BUILT NOT BOUGHT!
Old Oct 20, 2010 | 10:07 PM
  #1126
sc34dc4's Avatar
Default Re: BUILT NOT BOUGHT!
Well other then cams it's finished and they will be here on Friday. S300 is the last thing I need to go get tuned. Spring can't come soon enough.
Old Oct 20, 2010 | 11:28 PM
  #1127
91sedan_kid's Avatar
loving it bro!
Old Oct 21, 2010 | 08:11 AM
  #1128
CarlosEK's Avatar
A little update from my side..
the front is on it's lowest, in the rear I can lower it 3 or 4 cm more, but I like this stance..
Now I need some rims!
Old Oct 21, 2010 | 11:37 AM
  #1129
what wheel you got in mind carlosek?
Old Oct 21, 2010 | 09:11 PM
  #1130
went to go tune my car today and ran into some problems.. drove up there fine. Before the tune we swapped out the spark plugs. Got everything ready and did a couple of run.
For some reason once my car gets into boost it starts misfiring and throwing off the dyno.. tried to figure out the problem and couldnt seem to figure it out. The chart showed 178HP/172TQ at 7600rpm boosting 4psi..
Unhappy with these number and will return once i figure out the problem.. video will be posted later.
Old Oct 21, 2010 | 09:24 PM
  #1131
.:Spoon_Fed_09:.'s Avatar
dam bro sucks to hear that......... I honestly have no idea lol I want to go boost myself too
Old Oct 22, 2010 | 03:41 AM
  #1132
BrayzieEF9's Avatar
Damn, I would be disappointed at those numbers as well.
Old Oct 22, 2010 | 07:35 AM
  #1133
sc34dc4's Avatar
The coil may be going bad in your dizzy. To much gap on your plugs and the spark is getting blown out. Map sensor is messed up. Those are a few things I'd try first.
Old Oct 22, 2010 | 08:58 AM
  #1134
My_EFsedan's Avatar
well the spark plug, 2 was gapped at 25 and the other 2 was at 30. i had regapped all at 30 and he said so far the car drives better.
Old Oct 22, 2010 | 10:47 AM
  #1135
DumaDA's Avatar
Kaelyn Powered
Old Oct 22, 2010 | 11:02 AM
  #1136
CarlosEK's Avatar
I have no idea
Old Oct 22, 2010 | 11:38 AM
  #1137
brayzie: i was really disappoint i didnt even bother asked for a sheet.. when i get everything fix i will go back for a retune and i will hit my goal of 250hp. i know i can push more but my block cant handle it so im going to only push it for 250hp.
sc34dc4: im going to swap out the dizzy and spark plug wires. hopefully its the wire because they old..
my_efsedan: I got on it when i went home yesterday and it was fine. but after driving it a little longer it started doing it again. Wasnt as bad but we'll see i didnt get to drive it that much.
dumaDA: hook it up with a job! im bored outta my mind at home nitto is getting boring.. no one wanna race me because i do bracket and my car is dead on everytime..
carlosek: your car is forest green correct?
Old Oct 22, 2010 | 12:40 PM
  #1138
phaphon's Avatar
are you using cold spark plugs?
Old Oct 22, 2010 | 03:44 PM
  #1139
yup. NGK #7445
picked these up today and the car is driving way better!
Old Oct 22, 2010 | 11:26 PM
  #1140
sc34dc4's Avatar
ITR cams arrived this morning and I spent my Friday night finishing up the motor. I'm sad to say it's finished but also happy cause now I can start saving for S300 and a new tune.
Old Oct 22, 2010 | 11:57 PM
  #1141
My_EFsedan's Avatar
i work at sears and i cant help to see how many fridges you have!?
Old Oct 23, 2010 | 12:07 AM
  #1142
sc34dc4's Avatar
lol true. There's only 2 mini's plus a stand up chest freezer. The stainless one is the actual fridge in the basement for drinks and beer. You can't see the 3 microwaves haha. My roomate's father was the hvac teacher at a technical school and he recently retired after 23yrs. So he had a bunch of **** he gathered and gave it to his son to fix and sell. That's why I don't have a garage to use anymore. There are probably 30+ ac units out there.
Old Oct 23, 2010 | 12:18 AM
  #1143
My_EFsedan's Avatar
ahh, i see..its odd how i notice those more than the motor! haha! i saving a bit more then a build block here i come!
whats your piston spec?
Old Oct 23, 2010 | 01:26 AM
  #1144
So a couple of friends and I took a drive to get some in n out. The car is driving WAY BETTER with the new spark plug wires. on the way there it was just us vs us and right before we exited i ran a prelude.. After i passed the prelude i realize it was a chick that was racing me..
Was having problem with my clutch. Wasnt grabbing when i powershift. However on the way back i found out that if i let off the gas when i shift the car will grab. Was trying to run my friend in a N/A partly built DB1 but he was texting and i ended up running a foxbody 5.0 mustang. Pulled on him the 1st run, 2nd run was interupted by another car, and 3rd and final run i smoked him badly.. very fun night to say the least.
Although the car wasnt able to be fully tuned it runs pretty good after the wires were replaced. Cant wait to go back and get a retune and see how much she's really pushing out!
Old Oct 23, 2010 | 02:47 AM
  #1145
My_EFsedan's Avatar
video is on my youtube. clips from the point and shoot only til i find a program for the hd videos.
Old Oct 23, 2010 | 08:29 AM
  #1146
sc34dc4's Avatar
Wiseco pistons 8.6-8.9 cp and scat rods
Old Oct 23, 2010 | 12:08 PM
  #1147
My_EFsedan's Avatar
hmm..i dont understand that ratio..
im looking for 9:0:1 (9:1) but people said if its a dd, then 9:8:1 cp pistons..if i can somehow get 500bucks () i will start my block
Old Oct 23, 2010 | 06:49 PM
  #1148
sc34dc4's Avatar
8:6 to 8:9 compression ratio. Your ratio's will never be dead on unless your working with a block and head that are of factory thickness. Any time you deck either one of those 2 things your compression ratio will change. That's why Wiseco gives you a range such as 8:6 to 8:9. I'm basically running a 9:1 ratio since both have been decked. Yes anything between 9:1 and 10:1 will be fine for a dd.
Old Oct 23, 2010 | 06:56 PM
  #1149
My_EFsedan's Avatar
understood. i need to read around more before i get myself a super early bday present lol.
Old Oct 23, 2010 | 09:37 PM
  #1150
sc34dc4's Avatar
Just remember the lower your compression ratio the more boost you will have to throw at it to achieve your power goals but it also has less chance of knock. It's better to run more boost and lower compression ratio since the additional air can be compensated with more fuel. Opposite for higher compression ratio but at 10:1 you have nothing to worry about with a reputable tuner. That goes more for like 11:0 and higher. People have been boosting stock ls and gsr motors for years and the factory specs are...
b18a 9:4:1
b18a1 9:2:1
b18b1 9:2:1
b18c1 'us' 10:0:1
b18c 'jdm' 10:6:1
b18c5 'us' 10:6:1
b18c5 R 'jdm' 11:1:1
