DA Integra's Only
Old Jul 20, 2011 | 10:43 AM
  #48351
djkobe's Avatar
Default Re: DA Integra's Only
i got a question for all you DA lovers, what kinda oil pan gasket do you use? im on my 3rd properly tourqed felpro POS and im sick of having them split on me and leave all my nice fresh oil all over the ground. and before anyone asks if the pan or block is making them split the answer is no. Ive already tripple checked to make sure there were no rough spots that would cause problems. i will greatly appreciate any help that you shed on my little problem before it destroys my motor.
Old Jul 20, 2011 | 10:52 AM
  #48352
Mattb16teg's Avatar
Community Builder
Community Influencer
OEM all the way.
If your gasket keeps splitting then you are over tightening it for sure.
I forget the tq specs for the pan but look them up and use a tq wrench next time.
Old Jul 20, 2011 | 10:56 AM
  #48353
DumaDA's Avatar
the tq specs are HELLA low, you can barely hear the click of the wrench when tightening it, i think it was like 9ftlbs
Old Jul 20, 2011 | 11:11 AM
  #48354
djkobe's Avatar
Originally Posted by Mattb16teg
OEM all the way.
thats what i thought, and as stated above its 9ft/lbs but my snapon tq wrench only goes to 25 so i just snug up the pan just enough where it barely puts pressure onto the gasket, i was doing my balljoints so i climbed under to check all the bolts on the pan since it was a few weeks since i installed it and they were all finger loose so i snugged them up again and the leaking persisted.
would it be a good idea to use some honda bond on the pan and gasket before installing as a extra security?
Old Jul 20, 2011 | 11:22 AM
  #48355
Mattb16teg's Avatar
Community Builder
I do not use Honda Bond here as the OEM gasket is enough.
Old Jul 20, 2011 | 12:23 PM
  #48356
91b18a1ls's Avatar
Random shot of her ***
Old Jul 20, 2011 | 04:28 PM
  #48357
djkobe's Avatar
i wouldnt on the oem either, but as of now i dont have the money or time to get a oem one so im stuck with another felpro since its under warrenty so im kinda stuck tell i can get up some cash
Old Jul 20, 2011 | 04:42 PM
  #48358
DumaDA's Avatar
there has to be something wrong with the way you're installing it if you keep having the problem over and over and say theres nothing wrong with the block or oil pan because i know plenty of people who use felpro with no problems
Old Jul 20, 2011 | 04:46 PM
  #48359
tougetuned_ef's Avatar
mmmmm nice ***. love how clean this car is.
Old Jul 20, 2011 | 04:50 PM
  #48360
its like 15$ from hondapartsunlimited.com . just bite the bullet and buy one. i did mine without a tourqe wrench and it has been good for awhile. ive heard of people using silicone on the gasket. no idea if its any silicone or some kind of heat proof stuff.
Old Jul 20, 2011 | 07:48 PM
  #48361
ELIDA9's Avatar
Originally Posted by Mattyg2
The driver side mount
50820-SK7-A01 RUBBER ASSY., ENGINE SIDE MOUNTING (HYD) $127.12
I ment this one...thanks for the part number. After looking for it I just ordered a brand new full set. they should get here next Tue.
Old Jul 20, 2011 | 08:10 PM
  #48362
djkobe's Avatar
thats what the people at autozone are telling me, but i have been working on cars for a long time and am in school for my ase certs so im fairly confident that i can install a pan gasket haha. I pulled the pan to take the gasket back and i went over every square inch of the pan and the block and their both fine. over tourqing could be a possiblity but 9ftlbs isnt **** so i just snugged all the bolts up in the oem manuals pattern so its highly unlikely. only thing i could think may be playing a factor is either i got 2 bad gaskets or possibly my headers causing them to split. either way i tossed a new one on only time will tell.
thanks for the help guys!
Old Jul 20, 2011 | 08:42 PM
  #48363
91b18a1ls's Avatar
Lol thanks.
I went out today and finally got some new shots. I hadn't taken any shots since I cleaned up the engine bay and got the rear flaps.
Old Jul 21, 2011 | 08:01 AM
  #48364
kiDchaos's Avatar
Originally Posted by EFcivicJDM
can we get more shots of this? Preferrably a few more of the engine bay?
Old Jul 21, 2011 | 12:56 PM
  #48365
I Am The Ghost's Avatar
http://www.youtube.com/watch?v=lXk974_-XgE
another update to my car...it is going up for sale so check it out if interested
Old Jul 21, 2011 | 08:40 PM
  #48366
91_LS's Avatar
Old Jul 21, 2011 | 09:53 PM
  #48367
djkobe's Avatar
has anyone had a problem with all 3 of their tail lights all of a sudden having a constant power? i havent had any problems with any of my lights since i bought the car half a year ago, the weird part is all i did to it was solder a new o2 sensor, put on new pads and a new pan gasket. they were working just fine when i came inside from taking a test drive after the installing the parts, but when i went outside to listen to music and smoke a cig the battery was completely dead. i jumpstarted it and all 3 of my tails were stuck on like the brake was pressed in.
Wiring is not my strongest skill so any one have any input that may help? i have to fix this before 9am tomorrow or im screwed for work.
Old Jul 21, 2011 | 09:55 PM
  #48368
91_LS's Avatar
Sounds like the switch on the brake peddle is stuck.
Old Jul 21, 2011 | 10:14 PM
  #48369
Keving1991's Avatar
Originally Posted by 91_LS
How did you fit that air filter on your gsr mini? did you have relocate stuff? I tried for so long I ended up making a custom one haha
Old Jul 21, 2011 | 10:19 PM
  #48370
91_LS's Avatar
Well,its the stock tube with the filter added. I tried finding an AEM one that would fit but failed,so i just modded mine. I just had to move the battery over a little,that's all.
Old Jul 21, 2011 | 10:30 PM
  #48371
da9leo's Avatar
I <3 DA's
Actually it might be the rubber stopper that hits the switch, check the floor for pieces of it
Old Jul 21, 2011 | 10:34 PM
  #48372
91_LS's Avatar
Agreed^^ if not broken,the switch is bad.
Old Jul 21, 2011 | 11:47 PM
  #48373
djkobe's Avatar
that was close to the problem. it turned out that the stopper was replaced by a piece of plastic and electrical tape, which came undone. so i guess ill try to find a place to order a new one to properly fix this problem.. but for now some new tape will get me to and from work haha
thanks for the help guys, with out it i would have been ohming wires all day tomorrow
Old Jul 21, 2011 | 11:50 PM
  #48374
91b18a1ls's Avatar
Put these two photos of my engine bay side by side just to see how far it's come since I bought it
Old Jul 21, 2011 | 11:58 PM
  #48375
djkobe's Avatar
^^^^ looks much cleaner man! i cant wait to get my bay lookin that clean
