can someone explain wideband to me?
i have read some threads, but they mostly explain installation. i wondering what a wideband does? when is it needed? i am going to run a built d16 on uberdata. thanks guys
Re: can someone explain wideband to me? (Btothe3rdDegree)
The stock o2 sensor is a narrowband sensor. It only has a range of 0-1 volts. Basically it was only engineered to tell you if the engine is running at stoichiometric conditions (14.7:1). This Stoich level isn't even what you would tune a boosted or nitrous car for, this would only apply to an N/A tune.
A wideband o2 can read from 0-5 volts and gives a much more accurate reading. This is engineered to be accurate and read air/fuel at different levels than stoich (rich or lean).
not required, but necessary to tune. narrowband will never let you know that you are running rich enough for boost.
you could just go to a dyno that has a wideband and tune it and then leave it alone. the only problem with not having one installed daily is that you could have a situation in which your car leans out or becomes untuned and you don't know until...boom!!
Re: (Btothe3rdDegree)
I've had good success with the Innovate. They are quite popular and are a great price. Innovative Motor Sports I belive is the name of the company.
Re: (skellator_thoj)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skellator_thoj »</TD></TR><TR><TD CLASS="quote">does anybody know the website addy to Innovative Motor Sports??</TD></TR></TABLE>
http://www.innovatemotorsports.com/
This should clarify a lot of wideband questions, hopefully:
https://honda-tech.com/zerothread?id=635792
-PHiZ
-PHiZ
Re: (PHiZ)
hey thanks phiz!! so a normal O2 sensor won't give you a accurate reading where as a wideband will? also they can be used as datalogging right? since uberdata doesn't have datalogging (yet) a wideband would be a good idea? or is it not nessesary
juniordc2
12-27-2017 01:51 PM
Westrock2000
02-25-2002 05:20 PM
