wich way to mount turbo
im using a log mani and wanted to know if it matters wich way i mount the turbo intake towards driver side are pass side does it realy matter????
Re: wich way to mount turbo (Dual Cam Racing)
i understand that but is there a benefit to mounting it either way...will it effect the spool up of the turbo..im getting a custom downpipe made so it doesnt matter so wich would be better
Re: wich way to mount turbo (krazyturbo1)
might as well have the hotside facing the passenger side of the car to:
-have more room for a filter instead of jaming it against the rad hoses
-less time to make a smaller dp if it only has 2, maybe 3 bends instead of 3 or 4 for the opposite side.
-less charge piping
-less charge piping
Re: wich way to mount turbo (97CWITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97CWITR »</TD></TR><TR><TD CLASS="quote">might as well have the hotside facing the passenger side of the car to:
-less charge piping</TD></TR></TABLE>
X2
if you go the other way though, you could try to make it a/c compatible
X2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazyturbo1 »</TD></TR><TR><TD CLASS="quote">i understand that but is there a benefit to mounting it either way...will it effect the spool up of the turbo..im getting a custom downpipe made so it doesnt matter so wich would be better</TD></TR></TABLE>
Really does not matter, it usually depends where the turbo flange is place on the manifold. Usually the downpipe is ran out the passenger side.
