willem programmer question (uberdata, 29c256 chip)
Old Jun 29, 2004 | 08:02 PM
birz's Avatar
Default willem programmer question (uberdata, 29c256 chip)
Hi I have just bought the standard Willem programmer and I want some inputs before I mess around with it.
this one:
I will be burning 29c256 chip with it, so how do I setup the thing to get it to work??
I have read the walkthrough on boosted-hybrid but this one is for the enhenced version willem programmer,,, so it's not the same thing. Can someone guide me a bit or give me some links to read about???
thanks in advance.
Old Jun 29, 2004 | 08:04 PM
AspectIndustries's Avatar
Default Re: willem programmer question (birz)
lolz, n00b as i am. What is used to burn these chips? Recommended programs? (Sorry to jack thread, i also want to know how to work the thing) -
Old Jun 29, 2004 | 08:07 PM
birz's Avatar
Default Re: willem programmer question (synik)
the program that came with the burner itself does the job EPROM3 (when I find out how though )
Old Jun 29, 2004 | 10:14 PM
T-RO's Avatar
http://www.willem.org/
Download version 97g
set your DIP switches like the program says.
it will tell you to "jump" pins 3&31 when burning 29c256 chips. I just stick a small piece of wire in there.
Great burner for the price once you know how to use it.
Old Jun 30, 2004 | 03:09 AM
birz's Avatar
Default Re: (T-RO)
that's it?? I thought it was to simple to be true,,, pin 3 and 31 wich one are they though? where do you start to count?? can you tell me wich pins are 3 and 31 on the above picture??
thanks.
Old Jun 30, 2004 | 06:23 AM
Mad Cow's Avatar
If you don't find answers here, see my signature.
Old Jun 30, 2004 | 07:29 AM
birz's Avatar
Default Re: willem programmer question (Mad Cow)
I already ask the exact same question on fue uber forum also.
Old Jun 30, 2004 | 08:52 AM
T-RO's Avatar
Looking at the picture you posted above:
Pin #1 is the top left
Pin #32 is the top right
So it goes down then across then counts back up. Got it?
Just stick a SMALL piece of wire, or use the leg off a capacitor in pins 3 & 31
Old Jul 6, 2004 | 08:11 AM
doggydogg's Avatar
Pin 1 is right under the lever, across from it is pin 32...i think. anyways, it worked for me burning Roms on those chips.
Old Jul 6, 2004 | 08:16 AM
raene's Avatar
I used a male/female spade connector in the middle of the wire and soldered it into place from the bottom, you could just as easily use a switch. I also have some 27c's I use so it makes it easier to flip back and forth that way and you never have to worry about the wire falling out. GL!
Old Jul 6, 2004 | 07:09 PM
Crote's Avatar
Default Re: (raene)
I didn't put that jumper in place and never had problem with burning at29c256.
Maybe it's wrong and my chip will not last long. Someone can confirm me if it's wrong to not use it ?
Old Jul 6, 2004 | 07:38 PM
T-RO's Avatar
im surprised you didnt get an error message. If my wire isnt in good enough i get an error.
Mabye you didnt select the correct chip from the list?
Old Jul 6, 2004 | 07:43 PM
Crote's Avatar
Default Re: (T-RO)
The software ask me to jump it, but I forgot first time and never have problem so I let it without the jumper.
thatseemslegit
Engine Management and Tuning
Oct 21, 2017 10:23 AM
Honda4life777
Jul 11, 2009 09:39 PM
EX-T
May 22, 2006 08:51 AM
cyrock
Aug 9, 2005 08:19 AM
turboH22Aakkord
Apr 18, 2005 03:52 PM
