DA Integra's Only
Old Jul 20, 2009 | 07:34 AM
  #31326
Mattb16teg's Avatar
Community Builder
Community Influencer
Default Re: DA Integra's Only
cool, very different!
Old Jul 20, 2009 | 07:35 AM
  #31327
jhammond_82's Avatar
Reject Papi
that actually looks kinda neat!
Old Jul 20, 2009 | 08:00 AM
  #31328
HondaTom87's Avatar
thanks... Im thinkin about doing the back seat armrests and the shift boot but I dont want to go to crazy with it... gimme some thoughts and opinions on wether or no I should do that...
Old Jul 20, 2009 | 08:15 AM
  #31329
OldSkoolDa91's Avatar
Originally Posted by uses0ap
dont hate on the car....its a work in progresssssssssss
car looks pretty clean. just needs some wheels and you're good to go
Old Jul 20, 2009 | 08:16 AM
  #31330
vanga's Avatar
Old Jul 20, 2009 | 08:22 AM
  #31331
HondaTom87's Avatar
^^^ nice
Old Jul 20, 2009 | 05:46 PM
  #31332
what gsr's Avatar
this is a few weeks old i haven't drove it in forever.. i miss it/
Old Jul 20, 2009 | 05:51 PM
  #31333
Novtec4u's Avatar
h-series huh?
Old Jul 20, 2009 | 06:27 PM
  #31334
Brice.Hayden's Avatar
how do you figure? looks like a B from where i am sitting
Old Jul 20, 2009 | 06:43 PM
  #31335
Novtec4u's Avatar
Sorry I just galanced lol. I thought it was a blue top prelude h series motor
Old Jul 20, 2009 | 07:07 PM
  #31336
4DRmafia's Avatar
Where is the jumper plug for the CEL on a obd1 92 teg. My car threw a CEL and I shut off and started it back up, no CEL until about every 2 miles it throws it again. So I need to check.
Old Jul 20, 2009 | 07:21 PM
  #31337
Novtec4u's Avatar
passenger side under the kick panel is a two wire plug
Old Jul 20, 2009 | 07:43 PM
  #31338
4DRmafia's Avatar
Okay, what is code 43? I took off my exhaust manifold and unplugged the 02 to replace the oil pan gasket and reinstall everything and even plugged back the o2 sensor in too. So, only thing electrical I messed with was unplugging the o2.
Old Jul 20, 2009 | 08:44 PM
  #31339
Reject Papi
code 43 is fuel delivery system
Old Jul 20, 2009 | 09:09 PM
  #31340
4DRmafia's Avatar
Fuel delivery system, does that include a bad o2 as well. I don't know when the last time the fuel filter been changed though.
Old Jul 20, 2009 | 09:50 PM
  #31341
Reject Papi
code 1 and 2 are o2 sensor cel's. here's a list of codes for future reference. https://honda-tech.com/forums/acura-integra-6/ecu-abs-codes-here-978933/
Old Jul 20, 2009 | 09:58 PM
  #31342
4DRmafia's Avatar
So, it's not my o2. Umm, the car did bog a little and then stop bogging after the light came on. That sounded like a o2 to me from previous experience. Only fuel delivery system I could think of is the fuel filter, fuel pressure regular, and the injectors but I didn't mess with none of those when I was changing my oil pan gasket. To add in, I've been using Shell v-power 93 octane gas ever since I got the car.
Old Jul 20, 2009 | 10:08 PM
  #31343
cmyrex's Avatar
my baby its being worked on as i post each day something different it has come along way since i have gotten it sorry for the **** pictures
Old Jul 20, 2009 | 10:20 PM
  #31344
da9leo's Avatar
I <3 DA's
needs to be lower
Old Jul 20, 2009 | 10:31 PM
  #31345
4DRmafia's Avatar
I'm thinking my code 43 came on because of my bad cat. it does have 260k miles on that cat though.
Old Jul 20, 2009 | 10:52 PM
  #31346
Mattyg2's Avatar
I miss driving my DA....*sigh*
Old Jul 20, 2009 | 11:25 PM
  #31347
DA_DRE's Avatar
From: NOT EXAGGERATING but I COULD NEVER LOVE A HUMAN BABY AS MUCH AS I LOVE DAs
I do not thinks it is because of the cat converter. Our o2 sensors are before the cat. I do not have a cat on my car and i dont get any codes.
Old Jul 20, 2009 | 11:29 PM
  #31348
4DRmafia's Avatar
You are right, but I've read some more about this problem and where the o2 reads the mixture and the cat could be clogged and bounce the reading back to the o2, causing it to throw a code 43. Again, it's a 260k miles cat with a 80k 2nd engine.
I'll check the cat tomorrow to see if I can see through it or not. If I could see through it, then it's my faulty o2. My fuel filter looks fairly new as well.
Old Jul 20, 2009 | 11:33 PM
  #31349
DA_DRE's Avatar
^^ unbolt the exhaust after the header therefore it will run unbolt and should flow and no exhaust will be "bounded back" from the cat no being there than drive it for a while since you said it turns on every 2 miles. warning **** will be loud!
Old Jul 20, 2009 | 11:36 PM
  #31350
DA_DRE's Avatar
and inspect the cat when it is unbolted
