BUILT NOT BOUGHT!
Old May 23, 2012 | 04:12 PM
  #7551
91sedan_kid's Avatar
Default Re: BUILT NOT BOUGHT!
lol, took a long time for me to get that TSX.. 13 rejection before 1 approval. Everywhere i went they told me i either needed a bigger down payment or a high 700 co signer. A credit union told me about Golden 1 Credit Union and i gave them a go and sure enough i got approved! no co signer.
I wanted to get this car with no help from anyone and i got it. proud of myself.
Old May 24, 2012 | 09:58 AM
  #7552
91 crx savage's Avatar
Originally Posted by 91sedan_kid
Man this thread has been moving! Nice cars guys.
I been busy with work and trying to get a new car and also will be having a second child in a few months
if anyone can recall, a few months back i said i really wanted to get a Honda Crv or a Acura TSX.
Since i sold my Ferio i havent been able to get into a car and feel comfortable in it... Until now! My new baby
2006 Acura TSX
How's it ride it's awd right?
Old May 25, 2012 | 02:28 PM
  #7553
lude72's Avatar
i like those cars alot ... if i git a new car it would be an tsx type s
Old May 31, 2012 | 04:51 PM
  #7554
crx throwback..
goin through old pics
Old May 31, 2012 | 05:42 PM
  #7555
My_EFsedan's Avatar
im aching for a wings west crx..
Old May 31, 2012 | 08:10 PM
  #7556
OldSkoolDa91's Avatar
crx's will always have a soft spot in my heart
Old Jun 10, 2012 | 04:24 PM
  #7557
Dom93's Avatar
midely built ls/vtec:
89 b16a head
buddyclub spec 3+ cams
brian crower dual valve springs and retainers
blox flat face valves
AEM cam gears
5 angle valve job
b18a1 bottom
p30 pistons
ls rods
new OEM bearings
type r oil pump
type r water pump
LS sandwich plate
b16 oil squirters (dont know if it makes a differnce or not)
2-layer cometic head gasket
390cc dsm injectors
ARP head studs
misc parts:
skunk2 IM
skunk2 fuel rail
hasport motor mounts
lost the dyno sheet sorry =/ but here is what i made 186.3 top end 139ft/lbs tq
186.3 isnt the final hp, vtec wouldnt engage =/
Old Jun 10, 2012 | 04:48 PM
  #7558
no vtec tho
Old Jun 10, 2012 | 05:44 PM
  #7559
Dom93's Avatar
Originally Posted by 91 crx savage
no vtec tho
Old Jun 16, 2012 | 09:16 PM
  #7560
Old Jun 18, 2012 | 06:54 AM
  #7561
mtflyboy25's Avatar
hey guys.
I am letting you all know I would like to join the crew. I have attempted posting long intros and got logged out each time. So this will do for now for ya I hope.
Mod list!
Exterior Modifications:
Restored to Stock correct oem bumpers and fenders.
Stock Tail Lights
Anzo Black headlights with Halo
Anzo Black Corner Lens
Anzo Black Blinkers wire as running lights too.
New OEM Honda Side Moldings
Carbon Fiber Hood
Sparco Hood Pins
Enkei RPF-1s 17x7 all around
Hanook 205/40/17s All Season Goodness
Interior Modifications:
Full interior Delete
Custom Chassis Wiring Harness
6 Point 1 3/4 Mild Steel Roll Cage
Aluminum Dash
Water Temp Gauge - 52mm GlowShift Black Elite Series
Oil Pressure Gauge - 52mm GlowShift Black Elite Series
Fuel Level Gauge - 52mm GlowShift Black Elite Series
Voltmeter - 52mm GlowShift Black Elite Series
A/F Ratio Gauge - 52mm GlowShift Black Elite Series
Boost / Vacuum Gauge - 52mm GlowShift Black Elite Series
Tachometer Gauge w/ shift light - 95mm GlowShift Black Elite Series
Speedometer Gauge - 95mm GlowShift Black Elite Series
Ebay Racing Seats - Reclinable
Custom Seat Brackets
RFI 5 Point Racing Harnesses
Performance:
1998 JDM B18C Inline 4 Cylinder 1.8 L 1797cc
Innovative Motor Mounts
Custom Cool Air Intake
Golden Eagle High Flow Polished Fuel Rail
Rebuilt Head
SBI Chrome Plated Valves
SBI Bronze Guides
Fel Pro Multi Layer Steel head Gasket
Fel Pro Intake Gasket
Fel Pro Exhaust Gasket
ARP Head Studs
1998 Acura Integra GSR Fuel Filter
Aeromotive 340 Fuel Pump
Aeromotive Adjustable Fuel Pressure Regulator
Aeromotive Fuel Pressure Gauge
Half Size Radiator
4-2-1 Header
2 inch no catalytic converter custom bent exhaust
Magnaflow 40 Series Muffler with 3 inch rolled chrome tip.
