DA Integra's Only
Old Feb 8, 2006 | 01:55 PM
  #6301
LSDC-4's Avatar
Default Re: (digitalHorizon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by digitalHorizon &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>thas nice!
  #6302
2006CiViCsI's Avatar
Default Re: (Purple-skunk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Purple-skunk &raquo;</TD></TR><TR><TD CLASS="quote">Whats the story??</TD></TR></TABLE>
I was coming around a bend down some foresty road on my way home right after work. It was freezing out(road was dry, but you could see glare after where I spun out), and as I went into the corner(I wasnt going slow either, but Ive been driving down that road since like 2000) the back of the car started going out, which has happened to me in before, so I thought I was going to come to a sliding stop, but instead, in a split second, the car completely spun, and I was backwards, heading off the road. Right on that bend, there are boulders about roughly 4ft by 4ft, bout 3-4 feet high, probably bigger, but the side you see, that side of the car slammed into one and then into a second, which lifted the car in the air, reason why damage is direct and not on the bumper, which did get scraped, but just bent since its plastic... My seat was closer to the steering wheel once the car came to a stop, and my legs were right up on the steering wheel, so I consider myself lucky to walk out with just neck and back pains... Just got the car towed after and that was the end of everything....
Old Feb 8, 2006 | 02:13 PM
  #6303
BoostinEJ1's Avatar
quick ???, anyone know if there are aftermarket LCA's made for are cars???
Old Feb 8, 2006 | 02:15 PM
  #6304
Boriqua0555's Avatar
Default Re: (simple DB2)
i got omni control arms off a DC on my 91 integra and they fit perfect
Old Feb 8, 2006 | 02:17 PM
  #6305
ChaseIntegra's Avatar
Megan racing is the only ones I can think of.
Old Feb 8, 2006 | 02:30 PM
  #6306
Purple-skunk's Avatar
Default Re: (ChaseIntegra)
DC arms should work just fine. The rear LCA is the same for the DC chassis as it is for the DA. There may be only slight variations for ABS location, but that should be about it. Its should bolt right up.
  #6307
shiux's Avatar
thats pretty intense! i did something like that in my 94 Golf, im much more careful with my DA now though. good to hear youre alright.
Old Feb 8, 2006 | 02:34 PM
  #6308
BoostinEJ1's Avatar
so if i buy srr LCA's for a 94-01 integra they will bolt right up? awesome thanks guys
Old Feb 8, 2006 | 02:46 PM
  #6309
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by simple DB2 &raquo;</TD></TR><TR><TD CLASS="quote">so if i buy srr LCA's for a 94-01 integra they will bolt right up? awesome thanks guys</TD></TR></TABLE>
They should, I had the Megan racing on my DA before it got crashed, check em out in the far left....
I miss my DA...
Old Feb 8, 2006 | 02:47 PM
  #6310
integraXTC's Avatar
Default Re: Re: (toohott4handlin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toohott4handlin &raquo;</TD></TR><TR><TD CLASS="quote">
For reference, heres my old gsr, circa last year
What happened to this one? I miss my DA.
Old Feb 8, 2006 | 02:48 PM
  #6311
digitalHorizon's Avatar
Default Re: Re: (integraXTC)
it ended up in so cal, we saw it at a meet like a week ago.
Old Feb 8, 2006 | 02:49 PM
  #6312
BoostinEJ1's Avatar
now i gotta find a place with DC2 SRR control arms in stock lol. thanks again guys
Old Feb 8, 2006 | 03:02 PM
  #6313
jdmintegraxsi's Avatar
Default Re: Re: (jdmkrazie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmkrazie &raquo;</TD></TR><TR><TD CLASS="quote">are those 16's?</TD></TR></TABLE>
Yep those are 16's
Old Feb 8, 2006 | 03:42 PM
  #6314
Axel Foley's Avatar
i almost bought this, you saw it on craigslist right
Old Feb 8, 2006 | 03:49 PM
  #6315
Axel Foley's Avatar
Default Re: Re: (jdmintegraxsi)
[QUOTE=jdmintegraxsi]New pics
nice car, sweet pieces
Old Feb 8, 2006 | 05:56 PM
  #6316
Default Re: Re: (Cursd1)
  #6317
Deano_D aka
Default Re: Re: (ChaseIntegra)
They will go on but I thought they where alittle longer?
Old Feb 8, 2006 | 06:19 PM
  #6318
91IntegraX's Avatar
nice sckirt...and what kinda rims r those
Old Feb 8, 2006 | 06:31 PM
  #6319
Default Re: (91IntegraX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91IntegraX &raquo;</TD></TR><TR><TD CLASS="quote">nice sckirt...and what kinda rims r those </TD></TR></TABLE>
Thanks alot. They are rota c10's
Old Feb 8, 2006 | 07:39 PM
  #6320
BoostinEJ1's Avatar
Default Re: Re: (Deano_D)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deano_D &raquo;</TD></TR><TR><TD CLASS="quote">They will go on but I thought they where alittle longer?</TD></TR></TABLE>
so then they don't fit perfect...
Old Feb 8, 2006 | 07:40 PM
  #6321
Deano_D aka
Default Re: Re: (simple DB2)
so then they don't fit perfect...</TD></TR></TABLE>
I thought I read that on http://www.g2ic.com go there and search.
Old Feb 8, 2006 | 08:31 PM
  #6322
DATZ WEAKSAUCE's Avatar
srr lca's do fit perfect.. my friend is running itr lcas on his
Old Feb 8, 2006 | 08:38 PM
  #6323
Deano_D aka
Default Re: Re: (DATZ WEAKSAUCE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DATZ WEAKSAUCE &raquo;</TD></TR><TR><TD CLASS="quote">srr lca's do fit perfect.. my friend is running itr lcas on his</TD></TR></TABLE>
Awesome, any advantages?
Old Feb 8, 2006 | 08:51 PM
  #6324
ITR and regular DA/DC/EG are different rear LCAs design
ITR LCAs are boxed typed (as in, the shock/strut mounts inside the LCA (hence the box designation) as opposed to being mounted outside the LCAs)
The only reason people run it is to have wider options on coilovers to use (like the Zeal B6, KW variant, etc.) But, if your using the car mainly for street duty, its really not necessary
Old Feb 8, 2006 | 08:53 PM
  #6325
SiB16A's Avatar
Default Re: Re: (Purple-skunk)
