AM
  #7591
SHG_Claudio's Avatar
Rok Stok, do you have ABS AND LSD? You have a D16Z6 right? Where did you get an LSD from? Which D series even had LSD? JDM D15B optional?
Old Feb 24, 2009 | 09:31 AM
  #7592
shifts's Avatar
or he is going b?
Old Feb 24, 2009 | 09:39 AM
  #7593
Mashimaro's Avatar
or JDM K-series?! :O
Old Feb 24, 2009 | 09:47 AM
  #7594
Old Feb 24, 2009 | 09:49 AM
  #7595
Thanks for your imput fellas. I just ordered the Skunk2 Pro + Camber kit. I should have it by this Friday. I'll have the tires and the suspension aligned then. I hope they are good enough for track use.
Old Feb 24, 2009 | 09:54 AM
  #7596
shifts's Avatar
adjusting your toe should be all you need for even tire wear.
Old Feb 24, 2009 | 09:56 AM
  #7597
And how do I adjust that?
Old Feb 24, 2009 | 10:06 AM
  #7598
Mashimaro's Avatar
you would want to get an alignment shop for that (just so you know how far your adjusting it cuz you can't really eye-ball it).
it's adjusted with the tie rods.
Old Feb 24, 2009 | 10:10 AM
  #7599
should I try to have it aligned before I put the Skunk2 stuff on it?
Old Feb 24, 2009 | 10:12 AM
  #7600
Mashimaro's Avatar
i would install the Skunk2 camber kit first before doing the alignment...no point paying twice
but before all that, make sure you didn't bend anything when you hit the pothole.
