z6block/d15b7 head??
Old Nov 15, 2005 | 11:45 AM
project-boosteD's Avatar
Default z6block/d15b7 head??
i searched, even the archived
i was wonderin how a z6 block (stock) with a d15b7 head (stock) would hold up to 5-6.5lbs of boost.
im runnin the greddy 15g kit and the greddy e-manage, soon to be a chipped ecu tuned with uberdata or crome
how will this hold up, whats the CR gonna yeild?
Old Nov 15, 2005 | 11:52 AM
nonvtecD's Avatar
Why would you do that? It would have 8:1 compression and really crappy flow, so, sure, you could do it, but why?
Old Nov 15, 2005 | 11:58 AM
my d15's throwin out some cruicial blue smoke, and the breather on my valve cover emits smoke alos, i heard that was the case of bad rings, so i was just wanting to know if putting a d16 block on my ***** would help or hurt, and that way i can use the rings being bad as an excuse to get a stronger, better block for my set up
Old Nov 15, 2005 | 12:01 PM
nonvtecD's Avatar
you have access to a full z6? just put the whole thing in... but I guess if you only have the block this would work, like I said, low compression...
Old Nov 15, 2005 | 12:11 PM
what kind of boost would i be able to run on this set up...safely?
z6 block d15 head, all stock
Old Nov 15, 2005 | 12:12 PM
Old Nov 15, 2005 | 12:20 PM
got the info i needed....
preciate it
Old Nov 15, 2005 | 01:55 PM
SuperSteve737's Avatar
So what info did you get?
Old Nov 15, 2005 | 06:56 PM
8.2:1 CR....depending on how i tune 10lbs of boost....
Old Nov 15, 2005 | 07:02 PM
pheurton-skeurto's Avatar
nothing like detuning a perfectly good block...
save yourself $80-100 and grab a d16 head for God's sake.
D15b Sol
May 13, 2010 01:48 PM
fonkernuckle
May 31, 2006 06:55 PM
BoostedEgHatchFl
May 4, 2005 04:09 PM
eg4usdm
May 2, 2005 07:01 PM
