DA Integra's Only
Old May 28, 2012 | 09:30 PM
  #52126
Bond's Avatar
Default Re: DA Integra's Only
Originally Posted by Mattb16teg
Yea I wouldn't do that kind of ghetto stuff. I went to Home Depot today and all the fixtures I liked had normal plugs, nothing to hardwire. Guess I could cut it and wire it that way? I pulled the current fixture out and there is only a ground(black) and red(power) wire attached to it right now.
Yup pretty standard stuff. Often the bare green wire is grounded to the outlet box if I can remember correctly. Not 100% sure on if thats by code. Thats odd that there is no proper light fixtures available. That being said the gauge wire off the ballasts is fairly small. I'd imagine cutting the cord and hard wiring would be pretty close to normal.
Old May 29, 2012 | 06:35 AM
  #52127
Mattb16teg's Avatar
Community Builder
Community Influencer
So got the garage somewhat organized for now. Bought some cheap shelving and hooks to get stuff situated for the time being.
This is how my weekend went, what about you guys?
Old May 29, 2012 | 12:09 PM
  #52128
hb420's Avatar
This what I did
Old May 29, 2012 | 12:12 PM
  #52129
g2_teg_'s Avatar
black and red are hot. black is not ground. bare or green is ground. white is neutral.
Old May 30, 2012 | 05:00 AM
  #52130
tougetuned_ef's Avatar
everyday i get closer to being reunited with my DA! one month to go before i am ripping on her once again.
Old May 30, 2012 | 06:20 PM
  #52131
slammedg2's Avatar
my firewall ready to get welded in
Old May 30, 2012 | 11:35 PM
  #52132
Bond's Avatar
Post some installed pics when it's welded in
Old May 31, 2012 | 01:45 AM
  #52133
shifty92's Avatar
agreed
Old May 31, 2012 | 05:05 PM
  #52134
g2_teg_'s Avatar
dont be afraid to post pics next year if the welds crack.
a lot of people that shave the engine bay just stop postings close up pics when the welds crack. Hopefully they don't crack though.
Old May 31, 2012 | 05:06 PM
  #52135
TurdBlown Teg's Avatar
alright guys well i know this is a long shot but any one parting out a DA? i need the drivers side quarter panel behind the door all i really need is from the door crease to the wheel well and only the body line part on the bottom i will include a pic..... i know i know long shot but why not ask and see
Uploaded with ImageShack.us
Old May 31, 2012 | 05:26 PM
  #52136
The G2 Racer's Avatar
Actually, green/bare copper is a bond to tie all the boxes together (it does go to ground though). Be sure to connect it, with out it should the plug or switch touch the side of the box it won't trip the breaker and can start a fire. Everything has to be bonded by code(CEC or NEC), in a light fixture, it will be up in the octagon box attached to a screw.
Plugs are labelled on the back so you know what goes where, make sure you've got the proper amperage plug for the wiring that is there (likely 14AWG or 15A).
Old May 31, 2012 | 05:56 PM
  #52137
it would be much safer and easier to do all the way back. you will have a huge weld and it will be next to impossible to make it look right. trust me my last car was like that when i bought it and i got another car because of it.
Old Jun 1, 2012 | 08:08 AM
  #52138
meugenkid95's Avatar
yea its a bolt in cage idk wat brand or anythong but it goes around the back seat its sick
Old Jun 2, 2012 | 11:10 PM
  #52139
*da6*dohc VTEC's Avatar
has anyone got eg civic lowering spring and shocks in there da integra.
Old Jun 3, 2012 | 06:53 AM
  #52140
OldSkoolDa91's Avatar
i have tein ss coil overs on mine that are for an eg. worked perfectly fine. only thing you gotta change is you have to use the eg front forks with them as well.
Old Jun 3, 2012 | 11:42 AM
  #52141
Colin's Avatar
It's not the welds that crack when people shave/tuck. Welding has been the solution to cracking. The problem with cracking came up a lot in the beginning of the shaving/tucking fad when people didn't know what they were doing and were simply using a lot of body filler. It can be used for small things but the whole engine bay is structural and thus takes some abuse when driven, you can even see the front frame rails flex when you jack up your car. All this flexing causes the body filler to crack. The preferred method now is to fill all seams/holes with metal or just weld, grind it smooth, and then lay body filler over the top to fill in the small imperfections before paint. Same way you'd normally fix body panels since whenever you lay on bondo too thick you'll run into cracking eventually.
Old Jun 3, 2012 | 12:02 PM
  #52142
i use ek shocks. just had to trim 1/4" off rear shock bushings. fronts are a little tall so i cant go too low. unless i use extended top hats
Old Jun 3, 2012 | 03:05 PM
  #52143
be18see1's Avatar
I am. PM me.
Old Jun 3, 2012 | 06:15 PM
  #52144
Mattb16teg's Avatar
Community Builder
Old Jun 3, 2012 | 09:05 PM
  #52145
shifty92's Avatar
^^ noice
Old Jun 3, 2012 | 09:22 PM
  #52146
Bond's Avatar
Yeah buddy! Looks dope. Excited for you and your new home. DA looks so happy in there
Old Jun 4, 2012 | 12:30 AM
  #52147
thinking of doing a dc1 front end swap on my da integra
wat u think yes or no?
Old Jun 4, 2012 | 03:39 AM
  #52148
thedb63's Avatar
no! dont.
Old Jun 4, 2012 | 04:12 AM
  #52149
Mattb16teg's Avatar
Community Builder
Thanks fellas! I was excited it didn't scrape at all getting up there! Still a pretty steep climb but got it!
Old Jun 4, 2012 | 07:56 AM
  #52150
hb420's Avatar
Congrats Matt, teg is happy it has a garage now instead of a parking lot.
