Whose catch can do you use?
Old Jul 12, 2006 | 10:27 AM
  #76
kordenbrock motorsports's Avatar
Default Re: Whose catch can do you use? (tgh99si)
well in that pic there is a lot of room near the turbo inlet, but i would recommend mounting it as high as possible...
brett
Old Jul 13, 2006 | 03:55 AM
  #77
turbotypeR@SPEC's Avatar
25 Year Member
Default Re: Whose catch can do you use? (kordenbrock motorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kordenbrock motorsports &raquo;</TD></TR><TR><TD CLASS="quote">well in that pic there is a lot of room near the turbo inlet, but i would recommend mounting it as high as possible...
brett</TD></TR></TABLE>
yeah,for one that size,the battery location is about the only option
Old Jul 13, 2006 | 07:22 AM
  #78
Turbocivic94's Avatar
Default Re: Whose catch can do you use? (turbotypeR)
How do u have it draining back to block?
Old Jul 13, 2006 | 07:25 AM
  #79
redboost10's Avatar
Default Re: Whose catch can do you use? (Turbocivic94)
the two block lines act as breather lines when under boost, then when the motor is not under a load, the two block lines act as drain backs
Old Jul 13, 2006 | 07:32 AM
  #80
Race Egr's Avatar
how do u have it baffled
Old Jul 13, 2006 | 11:22 AM
  #81
nikolai.'s Avatar
Default Re: Whose catch can do you use? (NAPIER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAPIER &raquo;</TD></TR><TR><TD CLASS="quote">how do u have it baffled</TD></TR></TABLE>
id like to know this as well.
Old Jul 13, 2006 | 12:29 PM
  #82
what is volume some of your guys' breather boxes? i compared our catch can with that of endyn's and found ours were a little over 7 cubic inches larger, both for holding capacity and overall. just curous. i know with how mine are mounted i can add about twice the volume...thanks
brett
Old Jul 14, 2006 | 08:39 AM
  #83
TurboEM1's Avatar
Default Re: (kordenbrock motorsports)
Which Moroso is the one to get to be used as a catch can?
Anyone have a part number? Im looking for 2 ports in and a breather. Thanks
Old Jul 14, 2006 | 09:28 AM
  #84
Boostfed's Avatar
New User
Default Re: (TurboEM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboEM1 &raquo;</TD></TR><TR><TD CLASS="quote">Which Moroso is the one to get to be used as a catch can?
Anyone have a part number? Im looking for 2 ports in and a breather. Thanks</TD></TR></TABLE>
The Endyn catchcan is a Moroso that they added the extra bung on the side, Moroso doesn't make one with two bungs actually
I think I will be doing my catchcan set up like Joe Simpson's, I got one Endyn catchcan now, will just need to get another now
Old Jul 14, 2006 | 10:24 AM
  #85
TurboEM1's Avatar
Default Re: (Boostfed.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed.com &raquo;</TD></TR><TR><TD CLASS="quote">
I think I will be doing my catchcan set up like Joe Simpson's, I got one Endyn catchcan now, will just need to get another now </TD></TR></TABLE>
Is the moroso modified/endyn can baffled?
Old Jul 14, 2006 | 10:44 AM
  #86
Boostfed's Avatar
New User
Is the moroso modified/endyn can baffled?</TD></TR></TABLE>
Yes it is , the Moroso comes baffled from them as well
Old Jul 14, 2006 | 11:50 AM
  #87
TurboEM1's Avatar
what is the capacity of the endyn one? i always here of them filling up and spewing out. Maybe there just to small. i am stuck b/w the endyn and z10. i only need the can though i have the fittings and hose. not sure if endyn sells just the can
Old Jul 14, 2006 | 12:20 PM
  #88
Boostfed's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboEM1 &raquo;</TD></TR><TR><TD CLASS="quote">what is the capacity of the endyn one? i always here of them filling up and spewing out. Maybe there just to small. i am stuck b/w the endyn and z10. i only need the can though i have the fittings and hose. not sure if endyn sells just the can</TD></TR></TABLE>
The Z10 and the Endyn are very very very very very close in design and size, I wouldn't doubt if they were exactly the same capacity
Old Jul 14, 2006 | 12:27 PM
  #89
SOHCD16y8's Avatar
My Endyn Setup
Old Jul 14, 2006 | 01:40 PM
  #90
tepid1's Avatar
Default Re: Whose catch can do you use? (tony1)
Tony, the fittings on the back of the block... are they steel or aluminum?
Old Jul 14, 2006 | 01:44 PM
  #91
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: Whose catch can do you use? (tepid1)
Also do you have a pic of the fittings?
Old Jul 14, 2006 | 03:35 PM
  #92
tepid1's Avatar
Nevermind tony.... they are pretty heavy and can't be aluminum due to their weight.
Old Jul 14, 2006 | 04:07 PM
  #93
mike93eh2's Avatar
my greddy i converted to open breather...
Old Jul 15, 2006 | 09:22 PM
  #94
lupin5's Avatar
Default Re: Whose catch can do you use? (nikolai.)
I also would like to know how the box is baffled. It can't just be a aluminum box with lines going to them. Any info?
Old Jul 15, 2006 | 11:28 PM
  #95
mike93eh2's Avatar
Default Re: Whose catch can do you use? (lupin5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lupin5 &raquo;</TD></TR><TR><TD CLASS="quote">I also would like to know how the box is baffled. It can't just be a aluminum box with lines going to them. Any info?</TD></TR></TABLE>
put steel wool inside..
Old Jul 16, 2006 | 07:53 PM
  #96
EG civic's Avatar
Default Re: Whose catch can do you use? (mike93eh2)
So the two fittings on the back of the block are were the 2 allen head bolts are originally, on both sides of the oil filter? Also if that is correct are they both -10 sizes?
Old Jul 16, 2006 | 08:12 PM
  #97
mike93eh2's Avatar
Default Re: Whose catch can do you use? (EG civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG civic &raquo;</TD></TR><TR><TD CLASS="quote">So the two fittings on the back of the block are were the 2 allen head bolts are originally, on both sides of the oil filter? Also if that is correct are they both -10 sizes?</TD></TR></TABLE>
on a bseries. d series dont have those plugs.
Old Jul 16, 2006 | 08:15 PM
  #98
lupin5's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh2 &raquo;</TD></TR><TR><TD CLASS="quote">
put steel wool inside..</TD></TR></TABLE>
What?! Really?
Old Jul 16, 2006 | 08:37 PM
  #99
mike93eh2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lupin5 &raquo;</TD></TR><TR><TD CLASS="quote">What?! Really?</TD></TR></TABLE>
yes, really..
Old Jul 16, 2006 | 09:04 PM
  #100
dunkd's Avatar
damn these catch can setups are getting out of control. tony1