Suspension/Chassis:
Koni Yellow Adjustable Sport Shocks
Ground Control Koni Sleeves
350 Front / 250 Rear Spring Rates - Eibach Racing Springs
Black Works Racing Rear Lower Control Arms
1989 CRX Si Rear Disc Brake Swap - Complete Trailing arm swapped
1989 CRX Si Rear Sway bar swap
1994 Acura Integra DA Front Brake swap - Whole spindle / knuckle
Ebay Extended Top hats- Lime green all 4 corners.
Ingall's Camber Control Kit all 4 corners
Energy Suspension Poly Kit - All bushings in car changed to Poly.
Drivetrain:
S80 Transmission - 5 Speed
Helical LSD
Stock Rebuilt shafts
Innovative Shift Linkage
Electronics:
Custom Chassis Harness
Relocated Main Relay
Relocated Main Fuse Box
P72 Chipped ECU
Rywire Engine Harness
Custom Wired lights
Half way wire tuck
Turn Signals wired to function as running lights too.
To-Do List:
Too Much.
Here are some vids....
http://www.youtube.com/watch?v=DIwilXRi_3w
http://www.youtube.com/watch?v=Sxe0q-tviC4
http://www.youtube.com/watch?v=B1QmyI9unrg
Old Jun 18, 2012 | 01:15 PM
  #7562
Looks good but shouldent the jdm gsr put down more than 145? I know the stock b18c1's usually make that much
Old Jun 18, 2012 | 06:18 PM
  #7563
Mugenboij's Avatar
My 2 years and going project
Engine Bay:
mild wiretuck
H23A Blue top
Skunk2 pro IM
Phoenix friction fly wheel
Phoenix friction pressure plate
Phoenix friction stage 3 clutch
Megan headers
Ebay cat back
Ebay test pipe
Innovative mounts
Odyssey battery
Ebay radiator
Cheap intake that came with the car??
Ebay spoon reservoir cover
FLUSH BOLT ENGINE BAY DRESS UP KIT
Exterior:
Type s front lip
unknown ebay front lip
Mugen side skirts
Mugen replica aprons
Window visors
Rear window spoiler
Ebay front fog lights
Autozone license bracket
Depo Black housing headlights
Ebay rear tow hook
Interior:
Wink mirror
Bubble teal shift ****
98 Integra head rests
Chrome gauge rings
JVC deck
Suspension/wheels/brakes:
Drilled slotted rotors
Ceramic pads
Megan full coilover kit
Megan rear strut tower bar
Type S oem strut bar
C-piller bar
world suspension sway bar links
XXR 521 rims 18x10 +25 offset
AP1 front and rears
25mm spacer
NEO CHROME EXTENDED LUGNUTS
Mainly all ebay parts dyno'd on dynojet @205whp with 170wtq
Old Jun 20, 2012 | 09:35 AM
  #7564
mtflyboy25's Avatar
yeah idk. a b18c1 with 3 inch exhaust, big intake, dyno tune and 4-2-1 dc headers put down 1 less hp and 12 less torque than I did so I think the numbers were just a little low that day. it was a dynojet after all. But I dont really care, i know it scoots pretty good haha.
I lowered my seats 2 inches yesterday...
Old Jun 20, 2012 | 12:02 PM
  #7565
SHORTMAN46's Avatar
why lower the seats?
Old Jun 20, 2012 | 12:39 PM
  #7566
mtflyboy25's Avatar
Because the aftermarket seats I have practically hit the ceiling. The brackets were super tall too. So I just decided to drop them on the floor flat and that way I can see under the front bar of my cage...
Plus the way it sets me in the cockpit it just feels great.
Old Jun 21, 2012 | 09:59 AM
  #7567
NastyDB8's Avatar
HOLY HUGMONGOUS PICS BATMAN!!!
Old Jun 21, 2012 | 11:03 AM
  #7568
mtflyboy25's Avatar
Yea I don't know why they are so big. They are from my iPhone and normally are small.
Old Jun 21, 2012 | 11:59 AM
  #7569
Dramas_H22's Avatar
nice build bro looks good
Old Jun 21, 2012 | 08:37 PM
  #7570
mtflyboy25's Avatar
So this is how the dash is going to look from now on!
I haz a center console now! With a hole for my stereo! Which will eventually be a mini glovebox for the need info or maybe just a big legit switch panel, idk.
oh and I also now have door panels. They really finish off the car. Looks great. I still have all my aluminum pieces wrapped in plastic which is why they looks messed up.
New lowered seat bracket!
One side needed to be a little higher to be level...
Old Jun 21, 2012 | 09:09 PM
  #7571
where you on 680 going north this morning around 6:40am by warm spring blvd?
i swore the car looks just like yours.
Old Jun 22, 2012 | 08:26 AM
  #7572
that is some awesome lookin sheet metal work. that dash and those door panels are on point!
Old Jun 22, 2012 | 02:58 PM
  #7573
mtflyboy25's Avatar
Thanks man! I have been getting mixed reviews on it. It is pretty unique tho!
Old Jun 23, 2012 | 06:28 AM
  #7574
i think its pretty sick lookin. i'd love to have something like that
Old Jun 23, 2012 | 10:16 AM
  #7575
mtflyboy25's Avatar
well buy a welder and start practicing!
