DA Integra's Only
Old Sep 8, 2005 | 08:42 PM
  #3651
projectTeG's Avatar
from the pics ive seen of a non-abs car is you have to relocate the battery.
Old Sep 8, 2005 | 08:53 PM
  #3652
.Jay's Avatar
Default Re: (projectTeG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">from the pics ive seen of a non-abs car is you have to relocate the battery.</TD></TR></TABLE>
Sorry for being so lazy, but is there a write-up to relocate the battery? Maybe one on G2IC?
I am going to sell my gay bright blue intake to a friend, and I want something a little less flashy. I'll use his stock pipe w/ K&N filter until I can figure something out.
Old Sep 9, 2005 | 12:18 AM
  #3653
2GEN DA's Avatar
Some clean DA's I will post mine soon
Old Sep 9, 2005 | 01:06 AM
  #3654
GrayT's Avatar
Default Re: (.Jay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Jay &raquo;</TD></TR><TR><TD CLASS="quote">Sorry for being so lazy, but is there a write-up to relocate the battery? Maybe one on G2IC?
I am going to sell my gay bright blue intake to a friend, and I want something a little less flashy. I'll use his stock pipe w/ K&N filter until I can figure something out.</TD></TR></TABLE>
I could show you how to do it a little easier in person, Jay. Basically what *I* would do is use a 2pt block distributor (an audio accessory, 1 end has the power from the battery, while the other ends go to your amps. Utilizes only one power source, makes things easier) and have the power cable from your fuse box go into 1pt, and have the power cable from the starter go into the other pt.
Then at the end of the block distributor, run 4G wire of any kind to the hatch. This 4G wire will hook up to your positive battery terminal. To ground the battery you should use the same ground we're using for your amp, and then we can find another one. I always like to have 2 grounds, never hurts.
You'll have to take out your 8G power wire that supplies your amp, cut it accordingly and then hook it back up to your positive battery terminal. Then, to be on the safe side since you have a liquid battery (invest into a dry cell, Optima!) and because I wouldn't let you do it any other way... you'll need a battery box. You can get a Jegs battery box for around $30 shipped, drill some holes on the side of your trunk floor, then mount the battery box. Done.
It's much easier to explain in person, would probably take about 2 minutes. We should do ours at the same time, I have to move mine to make room for the big T.
Old Sep 9, 2005 | 01:37 AM
  #3655
JDM_sedan's Avatar
Default Re: (Js2GEN)
i'll be getting a project DA soon
Old Sep 9, 2005 | 06:15 AM
  #3656
Yosshaa's Avatar
Default Re: (DATZ WEAKSAUCE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DATZ WEAKSAUCE &raquo;</TD></TR><TR><TD CLASS="quote">pic of my car at the sonics meet brought to u by http://www.d2motorsports.com
HOW DID U MOUNT THAT TOW HOOK???
Old Sep 9, 2005 | 06:25 AM
  #3657
J's 94 Accord's Avatar
Default Re: (ambition)
Old Sep 9, 2005 | 06:33 AM
  #3658
projectTeG's Avatar
^ the white Da is the SeX!
Old Sep 9, 2005 | 06:44 AM
  #3659
former DA owner's Avatar
Default Re: (J's 94 Accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J’s 94 Accord &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
more pics of the white DA please!!!
Old Sep 9, 2005 | 06:46 AM
  #3660
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ambition &raquo;</TD></TR><TR><TD CLASS="quote">
HOW DID U MOUNT THAT TOW HOOK???</TD></TR></TABLE>
very carefully?
Old Sep 9, 2005 | 08:42 AM
  #3661
lhd dc2's Avatar
Default Re: (temp)
Old Sep 9, 2005 | 10:55 AM
  #3662
DATZ WEAKSAUCE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ambition &raquo;</TD></TR><TR><TD CLASS="quote">HOW DID U MOUNT THAT TOW HOOK???</TD></TR></TABLE>
drilled holes on the bumper support
Old Sep 9, 2005 | 11:13 AM
  #3663
DA_GURL's Avatar
<FONT COLOR="green"><FONT SIZE="6"> Check this out ... </FONT></FONT>
https://honda-tech.com/zerothread?id=1360133
Old Sep 9, 2005 | 07:38 PM
  #3664
.Jay's Avatar
Default Re: (GrayT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GrayT &raquo;</TD></TR><TR><TD CLASS="quote">
It's much easier to explain in person, would probably take about 2 minutes. We should do ours at the same time, I have to move mine to make room for the big T. </TD></TR></TABLE>
Ok, sounds good. How about after my car is back on the streets?
Old Sep 10, 2005 | 09:42 AM
  #3665
GrayT's Avatar
Default Re: (.Jay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Jay &raquo;</TD></TR><TR><TD CLASS="quote">Ok, sounds good. How about after my car is back on the streets? </TD></TR></TABLE>
Just get your T61 on the manifold and we'll hook up the oil lines.
It's gonna be sweet.
Old Sep 12, 2005 | 07:53 PM
  #3666
92LSVTEC's Avatar
Default Re: (GrayT)
Old Sep 14, 2005 | 09:10 AM
  #3667
1 point 6's Avatar
Down Since Day 1
Community Builder
Community Influencer
that is fuxin clean!
Old Sep 14, 2005 | 09:23 AM
  #3668
t o m's Avatar
Default Re: (FF-Greg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FF-Greg &raquo;</TD></TR><TR><TD CLASS="quote"> another pic of my da</TD></TR></TABLE>
GAME OVER
Old Sep 14, 2005 | 12:50 PM
  #3669
JOSEPH's Avatar
Default Re: (integra type s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra type s &raquo;</TD></TR><TR><TD CLASS="quote">
GAME OVER </TD></TR></TABLE>
dont think so. its nice but game is not over
Old Sep 14, 2005 | 01:02 PM
  #3670
t o m's Avatar
Default Re: (JOSEPH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JOSEPH &raquo;</TD></TR><TR><TD CLASS="quote">
dont think so. its nice but game is not over</TD></TR></TABLE>
for me it is. GAME OVER
Old Sep 14, 2005 | 01:03 PM
  #3671
130R's Avatar
me too
where's the restart button?
  #3672
HipHop Head's Avatar
LOL
Old Sep 14, 2005 | 01:06 PM
  #3673
t o m's Avatar
Default Re: (carbing'ed)
its in the front. it says Reset.
Old Sep 14, 2005 | 01:18 PM
  #3674
t o m's Avatar
this one takes the cake too
showoff classic 2004
Old Sep 14, 2005 | 01:19 PM
  #3675
Awww man .. I love that one so much .. God i want those wheels
