DA Integra's Only
Old Oct 13, 2008 | 04:30 PM
  #27351
Mattb16teg's Avatar
Community Builder
Community Influencer
Default Re: (TallKyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TallKyle &raquo;</TD></TR><TR><TD CLASS="quote">my buddy made 250 on 93 with a b18 with a stock bottom end.
uhh, were talking about all motor, your referring to a turbo/Nitrous car right?
Old Oct 13, 2008 | 04:32 PM
  #27352
TallKyle's Avatar
Default Re: (Mattb16teg)
nope all motor. 242 whp.
he holds the highest stock bottom end whp right now.
Old Oct 13, 2008 | 04:58 PM
  #27353
Mattb16teg's Avatar
Community Builder
Link?
I find it very hard to believe someone made that much power on a stock ls bottom end.
Stock = STOCK RODS, STOCK PISTONS and STOCK BORE.
By stock do you mean just stock bore?
Old Oct 13, 2008 | 05:02 PM
  #27354
TallKyle's Avatar
it was a gsr.
ill see if i can find the link. i know its somewhere.
Old Oct 13, 2008 | 05:04 PM
  #27355
TallKyle's Avatar
**** i was off on the numbers. but still damn good
http://www.hondamarketplace.co...91641
Old Oct 13, 2008 | 05:08 PM
  #27356
J's 94 Accord's Avatar
Cant close case.....
Old Oct 13, 2008 | 05:13 PM
  #27357
Mattb16teg's Avatar
Community Builder
Default Re: (J's 94 Accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TallKyle &raquo;</TD></TR><TR><TD CLASS="quote">**** i was off on the numbers. but still damn good
http://www.hondamarketplace.co...91641</TD></TR></TABLE>
Yea, nice numbers for the build, but not stock block.
Old Oct 13, 2008 | 05:15 PM
  #27358
TallKyle's Avatar
oem is stock to me.
i guess i have a different view on things. lol
Old Oct 13, 2008 | 05:23 PM
  #27359
Mattb16teg's Avatar
Community Builder
LoL true.
When you said Stock I thought bone stock untouched Block, nearly shat myself.
Old Oct 13, 2008 | 05:46 PM
  #27360
Brice.Hayden's Avatar
you need an 84-85mm to break 220+ on an N/A setup and some pretty sweet headwork.
Old Oct 13, 2008 | 06:33 PM
  #27361
hondamn1320's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J’s 94 Accord &raquo;</TD></TR><TR><TD CLASS="quote">Cant close case.....
[img]https://img.photobucket.com/albums/v248/BlackG2Teg/Transmission/DSC06652.jpg[img]
[img]https://img.photobucket.com/albums/v248/BlackG2Teg/Transmission/DSC06655.jpg[img]</TD></TR></TABLE>
there's a snap ring on the top of the case. you have to open it or it'll never close. not sure if you knew that or not. don't forget to flip it after you close the case so it'll snap in place.
Old Oct 13, 2008 | 07:54 PM
  #27362
Kuppa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TallKyle &raquo;</TD></TR><TR><TD CLASS="quote">dude if you dont know what a 2 step is.. dont boost your car.</TD></TR></TABLE>
Um so peole are just supposed to know everything wow so you had know learning curve. You just magicaly knew everything about turbos wow your cool. I asked cause if its good i would like to put it on my car but your kind of a dick for answering the way you did.
Old Oct 13, 2008 | 08:05 PM
  #27363
Default Re: (Kuppa)
anyone know anything about the Exedy OEM Replacement Clutch Cable? basically wanting to know about the quality, if it's worth buying, and what the adjustment part is made out of. the pics look like it may be made of metal? rather than plastic. which is basically exactly what i am looking for.
any helpful information is very much appreciated. need this info asap. my stock adjustment **** stripped, and it's pretty much useless. thanks in advance.
Old Oct 14, 2008 | 04:36 AM
  #27364
Mattb16teg's Avatar
Community Builder
Default Re: (hondamn1320)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondamn1320 &raquo;</TD></TR><TR><TD CLASS="quote">anyone know anything about the Exedy OEM Replacement Clutch Cable? basically wanting to know about the quality, if it's worth buying, and what the adjustment part is made out of. the pics look like it may be made of metal? rather than plastic. which is basically exactly what i am looking for.
any helpful information is very much appreciated. need this info asap. my stock adjustment **** stripped, and it's pretty much useless. thanks in advance.</TD></TR></TABLE>
Hmm never even seen this before. I try to stick with OEM items as much as I can because you know they will always fit perfect. Aftermarket items are hit or miss.
Pics?
Old Oct 14, 2008 | 09:11 AM
  #27365
only one i have. i'll try and look for more.
Old Oct 14, 2008 | 09:15 AM
  #27366
RED_90TEG's Avatar
From: where i stunt SAND CANYON in Southern California
finally everyones putting on dc side rockers ! havent figured out the rear lip yet ... have u guys ?
Old Oct 14, 2008 | 10:13 AM
  #27367
Blk_EJ1's Avatar
Default Re: (RED_90TEG)
No need for the rear lip...
Old Oct 14, 2008 | 10:15 AM
  #27368
hb420's Avatar
Oem optional lip
Old Oct 14, 2008 | 10:41 AM
  #27369
Mattb16teg's Avatar
Community Builder
Default Re: (hb420)
Im pretty happy with my JDM carbon front lip and Knock off mooooogen sides.
Old Oct 14, 2008 | 10:45 AM
  #27370
hb420's Avatar
Default Re: (Blk_EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blk_EJ1 &raquo;</TD></TR><TR><TD CLASS="quote">No need for the rear lip...</TD></TR></TABLE>
That is true, but the oem rear isn't bad either
Old Oct 14, 2008 | 10:48 AM
  #27371
hb420's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RED_90TEG &raquo;</TD></TR><TR><TD CLASS="quote">finally everyones putting on dc side rockers ! havent figured out the rear lip yet ... have u guys ? </TD></TR></TABLE>
The reason mine are about to come off and looking for new ones and a different front lip because everyone"s asking me what lip i have and then go looking for it. Everyones car's are gonna look the same
Old Oct 14, 2008 | 11:08 AM
  #27372
Blk_EJ1's Avatar
Default Re: (hb420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hb420 &raquo;</TD></TR><TR><TD CLASS="quote">
That is true, but the oem rear isn't bad either</TD></TR></TABLE>
didn't know they had an oem optional, but I'm new to DA's too...
Old Oct 14, 2008 | 11:32 AM
  #27373
hb420's Avatar
Last pic on the page. That car doesn't have the complete kit
http://www.g2ic.com/forums/sho...ional
Old Oct 14, 2008 | 02:35 PM
  #27374
SYNSEI's Avatar
Default Re: (hb420)
The reason mine are about to come off and looking for new ones and a different front lip because everyone"s asking me what lip i have and then go looking for it. Everyones car's are gonna look the same </TD></TR></TABLE>
Herb's a mufukkin trendsetter ya'heard?
FREE M.O.P. show this weekend!!
Old Oct 14, 2008 | 03:21 PM
  #27375
hb420's Avatar
Default Re: (SYNSEI)
Dearly departed with Dj babu is crazy. And gangsta boy with Jake one is dope to. That should be a good show
