WILL THIS WORK?
Old Mar 25, 2006 | 06:09 AM
blacknite's Avatar
Default WILL THIS WORK?
I have a 1999 civic EX, with the stock D16Y8 Engine. I also have a TD40H-15G Turbo kit that everyone I’ve talked to say works great on the d16 engines. My problem is that I want the boot but I still want to keep most of my car stock. What, can I do to get the boot without doing major engine work?
But, right now I have the TD40 Turbo Kit its sit at about 7 psi, with intercooler, 300 cc injectors, fuel rail, 6 psi wastegate, and a BOV.
Another question I have is will my car run like this? Or should I start looking for a new engine?
Hope, u guys can help.
Thanks!
Old Mar 25, 2006 | 06:22 AM
Topdawgg's Avatar
that should work fine on a stock motor... boost away and have fun
the only problem i see is the injector size
Old Mar 25, 2006 | 06:39 AM
coneheadsracing's Avatar
Default Re: (Topdawgg)
what are you doing for fuel management? Otherwise, you'll be fine with that boost level, hell i boosted a y7/y8 with over a 100k miles on it to 15 psi, no issues at all. As have many others on here.
Old Mar 25, 2006 | 09:05 AM
blacknite's Avatar
Default Re: WILL THIS WORK? (blacknite)
really!! thanks!
What size fuel injectors would you guys Recommend? And much more boots can I put on this setup?
Thank! Again
Old Mar 25, 2006 | 09:15 AM
blacknite's Avatar
Oh, almost forgot, what would u guys recommend for a FMU? And should i one if I plan on adding more boots?
Thank!
Old Mar 25, 2006 | 09:29 AM
Brain3208's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coneheadsracing &raquo;</TD></TR><TR><TD CLASS="quote">what are you doing for fuel management? Otherwise, you'll be fine with that boost level, hell i boosted a y7/y8 with over a 100k miles on it to 15 psi, no issues at all. As have many others on here. </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blacknite &raquo;</TD></TR><TR><TD CLASS="quote">Oh, almost forgot, what would u guys recommend for a FMU? And should i one if I plan on adding more boots?
Thank! </TD></TR></TABLE>
Woa Buddy hold on. Don't go getting excited jsut yet! DO NOT! REPEAT DO NOT BOOST OVER 7PSI with a FMU and limited experience! yo udon't want t o kill that 99 EX engine just yet. sure it will take 15psi if tuned properly but in your situation consider 7psi your safety limit. Dont even consider a FMU, their are cheaper solutions that work better. I have some 450cc injectors FS if you need them PM me.
Brain
Old Mar 25, 2006 | 10:21 AM
blacknite's Avatar
Default Re: WILL THIS WORK? (Brain3208)
Thank, for the heads up Brain3208.
So, no more boots. That's cool, i guess.
But, how much to you want for those fuel injectors Brain3208?
Old Mar 27, 2006 | 07:38 AM
Brain3208's Avatar
$35 shipped
wasadsm99
Aug 1, 2011 07:19 PM
U2
19
Jun 23, 2005 07:17 AM
Snail Tuning
Jul 24, 2004 08:35 AM
Layziebtnh055
Jul 9, 2004 06:35 PM
wrXtian
Jul 18, 2003 01:02 PM
