DA Integra's Only
Old Feb 8, 2006 | 09:05 PM
  #6326
whoa its len 2's Avatar
Default Re: Re: (SiB16A)
spc makes lca's for DA
http://www.spcperformance.com/....html
Old Feb 8, 2006 | 09:06 PM
  #6327
BoostinEJ1's Avatar
yea i found something on g2ic that said something about the itr lca's. im just gunna go with the dc lca's and hope they work out.
Old Feb 8, 2006 | 09:39 PM
  #6328
qwkteg125's Avatar
Default Re: (simple DB2)
you can use the dc lca's but they will change the geometry of your suspension somewhat. dunno how much difference it will make but you can judge for yourself. here's a pic for reference (courtesy of an old g2ic member):
Old Feb 8, 2006 | 09:45 PM
  #6329
toohott4handlin's Avatar
Default Re: Re: (Cursd1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cursd1 &raquo;</TD></TR><TR><TD CLASS="quote">i almost bought this, you saw it on craigslist right
Yep, that was the day I bought it, it looks alot better now
Old Feb 8, 2006 | 10:25 PM
  #6330
TheHooded_Mike's Avatar
Default Re: Re: (toohott4handlin)
Is there still a place to buy the oem front lip? It is listed on acuraautomotiveparts.org, but I figured they wouldn't make them anymore...?
Old Feb 8, 2006 | 11:21 PM
  #6331
::MUGEN::INTEGRA::RSi's Avatar
Default Re: Re: (TheHooded_Mike)
i got that jdm da rear lca on mines...works great...........at first i thought it was an itr but found out it wasnt......bought a tein setup which was out of an acutal rhd DA and was curious to see the rear suspension with a ball and not a fork..........anywayz
Old Feb 9, 2006 | 04:42 AM
  #6332
Purple-skunk's Avatar
Default Re: Re: (DA-KIN3 aka t3k9)
Yeah, although from a quicm inspection they look identical, they are not.
http://g2ic.com/forums/showthr...pp=20
Check that out
Old Feb 9, 2006 | 12:40 PM
  #6333
Default Re: Re: (Purple-skunk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Purple-skunk &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, although from a quicm inspection they look identical, they are not.
Check that out </TD></TR></TABLE>
good point out.........
Old Feb 9, 2006 | 03:21 PM
  #6334
BoostinEJ1's Avatar
well now im confused. i guess ill have to look into the LCA's otherwise keep my ugly stock ones.
Old Feb 9, 2006 | 04:09 PM
  #6335
BoostinEJ1's Avatar
anyone interested in some koni yellows and neuspeed race springs pm me.
Old Feb 9, 2006 | 06:06 PM
  #6336
Mattb16teg's Avatar
Community Builder
Community Influencer
Ok fellas need some help.
I installed my HIds the other day, they worked fine for about a day, the next night i get in turn them on and the passenger side one works but no drivers side, Pop the hood, and close it, turn them off and back on, then the drivers side works but no passenger side. Well i flick my high beams on and drive.
A few minutes down the road i flick the low beams (Hids) back on and no dice, like nothing at all. Do this once more about 5 minutes later and the drivers side one comes on.
Well i continue to do this the whole drive, and funny thing is, the drivers side one works every so often.
Havnt had time to check the wiring, but what else could it be?
thanks for reading my novel
Old Feb 9, 2006 | 06:14 PM
  #6337
91IntegraX's Avatar
id check the wireing....look for a loose connection or a messed up one then reply back and if it still dont work ...then will try something else
Old Feb 10, 2006 | 09:01 AM
  #6338
hionvtecxda6's Avatar
Default Re: (Mattb16teg)
check the relay. And also try switching the balast, that worked for me one time
Old Feb 10, 2006 | 02:02 PM
  #6339
Mattb16teg's Avatar
Community Builder
Default Re: (hionvtecxda6)
haha switching the ballast really worked huh?
Ill try that, i dont have time to expletive with them until like tuesday or something so ill keep you guys posted. Im pretty sure its just the connection because i just spliced the wires so we shall see. I think this time ill solder them.
Old Feb 10, 2006 | 08:17 PM
  #6340
Anyone have info on getting an OEM lip? Like I said, it's listed on acuraautomotiveparts.org but I dunno if that's just an old part number and they really don't have it or what.
Old Feb 11, 2006 | 10:24 AM
  #6341
BoostinEJ1's Avatar
more bay pictures, i wanna see how you guys empty them out cause i personally hate mine.
Old Feb 11, 2006 | 11:20 AM
  #6342
JDMorgan's Avatar
Default Re: (ultra tegboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by simple DB2 &raquo;</TD></TR><TR><TD CLASS="quote">now i gotta find a place with DC2 SRR control arms in stock lol. thanks again guys</TD></TR></TABLE>
srr only sells non-itr lca's last i checked. if you want itr lca's you have to buy function 7 lca's.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deano_D &raquo;</TD></TR><TR><TD CLASS="quote">They will go on but I thought they where alittle longer?</TD></TR></TABLE>
spc are SHORTER, not worth anyone's time. to use them you have to buy upper control arms and toe arms.
srr and function 7 are both oem length and awsome control arms. both fit right on a da perfect with no mods.
also to use an srs steering wheel you need the srs spacer, otherwise it should bolt right on. from like 50 pages back lol.
Old Feb 11, 2006 | 11:23 AM
  #6343
BoostinEJ1's Avatar
i bought omni ones, same difference.
Old Feb 11, 2006 | 11:26 AM
  #6344
JDMorgan's Avatar
cool now buy my a/c and abs deletes.
Old Feb 11, 2006 | 11:33 AM
  #6345
Default Re: (KraZEtEggIE)
Also, function 7 is overkill for the street and is expensive as hell!! But, I thge product quality is amazing. In the function 7 case, you DO get what you pay for
P.S,. I think the new function (rear) 7 LCA has sway bar adjusting holes. Pretty neat stuff
Old Feb 11, 2006 | 07:36 PM
  #6346
88crxsir's Avatar
Default Re: (Purple-skunk)
heres a few pics of mine
Old Feb 11, 2006 | 08:31 PM
  #6347
ATS*JONES's Avatar
Default Re: Re: (DATZ WEAKSAUCE)
SRR LCA's do fit perfect
i was running it for a couple months,
until i came up on some XSI Tokico 5-way adjustables then i had to down grade to ITR LCA's
the only thing whack about it is, people never saw the SRR LCA's because of my HKS sport exhaust... LOL
Old Feb 11, 2006 | 08:44 PM
  #6348
4NLINE UNLIMITED's Avatar
Default Re: Re: (ATS*JONES)
Shes FS... Please BUY... Reasonable Offer Considered
http://www.hondamarketplace.co...67180
Old Feb 11, 2006 | 08:52 PM
  #6349
91IntegraX's Avatar
ok so today i swap out the tan underdash centerconsole plastic and the door panels for black ones because im starting to do a interior conversion fomr tan to black so then i get into my car to leave and go somewhere and i my hatch light, door light, clock, radio are flickering on and off and my interior light dont even work and the radio wont play ...checked all the fuses and they were good, i didnt even mess with the electrical at all because i dont have PW or PL ....what could be wrong ?????pleeeeze any help would be amazing
Old Feb 12, 2006 | 12:06 AM
  #6350
former DA owner's Avatar
Default Re: (88crxsir)
car looks clean... what kind of rear lip is this???
