oil return line help!!!
Old Mar 1, 2007 | 10:57 AM
D15Bbigred's Avatar
Default oil return line help!!!
I am using a stealthmode kit. and the line fits fine on the turbo side of the return but does really come close to fitting on the pan side. trying to figure out what my options are. any help is appreciated. thnx
Heres a pic of what I'm dealing with.
Old Mar 1, 2007 | 11:56 AM
D15Bbigred's Avatar
also what temp does oil run at in the return line? locally i can get some rubber 212 F hose. I'm thinken that may work.
Old Mar 1, 2007 | 01:47 PM
stealthmode62's Avatar
Default Re: (Autoworks)
The drain line has a 5/8 inside diameter. I'm not sure what diameter of that fitting you're using is, but it looks like you'll either need to change that fitting, or get a larger hose.
How is that fitting attached to the pan?
Old Mar 1, 2007 | 01:52 PM
building boost's Avatar
looks like its gonna end up being a big mess of oil lol.
Old Mar 1, 2007 | 01:53 PM
D15Bbigred's Avatar
its been welded on and then hit with a good amount of jb weld. wasn't my crappy job, the person i bought it from did it. I'll probly just go with a different hose. but is 212 degree hose going to be ok? I don't know where to find any higher temp hose.
Old Mar 1, 2007 | 01:56 PM
D15Bbigred's Avatar
the diameter of the fitting on the pan is a little under 3/4" . grinding the bead will do nothing. and hopefully it will not be a mess
Old Mar 1, 2007 | 02:26 PM
JoePSI's Avatar
Default Re: (D15Bbigred)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D15Bbigred &raquo;</TD></TR><TR><TD CLASS="quote">
Its hard to tell from the picture but that fitting doesnt look extremely fluid and may cause a headache when you begin clocking your turbo. You could weld a better fitting on.
Another option would be the moroso replacement plan. I used it and there have been zero leaks.
Old Mar 1, 2007 | 02:55 PM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D15Bbigred &raquo;</TD></TR><TR><TD CLASS="quote">its been welded on and then hit with a good amount of jb weld. wasn't my crappy job, the person i bought it from did it. I'll probly just go with a different hose. but is 212 degree hose going to be ok? I don't know where to find any higher temp hose.</TD></TR></TABLE>
aeroquip makes 300F rated hose (blue). check their website for dealers in your area (plumbing stores). its not braided and i wouldn't use braided line on the type of fitting you got there.
Modified by vtec.dc2 at 7:57 PM 3/1/2007
Old Mar 1, 2007 | 03:51 PM
D15Bbigred's Avatar
thanks vtec.dc2 i'll look into it. so some think this fitting may cause a problem. y?
Old Mar 1, 2007 | 04:29 PM
bigbadboy's Avatar
use some heater hose. it works just fine. used it numerous times on a lot of cars. and its cheap.
Old Mar 1, 2007 | 05:57 PM
Default Re: (bigbadboy)
I would either put the pan fitting that came with the kit in and block that one you have, or find a larger diameter hose. If you go with a larger diameter hose, you're also going to need a new barb coming off the drain flange as well.
Old Mar 1, 2007 | 07:36 PM
D15Bbigred's Avatar
yah i ordered a new barb fitting allready. i'm gonna give the push on hose a go. those aeroquip hoses look pretty sweet. If it leaks hopefully I can find someone local that drills. and taps pans.
jacob4lester
Feb 16, 2010 08:36 PM
cruiseMain
Dec 19, 2007 10:08 AM
Fatty_1775
Jul 30, 2006 08:04 PM
degradated
Sep 16, 2001 05:02 PM
