BUILT NOT BOUGHT!
Old Feb 18, 2011 | 01:53 PM
  #3201
CDdubz5's Avatar
Default Re: BUILT NOT BOUGHT!
Originally Posted by Mrevann
ok coo.. so then .. for the meantime if i got some SlipStreams or GT3's that would be the size i would be looking for
because they aren't low offset you could do 205/45/16s
Originally Posted by DA9_All_Motor
Ok right now I have 205 50-15 on my ride any reason why more of you prefer the 195 size tire? Or is it just for the negative camber look and no rubbing effect?
the reason 195s are more common is because when you start talking low offset, there needs to be clearance between the fender and tire and so going with 195 or 205 width on an 8"wide wheel will give the tire some stretch to clear the fenders
like this:
Old Feb 18, 2011 | 01:59 PM
  #3202
DumaDA's Avatar
195s on an 8" wheel wont stretch that much though, wasnt much of a stretch on mine
Old Feb 18, 2011 | 02:02 PM
  #3203
CDdubz5's Avatar
no its not but its about as stretched as i would go for saftey and piece of mind
Old Feb 18, 2011 | 03:00 PM
  #3204
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
copied my post from three geez of a small project I was working on today
after the terrible luck i've had with the stupid in tank pump, i've decided to go with the Walbro pump under the body, it's a diaphram type pump and is very much like the old AC pumps that were used with SU's for decades. the main problem with the setup is the fuel outlet is on the top, this series of the Walbro pumps has a dry lift capability of two feet, that means even if the hose is empty, it can suck the fuel two feet straight up to the pump if needed. once fuel reaches the pump it has a prime anyway, most pumps are damaged if they run dry like this. This is one of the only pumps i've seen that can pull fuel not just push it. This is my solution to locating the pickup in the tank in the correct position, and being able to use a factory pump sock.
first I machined this aluminum adapter to replace the pump, this will locate the pump sock in the correct position in the tank, i cut a groove in the body for the hanger clamp,
I moved the sock up slightly, for some reason it sits against the tank, and restricts flow
First I milled it out at 3/8, then I used a tapered 7/16 reamer to ream it for the pipe threads, the other side was milled out at 3/4 for the adapter for the pump sock
this is the sock adapter, I took a 1/4 aeroquip coupler, machined one end to fit the pump sock, and cut a retaining groove, the other end was machined to 3/4 and pressed into the other piece, then tig welded
Old Feb 18, 2011 | 03:08 PM
  #3205
CDdubz5's Avatar
nice man! you're pretty intuitive
Old Feb 18, 2011 | 03:12 PM
  #3206
If I wasn't broke, I just need a couple of FI type hose clamps and a piece of fuel hose, and I would go mount it on the tank
Old Feb 18, 2011 | 03:43 PM
  #3207
Mrevann's Avatar
GDD Black Reject
Originally Posted by DumaDA
you know, 91sedan_kid can swap a motor pretty damn quick...just saying..lol
does that mean i should drive this car all the way up to him ???
Old Feb 18, 2011 | 04:15 PM
  #3208
DumaDA's Avatar
im just messing around i cant speak for him haha, just saying he probably knows everything you need to know about putting that b16 swap into your car, especially that putting in a b16 is probably a waste of time, lsvtec or b20vtec would be better
Old Feb 18, 2011 | 04:24 PM
  #3209
91 crx savage's Avatar
I sold my b16 and turned out it had spun bearing ouch
Old Feb 18, 2011 | 04:28 PM
  #3210
mugendamugen's Avatar
dam a spun bearing no good
Old Feb 18, 2011 | 04:38 PM
  #3211
Yea man good thing U dident buy it and good thing I dident swap it, needless to say the guy I sold it to was pretty mad. I was told it was good I could tell it dident burn oil but can't tell a rod knock untill it runs.
Old Feb 18, 2011 | 04:45 PM
  #3212
Mrevann's Avatar
GDD Black Reject
Quick update got the front bumper off.. its soooooooo dirty ... i got alot of work there is a dent in my frame
Old Feb 18, 2011 | 05:27 PM
  #3213
91sedan_kid's Avatar
ya i tried looking for it wasnt there.... unless im blind ..
so today i called Nastie garage and its gonna 2200 for a JDM B16 and thats the complete change over.
so imma start preparing to drop my engine. I need to go buy a engine hoist and some tools and slowly teach myself how to take a engine out .. but never put one in lol ..
are you planning on baring the b16?
i wish i was as fast as Ngoc.
