boost drop (searched)
Old Jul 31, 2005 | 09:58 AM
b18cEF9's Avatar
Default boost drop (searched)
ok i searched old and new archives, and still nothing im looking for. Heres my problem, boost controller is set to 10psi, stock spring on the WG is 4psi. Soo every gear around 4-4500 rpm by boost drops from 10 psi, to the stock spring BAR. I know the turbo isnt running out of breathe cuz it only get full boost around 3500
setup is b18c, t3, tial 35mm WG, open dp
Old Jul 31, 2005 | 10:10 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: boost drop (b18cEF9)
almost every straight t3 is too small for dohc's. im guessing you are using a .48/.42 t3, which in that case it makes sense because up high almost every t3 runs out of breath
Old Jul 31, 2005 | 10:14 AM
b18cEF9's Avatar
Default Re: boost drop (wantboost)
yes its a 48/42 but dont you think 4500rpm is kinda low for the boost to start dropping? it gets full boost around 3500
Old Jul 31, 2005 | 10:19 AM
wantboost's Avatar
Who is Mr Robot?
its a very small t3... thats whats gonna happen, right avter the vtec crossover point its gonna die. a bigger turbo will solve your boost drop problem
Old Jul 31, 2005 | 10:21 AM
b18cEF9's Avatar
vtec is set at 6k right now
Old Jul 31, 2005 | 10:23 AM
wantboost's Avatar
Who is Mr Robot?
well thats way too highm and trust me. that turbo is too small for your motor and that pressure ratio
Old Jul 31, 2005 | 10:46 AM
Bailhatch's Avatar
shift at 4800 and you will be a happy person that will prosper and find joy in many things in life...except turbo hondas. And put your vtec back to stock.
Old Jul 31, 2005 | 10:47 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: boost drop (Bailhatch)
rofl.
not to mention the fact that your open downpipe isnt helping
Old Jul 31, 2005 | 10:54 AM
b18cEF9's Avatar
so its just the turbo huh? im not doubting you i just think 4500 rpm is kinda low for a t3 to run outta breath
Old Jul 31, 2005 | 10:56 AM
wantboost's Avatar
Who is Mr Robot?
its the turbo.
flangemastermike
Feb 7, 2007 05:30 PM
kun3racer
Jul 7, 2004 03:25 PM
Mr. Softee
Jul 8, 2002 06:54 AM
