DA Integra's Only
Old Apr 10, 2007 | 09:55 PM
  #14501
integ3x21's Avatar
Default Re: (emissionsux)
here you an man. ITR sway on a DA
http://g2ic.com/forums/showthread.php?t=124417
Old Apr 10, 2007 | 10:06 PM
  #14502
t . b o z's Avatar
Has anyone heard of any tear out problems with the Progress?
Old Apr 10, 2007 | 10:25 PM
  #14503
DATZ WEAKSAUCE's Avatar
Default Re: (t . b o z)
i had the ST rear sway its still a dinky sway bar but it did make a big differnce compared to the stock one
Old Apr 10, 2007 | 10:46 PM
  #14504
1200 Hobos's Avatar
Default Re: (DATZ WEAKSAUCE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rosetta Stoned &raquo;</TD></TR><TR><TD CLASS="quote">Dee A your car is beyond clean.
I miss my black LS-special</TD></TR></TABLE>
You haven't seen the other side
Dee A Nine: By the way man, did you get a camber kit?
Old Apr 10, 2007 | 11:28 PM
  #14505
DB1_559's Avatar
Default Re: DA Integra's Only (bergenholtzracing)
tradein her
Old Apr 10, 2007 | 11:59 PM
  #14506
ChaseIntegra's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t . b o z &raquo;</TD></TR><TR><TD CLASS="quote">Has anyone heard of any tear out problems with the Progress?</TD></TR></TABLE>
I've been doing a little reading and I can't see why the DA would have any problems with a big sway bar. The bar isn't mounted against the subframe like other cars. There's a bracket that appears to be on the frame rail for support and then of course the rear LCA mount. Maybe these pics will show you the diff in mounting versus say a 92 Civic
Old Apr 11, 2007 | 04:25 AM
  #14507
t . b o z's Avatar
Thats the ST swaybar, right?
The Progress/ITR swaybars mount to our subframe, and then to the LCA. The only fabrication that is required is to drill the subframe for the D-clamps.
Old Apr 11, 2007 | 07:51 AM
  #14508
Brice.Hayden's Avatar
Default Re: (ChaseIntegra)
Tokicos are for ricers
Old Apr 11, 2007 | 08:07 AM
  #14509
Morasso's Avatar
Default Re: (JasperDA9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JasperDA9 &raquo;</TD></TR><TR><TD CLASS="quote">Tokicos are for ricers </TD></TR></TABLE>
I like my Tokicos
They squeek a bit though. Not sure if its my Illuminas or my Eibach pro kit.
Old Apr 11, 2007 | 08:16 AM
  #14510
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t . b o z &raquo;</TD></TR><TR><TD CLASS="quote">Thats the ST swaybar, right?
The Progress/ITR swaybars mount to our subframe, and then to the LCA. The only fabrication that is required is to drill the subframe for the D-clamps. </TD></TR></TABLE>
Yeah you're right, I just called them. I don't freakin care, i'd mount it and let it ride. In fact I think i'm gonna go ahead and do the 24mm
Old Apr 11, 2007 | 08:37 AM
  #14511
sinfulDB1's Avatar
hhahahaha
Old Apr 11, 2007 | 08:58 AM
  #14512
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChaseIntegra &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah you're right, I just called them. I don't freakin care, i'd mount it and let it ride. In fact I think i'm gonna go ahead and do the 24mm </TD></TR></TABLE>
You're gf will appreciate all 24mm of it
love you SRA Shands
Old Apr 11, 2007 | 09:40 AM
  #14513
92LSVTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChaseIntegra &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
is it just me, or does that look like a limo?
Old Apr 11, 2007 | 09:54 AM
  #14514
dohctor_B's Avatar
Default Re: (92LSVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92LSVTEC &raquo;</TD></TR><TR><TD CLASS="quote">is it just me, or does that look like a limo?</TD></TR></TABLE>
it's a "Stretchda", the limo version of the the DA. duh
Old Apr 11, 2007 | 11:59 AM
  #14515
MaltBeer's Avatar
Default Re: (iSRT_Vtec)
haha wtf lol
Old Apr 11, 2007 | 12:40 PM
  #14516
t . b o z's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChaseIntegra &raquo;</TD></TR><TR><TD CLASS="quote">Yeah you're right, I just called them. I don't freakin care, i'd mount it and let it ride. In fact I think i'm gonna go ahead and do the 24mm </TD></TR></TABLE>
hah, Im thinking I could use a really big washer...like the ones that have about the same diameter of a golfball, and weld it to each side of the subframe..that is, of course, if the bolt provided is long enough.
Or I could have our CNC guy at the shop machine me some baller metal plates
The body roll my car exudes is really really starting to grate on my nerves.
Old Apr 11, 2007 | 01:25 PM
  #14517
DA9Rood's Avatar
the rear sway bar is only one worth changing to a 24mm, upgrading the front will cause lots of under steer, if you go with a FULL-RACE 32mm rear sway bar and a upgraded front that is were its worth it. suck cuz the 32mm bar is about $500. wish cusco made a set!!! if you just change the bushings out with a set from energy suspention, u'll feel a difference.
Old Apr 11, 2007 | 04:43 PM
  #14518
t . b o z's Avatar
Default Re: (DA9Rood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA9Rood &raquo;</TD></TR><TR><TD CLASS="quote">the rear sway bar is only one worth changing to a 24mm, upgrading the front will cause lots of under steer</TD></TR></TABLE>
Thats a really uneducated assumption. That would depend on a lot of things actually.
Old Apr 11, 2007 | 05:00 PM
  #14519
SYNSEI's Avatar
Default Re: DA Integra's Only (jdmboi86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmboi86 &raquo;</TD></TR><TR><TD CLASS="quote">Name:  S5030047.jpg
tradein her </TD></TR></TABLE>
Why?
Old Apr 11, 2007 | 05:15 PM
  #14520
adiDAs's Avatar
Thats a really uneducated assumption. That would depend on a lot of things actually.</TD></TR></TABLE>
as long as the rear is bigger than front you shouldn't have too much understeer.
Old Apr 11, 2007 | 06:10 PM
  #14521
Lewy. Dee Ayy's Avatar
Default Re: (adiDAs)
bump for more pic's
Modified by Lewy. Dee Ayy at 8:10 PM 4/11/2007
Old Apr 11, 2007 | 06:40 PM
  #14522
bokals's Avatar
Default Re: (Lewy. Dee Ayy)
Old Apr 11, 2007 | 07:14 PM
  #14523
DB1_559's Avatar
Default Re: DA Integra's Only (SYNSEI)
im tradein her for a db1 though need room for my new daughter
Old Apr 11, 2007 | 07:42 PM
  #14524
itsHumble's Avatar
Old Apr 11, 2007 | 07:45 PM
  #14525
sh!tsWEAK!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmboi86 &raquo;</TD></TR><TR><TD CLASS="quote">im tradein her for a db1 though need room for my new daughter </TD></TR></TABLE>
I've always loved the color!