Originally Posted by Ef9vsDa9
how quick lol
messing around in between or just straight work?
x2
if the car is already obd1 then all you need is the mounts from a 94-01 integra, shift linkage and everything else is just plug and play. put everything in the way you took it out.
if your trying to bar it, then your going to have to do some research because i havent bar;d a car yet. looking to bar a GSR in the ferio though, then turbo.
ouch times a million.
so i decided to look under my car.. and i find out that the car has a straight pipe.. i bought the car because i wanted a car i can smog without hassle.. now i find out this car is not smogable unless i buy a cat and resignator. im tempted to boost my single cam but this rain weather is helping me resist it.
Old Feb 18, 2011 | 05:34 PM
  #3214
Weather is shitty hate driving in this rain Cant see anything
Old Feb 18, 2011 | 05:36 PM
  #3215
that makes two of us.. i was just at my cousin house and i told myself to take pic of the dam tires and i completely forgot when i left.. i will get some pic asap for you bro.
Old Feb 18, 2011 | 05:50 PM
  #3216
Mrevann's Avatar
GDD Black Reject
ya imma have too right ?
i gotta make it look like a B16a2 ?
Old Feb 18, 2011 | 06:20 PM
  #3217
its not hard to bar'd a b16 or a b18 in a eg just need all the smog emission. also it would put your mind at ease knowing its legal for you to have that motor in your car.
but if your a thug, then **** it.
Old Feb 18, 2011 | 06:39 PM
  #3218
Mrevann's Avatar
GDD Black Reject
nahh F*ck that lol ... i rather do it the smart way ...
Old Feb 18, 2011 | 06:49 PM
  #3219
Mrevann's Avatar
GDD Black Reject
Update .... i just noticed that my Right tire it down to the wires.. my headlight holder one of them broke .. so ya .. but here are some pictures..
im alittle annoyed that some of the sh*t is my splash guards are rip apart and ya .. looks like i got alot of work with this engine bay ... before i get my b16. what should i do with my harness and **** .. and on top of that i wanna do a wire tuck ..
Old Feb 18, 2011 | 10:11 PM
  #3220
91_LS's Avatar
Hay BNB,its been hell the last 3 days and its only getting worse. It took me an hour and a half to plow out of my driveway (A FOOT IN A HALF IN 4 HOURS OF DUMPING) just to look out again 4 hours later to have 2 and a half feet all over again. Looks like its going to be awhile till i can start working on the car,but ill keep you all up to date when GOD stops punishing me for all me sins.
Old Feb 18, 2011 | 10:37 PM
  #3221
My_EFsedan's Avatar
its funny how you forgot to take pix of the tires and keep saying ill do it tmorrow when i like literally sleep next to them and have a million cameras in my room! hahahaha!!!!!nsoifhsuofckcbgmuhcbhxvn lgn,vmghjzjk,jfkchnaszkhjvbjlfvabjl; vgr41ag534a56g4654d56vg464a6.5t4a6e84bta561va56156
s.1561.tb56w
Old Feb 18, 2011 | 10:47 PM
  #3222
My_EFsedan's Avatar
here..
3 nexen 1 yokohoma
top to bottom
Old Feb 18, 2011 | 10:51 PM
  #3223
DKYamada's Avatar
lol that **** sounds funny, canibeat meet.
kinda wish i didnt go lol. i hydroplaned on 880 on the way back alot. but if i get 1 or 2 decent pics from the meet, i'll be happy
Old Feb 19, 2011 | 07:39 AM
  #3224
And if your gangsta u ride a b20vtec haha
Old Feb 19, 2011 | 09:42 AM
  #3225
Mrevann's Avatar
GDD Black Reject
so whats the easiest way to take my SOHC out. and i was wondering if i should order some new fenders for PasswordJDM the ones with the sidemarkers what u guys think or should i just put my sidemarkers in myself?
