will plastic IC piping work?
Old Oct 8, 2003 | 08:08 AM
  #51
skierGT's Avatar
Default Re: will plastic IC piping work? (evan2)
evan2 - yeah maybe man, i m me or sumthin
Old Oct 8, 2003 | 08:46 AM
  #52
syndicate43's Avatar
Default Re: will plastic IC piping work? (skierGT)
I have melted a couple of those rubber couplers so I changed up to the silcon ones
good luck
Old Oct 8, 2003 | 09:00 AM
  #53
Overblown-Teg's Avatar
Default Re: will plastic IC piping work? (syndicate43)
pvc works great.. J. davis on here ran if for about two years with no problems.. http://www.toohighpsi.com had it on the twin turbo capri running 15psi and it worked great.. They never had a problem with it.
Old Oct 8, 2003 | 09:43 AM
  #54
PHiZ's Avatar
Default Re: will plastic IC piping work? (Overblown-Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Overblown-Teg &raquo;</TD></TR><TR><TD CLASS="quote">pvc works great.. J. davis on here ran if for about two years with no problems</TD></TR></TABLE>
Did he chrome dip the PVC? That guy is such a stunna.
-PHiZ
Old Oct 8, 2003 | 10:03 AM
  #55
Default Re: will plastic IC piping work? (PHiZ)
J. Davis? I'm not sure what your talking about.. There was nothing shinny on his old setup.. I don't think there is any pvc on the new intercooled setup..Thats just because I had enough steel laying around for him to use.
Old Oct 8, 2003 | 10:33 AM
  #56
kaj's Avatar
kaj
there's gonna be a lot of upset people if that setup holds.... some of us have custom steel or aluminum tubing that was a bit on the expensive side!
props
Old Oct 8, 2003 | 10:40 AM
  #57
PrecisionH23a's Avatar
Default Re: will plastic IC piping work? (kaj)
I won't be upset at all if the set-up holds. Actually I hope the set-up holds and gives you zero problems. I'm just saying I wouldn't do it on a high hp application...
Good luck
Old Oct 8, 2003 | 11:14 AM
  #58
DOHCarp's Avatar
Default Re: will plastic IC piping work? (GudeH23a)
Ive been in home depot, and thought about doing the same thing!
its really not much more to get it done the right way.
it will probably hold for a while, but the pvc will distort after long periods of heat.
Old Oct 8, 2003 | 11:35 AM
  #59
skierGT's Avatar
Default Re: will plastic IC piping work? (DOHCarp)
i fully intend to do it the right way but right now im in college and only drive my car like every other weekend. it will be in the garage all winter too. so im not driving it hardly at all right now. and it definetly is LOTS more to do it the right way. to buy the pipes from jc whitney and do it yourself will cost you at least 150 bucks. thats not too bad, but if you have it all done in aluminum and welded beautifully then its going to cost alot more. like 400 to 800 bucks which i think is rediculous.
Old Oct 8, 2003 | 11:39 AM
  #60
skierGT's Avatar
can anyone post the exact pieces they bought from jc whitney? preferably aluminum and for the greddy kit on an EG
89efDUSTY
Jan 12, 2007 04:32 AM
97spooncivic
Jan 6, 2006 01:39 AM
misskris220
Jul 7, 2005 04:54 PM
GOLDBERG
Apr 14, 2004 07:37 AM
ILOVEGIRLS
Oct 13, 2001 04:52 PM
