BUILT NOT BOUGHT!
Old Apr 24, 2011 | 10:13 PM
  #5001
GaaaareenTeg's Avatar
Default Re: BUILT NOT BOUGHT!
Originally Posted by DKYamada
whats up guys, been a while since i've dropped in. i crashed my friends R1 last week so just been recovering, finally start back at work tomorrow so we'll see how it goes.
yesterday met up with mr robert deluna and did a mini shoot. the model that was suppose to come didnt get ready in time so we just ended up going witout her.
here's a little preview of my GS and my friend's EK
That ek is noice.
Old Apr 25, 2011 | 06:53 AM
  #5002
OldSkoolDa91's Avatar
Originally Posted by brokensol
I have a quick question. Can I use a b16 shift linkage out of a del sol in my 95 civic coupe? Some people say del sol linkages are only for del sol's and wont work. I put a b20z motor with b16 tranny in the car. Thanks
no. like you've been told, they are different
Old Apr 25, 2011 | 07:20 AM
  #5003
del_sol_freak's Avatar
Del sols are longer. I took a set and chopped and welded them back together. I wanted the shifter to set closler to me in 1st and 2nd. But stock wise no they will not work.
Haha got the V6 out last night. its still in limp mode . Sold the b16/lsd trans out of the hatchback. Time to order the AEM EMS2 for the J . I hope everyone had a good weekend
Old Apr 25, 2011 | 07:30 AM
  #5004
NastyDB8's Avatar
Hey what's up BNB? I have been on vaca for a couple days and i was catching up on the thread No new updates other than the drilled and slotted rotor upgrade I did to my ride braking is sooo much smoother now.
Old Apr 25, 2011 | 07:54 AM
  #5005
AWEK's Avatar
Hi guys!
I bought my stock DelSol Motegi 2years ago, not much (only interior, and some body) have left stock
The main chagnes:
Stage one: swap D16Y8 into B18C4 (from UK areodeck); oem OBDII to OBDI P28; whole new intake (K&N) and exhaust (4-1, 2,5")
Stage two: new suspension Buddy Club N+ spec.; strut bars; break hybrid Prelude/Rover (front 282)
Stage three: body changes (wheels, hood, spoiler, etc...)
Before:
Now:
Old Apr 25, 2011 | 10:04 AM
  #5006
91 crx savage's Avatar
Originally Posted by N/A
Try honda mtf in the new tranny.
Yea, why are you against full syn, my friends told me it was ok to run it in my ls it seemed to hold up longer
Old Apr 25, 2011 | 01:25 PM
  #5007
N/A's Avatar
N/A
Purpose Built
No offence, but your friend don't know what they're talking about
Synchronizers need some friction to perform correctly and keep from wear, synthetic oil greatly reduces friction, too much for trannys.
People have had great success with honda mtf and GM synchromesh
Old Apr 25, 2011 | 03:15 PM
  #5008
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
you don't want full synthetic oil in your manual transmission, Honda used to recommend regular motor oil, but that's before the Honda manual transmission oil came out. The synchronizers need a specific amount of friction to work properly, either the Honda fluid or GM syncromesh work great. A lot of people have fixed difficult engagement problems with changing the fluid.
Old Apr 25, 2011 | 03:36 PM
  #5009
N/A's Avatar
N/A
Purpose Built
Way to repeat what I said lol
Old Apr 25, 2011 | 05:22 PM
  #5010
I think I was typing at the same time you were or something, I didn't see your response until I posted
Old Apr 25, 2011 | 06:37 PM
  #5011
TGC-206's Avatar
that white ej1 is super clean! did you buy those wheels polished or do it yourself?
Old Apr 25, 2011 | 07:00 PM
  #5012
i've been under the dash in a strange positition trying to figure out a bracket for my ignition relays using factory holes, not easy doing all this stuff when you are 6 -1 and it's a tiny car, my wiring harness looks like it exploded, but I live for this ****, most people would look at it like WTF? but I know every wire and circuit in this car. it looks like behind the instrument panel on a twin engine aircraft during an avionics overhaul. I've always had the ability to build and remember super complex harnesses and motor control stuff, some people paint, some play music, I design stuff that gives the average person a migraine
Old Apr 25, 2011 | 07:37 PM
  #5013
N/A's Avatar
N/A
Purpose Built
Take out the fron seat while u work on the dash, its only 4 bolts
Old Apr 25, 2011 | 07:47 PM
  #5014
I know this. i just have a couple of bolts loosely holding it in, my entire interior is out, the way this car is built it's easier for me to contort myself from the side through the door opening,it's almost impossible for me to do it in any other position, I also have some complex mechanical stuff I built bolted to the floor under the seat with nice sharp edges, not fun to lie across
Old Apr 25, 2011 | 09:15 PM
  #5015
two hours of upside down to make this stupid template, and bolt it in, but now I know just a little bit trimmed at the lower and upper corner, and when I copy it into steel everything will clear properly. they are buried WAY up under my dash under the cowl above the pedals, and will hold my ignition relays, really fun to get to
Old Apr 25, 2011 | 09:26 PM
  #5016
91sedan_kid's Avatar
THE SAN JOSE SHARKS IS MOVING ON TO THE SECOND ROUND OF THE PLAYOFF!! IM SO EXCITED!!!!
Old Apr 26, 2011 | 12:44 PM
  #5017
DKYamada's Avatar
^ YEEE!
Old Apr 26, 2011 | 01:08 PM
  #5018
JesusGLS's Avatar
Here are some of my old ride...
BEFORE:
AFTER:
Old Apr 26, 2011 | 01:27 PM
  #5019
DKYamada's Avatar
not bad. a front lip would set it off.
Old Apr 26, 2011 | 01:37 PM
  #5020
N/A's Avatar
N/A
Purpose Built
God take that megan sticker off your cover...
That **** is garbage
Old Apr 26, 2011 | 01:54 PM
  #5021
DumaDA's Avatar
when i saw the first couple pictures i was like "his sidemarkers are hella low wth" then i saw under the hood and i was like "fucc the sidemarkers"
and who gives a **** about a sticker
Old Apr 26, 2011 | 02:38 PM
  #5022
x2, i would like to see it a bit lower but its not too bad at the current height.
what motor/setup you running?
edit: idk if its just me but the motor looks kinda off to the right.
Old Apr 26, 2011 | 02:42 PM
  #5023
My_EFsedan's Avatar
its boosted, thats all i care for haha!
Old Apr 26, 2011 | 03:21 PM
  #5024
N/A's Avatar
N/A
Purpose Built
Why display garbage on such a nice build?
Old Apr 26, 2011 | 03:40 PM
  #5025
does no one like flat black anymore? I used to have a different color but when you polish the aluminum parts it really sets off the flat, I have some anodized purple, but mainly as an accent
