BUILT NOT BOUGHT!
Ok bnb. I got a skunk2 intake manifold for d series for real cheap 250 complete with d15b tb b series injectors iacv or 180 just the manifold bare no sensors or tb price is obo quick sale must go. Might be gettin a civic sedan with a k20 swap for 5bills so won't need this
It was his sons car he bought it before deployment to iraq he says and I guess he got drunk and crashed it nothin bad just radiator, radiator support bumper fenders lights hood basicly a whole front end. Well his son was killed over sees and the car is just sitting there all he says he knows was that he bought it for 6000 and that it has a motor out of a si in his words "the new huntchbacks". He said 500 and u pick it up or 700 and he dilivers it he just wants it gone.
Its been an ongoing sale since last year around november but he didn't have the pink he called me today and said he was able to put it under his name and register it.
hey mang! is that the VRKIDDRACING headers you have there cause it looks likr them ..I may have spelled his name on here wrong but I think it's something like that.
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
I got more done on the fuel pump, I wanted to add something to protect the pump and filter from flying road debris,
these are the end brackets, I already had cut them, and drilled and tapped them
the finished bracket
milling the support brackets
bottom plate
I'm still waiting on some fittings to come in, as well as the actual pump, should be here tomorrow
bottom plate
So I Installed My new D2 Spec Headlights w/Citylights but Citylights arent installed yet. After the install i tried starting my car and going for a drive to test ..plus my fogs were flickering too .. but it wouldnt start so .. im stuck .. any ideas.....
ive check the battery .. i think it could be the alternator possibly the starter ...
im mad.
im mad.
bottom plate
bottom plate
im mad.
im mad.
im mad.
im mad.
Uh check your fuse. starter and alternator fuse.
lostforawhile: That looks really good bro! Keep up the good work. I envy your fabbing skillz
I hope my nice new version of this pump is here tomorrow, It's the same pump but is a facet silvertop, this one is an old mockup pump from work, we use the same ones, I also had to order a 1/8 NPT to -6 right angle adapter from summit to hook up the pump to filter line, I'm trying to see if Norskog still makes my fuel pressure gauge, I wanted another sender to install by the pump, then i could fllip between pump pressure and regulator pressure. I'm also waiting on my time delay box, then i can finish hooking up my rfid key system
battery terminal or ground, the starter can't pull enough current, so it pulls the voltage down, then the alarm thinks someone tried to disconnect it, and it goes off, you said your fog lights were flickering, i'm almost positive one or the other is loose
TGIF. Whats the plans for the weekend everyone? I've been out in the garage so much this winter, I think the wife is going nuts. I'm out there from 4:30-11:00pm throughout the winter, trying to get this J-swap going for Import Alliance in Nashville. Think I'm gonna hit up a few bars. And do some side work to make some extra cheddar this weekend.
Ill also be cleaning all the dirt and mud off my car from our last storms we had.
This was going to be the side cover, but I left it on my bench at the house this morning, doh, so i started over.
This is the new cover, I already put the hole in the center of it on the mill. The hole is needed to clear the bolts on the filter
while deburring the hole, I decided it was a good time to give blood,
I needed something to cover the hole, ( the cover hole, not the hole in my thumb) so I used an old wheel hub,
continued.............
of course it needs paint, other then the center cap, and i need to finish putting the rivets in the lower bracket, but it all fits. I think this will protect the pump and filter well
