is your BOV open/slightly open OR close during idle?
Old 07-03-2003, 12:33 AM
_Endless_'s Avatar
Default is your BOV open/slightly open OR close during idle?
which one is better...close or open during idle? how would you know if your bov is open or slightly open?
Old 07-03-2003, 12:47 AM
red_sir's Avatar
Default Re: is your BOV open/slightly open OR close during idle? (_Endless_)
My BOV is open during idle. You would know if it's open if you get out and look and listen to it. I'm not sure which is better but I kind of worry about sucking in dirty, unfiltered air.
Old 07-03-2003, 01:12 AM
SiRkid's Avatar
Default Re: is your BOV open/slightly open OR close during idle? (red_sir)
my types whistles like a damn bird a lot when I come off the throttle(light throttle)
Old 07-03-2003, 02:01 AM
New User
SiR Kid's Avatar
Default Re: is your BOV open/slightly open OR close during idle? (SiRkid)
BOV should be CLOSED at idle, or your BOV is not adjusted correctly.
Old 07-03-2003, 02:05 AM
importimage's Avatar
Default Re: is your BOV open/slightly open OR close during idle? (SiR Kid)
How can you tell if it is open or closed at idle? I have an HLS blow off valve.
Old 07-03-2003, 02:07 AM
New User
SiR Kid's Avatar
Default Re: is your BOV open/slightly open OR close during idle? (importimage)
Put a piece of paper/spring next to it. If it sucks to the BOV, it's open.
Just don't let it get sucked in.
Old 07-03-2003, 06:01 AM
Happyman's Avatar
It depends really. I've heard some need to be open. On other setups they should be closed. That's why most BOVs give you the adjusting washers. Not to thread jack but I just got a TurboXS Type H34 and was wondering if it would be ok to use it with only 8 psi of boost. TurboXS says 10-25 psi with it but I already bought the damn thing
Old 07-03-2003, 09:39 PM
New User
Pritos's Avatar
closed. you wouldnt wanna suck in something nasty would ya?
if you have an adjusting screw at the top, tighten until closed. then blip the throttle a couple of times and feel or look at the piston again to see if its open still.
if you have those 'washers' then install a few to shut it.
Old 07-04-2003, 12:29 AM
InTeGrA B18b1's Avatar
Default Re: is your BOV open/slightly open OR close during idle? (Pritos)
my 1g bov is slightly open so is most bovs
Old 07-04-2003, 07:23 AM
scttydb411's Avatar
at idle you are in vacuum so your bov should be open somewhat since that is what causes it to open. i just put a small filter on mine and don't worry about it at all.
Old 07-04-2003, 09:54 AM
I Like Boost's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRkid &raquo;</TD></TR><TR><TD CLASS="quote">my types whistles like a damn bird a lot when I come off the throttle(light throttle)
Mine does the same, like a stupid bird whining.
Old 07-04-2003, 10:56 AM
FredoSP's Avatar
Default Re: is your BOV open/slightly open OR close during idle? (IMPULSE B18C-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IMPULSE B18C-T &raquo;</TD></TR><TR><TD CLASS="quote">
Mine does the same, like a stupid bird whining.</TD></TR></TABLE>
greddy type S?
eg:R
01-31-2007 01:27 PM
vladd
01-11-2007 11:06 AM
eg:R
09-17-2006 06:47 PM
NotUrAvgSi
09-14-2004 10:37 AM
EFbomb
09-03-2004 01:08 PM
Quick Reply: is your BOV open/slightly open OR close during idle?
