WTF is wrong with my Techedge unit....
Old Jan 2, 2003 | 07:44 AM
Boostless97Lude
Guest
Posts: n/a
Default WTF is wrong with my Techedge unit....
it only reads 10.5, no matter what.... is it possible that i am running that rich consistantly???
Old Jan 2, 2003 | 09:54 AM
KC GSR's Avatar
Default Re: WTF is wrong with my Techedge unit.... (Boosted97Lude)
I dont think it would stay at 10.5 and not change even a little bit
Old Jan 2, 2003 | 10:00 AM
dustin's Avatar
Default Re: WTF is wrong with my Techedge unit.... (KC GSR)
Sounds like it is not connected to the sensor correctly.
Old Jan 2, 2003 | 11:17 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: WTF is wrong with my Techedge unit.... (dustin)
is that even possible? i mean, the plug only goes in one way right
Old Jan 2, 2003 | 11:53 AM
Flamenco-T's Avatar
does it display 10.5, with a broken 5 ? and it stayed there ?
you may have some open wires from the sensor to the box, double check the wiring, make sure you have no shortage or etc.
stan
Old Jan 2, 2003 | 12:03 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: WTF is wrong with my Techedge unit.... (Flamenco-T)
that's exactly what it is, what do i need to check exactly?? i bought the pre-built kit if that matters
Old Jan 2, 2003 | 12:09 PM
Flamenco-T's Avatar
you may have cut one of the 7 wires open coming out of the box to the sensor...and possibly shorten it...
my suggestion, IM falcon, he can tell you the diagnostic steps as far trying to find where the open wire is...
stan
Old Jan 2, 2003 | 12:15 PM
Full-Race Javier's Avatar
what does ur voltmeter read for Vout?
Old Jan 2, 2003 | 12:27 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: WTF is wrong with my Techedge unit.... (javierb14)
damnit, this is the reason i bought a f*cking pre-built kit, b/c i'm gettin burnout on doinall this **** all of a sudden grrrr why can't **** just work damnit
Old Jan 2, 2003 | 12:41 PM
i ran into a similar problem with mine. i couldnt get a Vout signal from pin 7 of Con 3 to the display. http://www.techedge.com.au/vehicle/wbo2/wiring.htm other than that make sure u have enough voltage supplied to it, the 1.0 need 13.2 volts and the 1.5's need 11.0 volts
Old Jan 2, 2003 | 02:00 PM
echo999's Avatar
New User
Did the unit EVER work?
There is a problem with the displays getting stuck at 10.5 depending on how
cold it is (the display unit)..
Get a voltmeter and check the voltage across pins 6 and 7 (serial from the control
box).. and if you get a voltage, but the display still shows 10.5... then changes are
you have this problem.
I have the problem as well.. usually happens at night when it's colder outside.
This also happens when the photosensor on the face doesn't get enough light..
I think the design is screwy in some ways.. Try reading more at the
DIY-WBO2 yahoo forum.. search for wideband!
Old Jan 2, 2003 | 06:26 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: WTF is wrong with my Techedge unit.... (echo999)
well...... i unplugged the O2 sensor and plugged it back in, and ten after echo's post, i checked the display again (it's behind a flip down door under the radio), and it was working, so, either it was a bad connection to the sensor, or the display had to warm up, either way it works now, and that GReddy blue box is an excellent fuel management setup for 7psi, it reads between 14.4 and 14.8 at part, and WOT
Old Jan 3, 2003 | 04:05 AM
echo999's Avatar
New User
Hmm.. don't you think 14.4-14.8 is quite aggressive for under boost a/f?
Old Jan 3, 2003 | 04:41 AM
Boostless97Lude
Guest
Posts: n/a
it stays there constantly..... well, i think under boost it would drop down yo like 13.x, i wasn't really geting on it or anything, so it pretty much stayed in the ~14.7 area
folta2169
Dec 15, 2007 08:14 PM
96vtecI4
Aug 12, 2007 12:33 PM
lmike6453
Aug 5, 2007 07:48 AM
BLKCRX
May 17, 2002 04:44 AM
