Forced Induction Everything Forced Induction (Ex: Turbo Kits, Intercoolers, Blowoff valves, IC Piping, Turbo Manifolds)
lsvtec turbo question...
Old Oct 21, 2004 | 12:06 PM
brega3's Avatar
Default lsvtec turbo question...
I am posting for a friend who has a lsvtec ls block with gsr head and he wants to go turbo. His question is what compression should he be running and how much pounds of boost should he run? Oh by the way the engine is in a 92 civic hatch dx
Thanks
Old Oct 21, 2004 | 12:10 PM
Cractos's Avatar
Default Re: lsvtec turbo question... (brega3)
i would run about 10psi on a stock engine...with little fuel management...
Old Oct 21, 2004 | 12:11 PM
JDMallTHEway's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brega3 &raquo;</TD></TR><TR><TD CLASS="quote">I am posting for a friend who has a lsvtec ls block with gsr head and he wants to go turbo. His question is what compression should he be running and how much pounds of boost should he run? Oh by the way the engine is in a 92 civic hatch dx
Thanks</TD></TR></TABLE>
I tihink 8psi would be safer
but brega3 has a turbo ls/vtec, so I think he knows better...
Old Oct 21, 2004 | 12:17 PM
ej1 pilot's Avatar
Default Re: lsvtec turbo question... (JDMallTHEway)
it must be boost day in EG+
https://honda-tech.com/zeroforum?id=16 &lt;---forum specifically for forced induction right here on HT! =O
Old Oct 21, 2004 | 05:58 PM
brega3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMallTHEway &raquo;</TD></TR><TR><TD CLASS="quote">
but brega3 has a turbo ls/vtec, so I think he knows better...</TD></TR></TABLE>
I wish, but I don't have one
Old Oct 21, 2004 | 06:29 PM
oh, thought you did. anyways 8 psi is prolly the most you'll want to run.
Old Oct 21, 2004 | 07:54 PM
VvPeachyvV's Avatar
this is kind of off topic but i heard that vtec heads blew rather quickly on b18b blocks....or is that b20?
anyways i would think about that before adding boost, to a higher compression head, remember boost=10x the miles on ur engine
Old Oct 21, 2004 | 09:51 PM
drumking15's Avatar
Default Re: lsvtec turbo question... (VvPeachyvV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VvPeachyvV &raquo;</TD></TR><TR><TD CLASS="quote">this is kind of off topic but i heard that vtec heads blew rather quickly on b18b blocks....or is that b20?
anyways i would think about that before adding boost, to a higher compression head, remember boost=10x the miles on ur engine</TD></TR></TABLE>
you have sooo much learning ahead of you
Old Oct 23, 2004 | 08:36 AM
VvPeachyvV's Avatar
Default Re: lsvtec turbo question... (drumking15)
you're correct, which is why i'm in this forum and reading, reading, reading
Old Oct 29, 2004 | 01:06 PM
RPS turbo clutch's Avatar
Put some cp pistons in with 9:1 compression a block guard eagle rods and some JG valve springs and retainers and you should be safe anywhere from 10-16psi. i have the same set up on my hatch and its my daliy driver.
2OOO ITR
Nov 6, 2010 10:53 AM
juba_x
Mar 26, 2008 09:30 AM
ghostcivic
Jul 19, 2007 03:23 PM
NightKids
Oct 1, 2003 02:47 PM
tencan
11
Sep 30, 2003 08:07 AM
