will a boost controller help my turbo spool quicker?
Old Jun 28, 2004 | 04:33 PM
  #26
MaxxdoutSRT4_EK9's Avatar
Default Re: (T-RO)
im pretty sure if that you will notice that a boost controller might even slow up spool time. what will make the turbo spool faster is trying a different source of pressure. im am going to try a different source this week when i get some time off of work. i will try to keep all posted.
Old Jun 28, 2004 | 06:06 PM
  #27
kun3racer's Avatar
Default Re: (T-RO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T-RO &raquo;</TD></TR><TR><TD CLASS="quote">Which DIY MBC did you go with?</TD></TR></TABLE>
i made the one where you use an NPT "T" and an adjusting screw...the one with just the two barbs didnt look to healthy lol.
Old Jul 2, 2004 | 06:54 PM
  #28
kun3racer's Avatar
Default Re: (kun3racer)
ok i went to the track and hit 13.7 w/ 1.9 60' on 14" m/t's and 14.2 / 2.3 60' on 15" falkens. im hitting 5th gear with the m/t's, is it too small for my car? i also hit 100 mph with the 15" street tires. i got major traction issues! even with the m/t's im spinning in 2nd and i still need to feather the throttle in first. would some 15" slicks make a difference?
Old Jul 7, 2004 | 02:58 PM
  #29
Circuit Star-29's Avatar
If you advance your Exhaust cam 3 degress, that'll spool your turbine sooner.
Old Jul 7, 2004 | 03:20 PM
  #30
93TurboSi's Avatar
I'm not sure if manual boost controllers will help with quicker spool up but electronic bosst controller definatly will. electronic boost controllers keep the wastegate completely 100%closed until set boost is reached so 100% of the exhaust goes through the turbine untill desired boost. with no electronic controller the wasge gate slowly opens as oost in creases until it gets to the desired boost that means as boost increases more and more of the exhaust is bypassing the turbine so you don't always have 100% exhaust flow to turbine it slowly decreases as you get to set boost. this makes the spool up with the electronic boost controller much faster
Old Jul 7, 2004 | 03:25 PM
  #31
Default Re: (nathan atwell)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nathan atwell &raquo;</TD></TR><TR><TD CLASS="quote">If you advance your Exhaust cam 3 degress, that'll spool your turbine sooner.</TD></TR></TABLE>
Just do this...screw boost controllers. They are over rated, lol. j/k
b18cEF9
Jul 31, 2005 10:56 AM
digital sol
Feb 25, 2005 11:49 AM
VisualAutoMotoring
Apr 3, 2003 06:40 PM
Dramier
Jan 4, 2003 06:24 AM
