Will this earls leak.
Old Oct 8, 2002 | 08:24 PM
true's Avatar
Default Will this earls leak.
My greddy oil cooler's earls fittings are always weeping and wet. I took the fittings off the lines to freshly attach them when i noticed the seating surface's have a few small dings. I don't know if it was the fitting itself leaking (mating surface) or if the line just needs to be freshly attached. Anyone with a lot of fitting experience have an opinion on if this will leak::
If there's a good chance it will, I'd rather just get new fittings... Thanks.
[Modified by true, 8:46 PM 10/10/2002]
Old Oct 8, 2002 | 09:57 PM
Lamchop0000's Avatar
Default Re: Will this earls leak. (true)
if im doubt, change it out.
are you using teflon tape also?
Old Oct 8, 2002 | 10:08 PM
bigTom's Avatar
Default Re: Will this earls leak. (lamchop0000)
teflon is not needed or reccomended to be used on these fitting other than npt fittings
Old Oct 10, 2002 | 11:47 AM
true's Avatar
I don't use teflon..you don't use it on flare fittings like above post said. Well, I recut the line and it doesn't leak so far..so I'll say no, it wont.
[Modified by true, 8:48 PM 10/10/2002]
stackz
Feb 28, 2008 01:49 PM
B16Civic93
Mar 10, 2005 03:24 PM
boostin b16
Mar 13, 2003 09:36 PM
DIY_Racing
Dec 19, 2002 03:55 PM
92HB_HB
May 2, 2002 06:48 PM
