will this clear for AC ??
Old Oct 22, 2009 | 09:29 AM
092eg6's Avatar
Default will this clear for AC ??
B-series in a EG
t3 inlinepro manifold
t3/t04e garrett 57 trim
2.5" DP
and do i have to cut a chunk out of the block to clear for the turbo??
Old Oct 22, 2009 | 09:55 AM
1DayIllBFast's Avatar
Default Re: will this clear for AC ??
you do not need to cut anything man. it will bolt right up no problem.
Old Oct 27, 2009 | 06:41 PM
TheCheeseWedge's Avatar
yes you will more than likely have to notch the webbing on the front of the block like i had to*** cold side facing passenger side***
and yes it will clear the ac/ps
Old Oct 27, 2009 | 06:51 PM
civicjunkie17's Avatar
yeah you'll be fine, that turbo isnt big at all.
Old Oct 27, 2009 | 10:55 PM
b18_P's Avatar
flush the small rib below the engine code/number for more clearance..
Old Oct 29, 2009 | 04:41 AM
project dc2's Avatar
will clear ac
if its a 4 bolt turbine outlet you will have to notch a significant amount of block out
Old Oct 29, 2009 | 06:17 PM
K i l l a B e e.'s Avatar
i notched my block with that turbo. just get a die grinder and some goggles haha
Old Oct 30, 2009 | 12:59 AM
carrnut21's Avatar
if you are 4 bolt i would seriously consider getting a 5 bolt exhaust housing. I did almost the exact same set up (cast revhard mani with the same turbo in a integra) and it took a fair amount of work to fit the turbo. it is doable for sure but it wasn't easy. If i had not already had my 3 inch dp made by spoolin performance (excellent fitment btw, cleared the ac perfectly) i would have switched to a five bolt. I was however able to keep my full sized radiator with the set up which was a plus
nick21
Sep 29, 2015 07:27 PM
hardrock2401
Nov 3, 2013 09:24 AM
MoJoe21
Jul 23, 2011 06:29 PM
JDM92Bubble
May 11, 2011 10:49 AM
RyanA
Feb 3, 2011 06:45 PM
