Whose catch can do you use?
Old Jun 29, 2006 | 12:27 PM
  #26
tony1's Avatar
Default Re: Whose catch can do you use? (Turbo-charged)
yeah, same points on the drains. They're breathers when it's under pressure and drains when it's not.
Old Jun 29, 2006 | 12:35 PM
  #27
Turbo-charged's Avatar
Default Re: Whose catch can do you use? (tony1)
pretty cool set up. did you put your battery inside or by the front tires? i was just doing the math in my head on how much that cost, not including your time LOL
Old Jun 29, 2006 | 12:52 PM
  #28
Turbocivic94's Avatar
Tony can u have 4 ports off the valve cover and both catch cans draining back to behind the block?
Right now I have endyne coming from back of the block with drain and second one off the valve cover with no drain.
Old Jun 29, 2006 | 01:02 PM
  #29
tony1's Avatar
Yeah, battery is up front on the drivers side, behind the blinker. It doesn't take a rocket scientist to add up the parts, this gets pretty expensive doing it this way! haha
Turbocivic, just remember the drain only works off gravity, you have to look at it and make the call on if it'll work or not.
Old Jun 29, 2006 | 01:20 PM
  #30
boostedcivicsir's Avatar
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">Art's was last year too, when he wasn't going fast. This year it pukes all over. lol Just wait till you go fast Joe. </TD></TR></TABLE>
makes sense joe, mine wasnt acting up at all at e-town, but when i was hitting the .70's at atco, i started seeing a little puke on it.
hey tony, are you selling that setup? may be interested, if i relocate my batt into the bumper.
Old Jun 29, 2006 | 01:21 PM
  #31
h22 civic's Avatar
i have the endyne with 2 -12 in the front valve cover and have no issues now concerning the releife for the cranckcase i was thinking bout welding 2 -12 bungs in the fron of the oil pan and runing line up to another catch cann how would this work i dont see a prob
Old Jun 29, 2006 | 01:22 PM
  #32
Turbocivic, just remember the drain only works off gravity, you have to look at it and make the call on if it'll work or not.</TD></TR></TABLE>
Reason I ask is cause on endyne kit 2 hoses are going into catch can and one is coming back into the same hose. If its draining back into the same hose as feed to the catch can. I'm assuming its going up into the catch can and that's why its puking.
Old Jun 29, 2006 | 01:24 PM
  #33
tony1's Avatar
Default Re: Whose catch can do you use? (boostedcivicsir)
I could duplicate it. I just added up the price for the parts and came up with about $475 by themselves. Figure another 2-3 hours to build it all. I'll build a "kit" for $675. Probably won't have to keep too many on the shelf! haha
Old Jun 29, 2006 | 01:26 PM
  #34
Mr. Badwrench
it looks when i take my tig class in the fall, that will be my project he hee. thanks for the reply.
Old Jun 29, 2006 | 01:29 PM
  #35
tony1's Avatar
Default Re: Whose catch can do you use? (Turbocivic94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbocivic94 &raquo;</TD></TR><TR><TD CLASS="quote">
Reason I ask is cause on endyne kit 2 hoses are going into catch can and one is coming back into the same hose. If its draining back into the same hose as feed to the catch can. I'm assuming its going up into the catch can and that's why its puking. </TD></TR></TABLE>
It doesn't drain while there is crankcase pressure, it drains when the car stops or is cruising. I also tried a ball valve on the drain line with the endyn, thinking it was picking the oil up from there and pushing it up, same deal open or closed, didn't fix it. I tried putting the fittings in the back of the valve cover and the drain in the block, same deal.
Old Jun 29, 2006 | 01:30 PM
  #36
kordenbrock motorsports's Avatar
damn, thats some coin...
both my brother and i run the head and crankcase vents that we produce. we run baffeling at the inlets and at the top/filter. we also designed it to have no return for the simple reason of not have contaminated oil. they have worked very well so far, granted we're not doing some crazy horse power (about 400whp on both setups). good topic.
brett
Old Jun 29, 2006 | 01:33 PM
  #37
tony1's Avatar
Default Re: (kordenbrock motorsports)
It could be done alot cheaper w/o stainless lines and stuff. Gotta figure, that's 6 -10 lines, so 12 -10 weld on bungs, 12 -10 hose ends, and about 13' of -10 ss hose. Not to mention 3 filters at $20/ea and the alum plate to build the box. Then the material for the baffling inside.
Old Jun 29, 2006 | 01:37 PM
  #38
oh yeah, for sure. we have the option of doing weld-on -AN fittings, or making bungs for 5/8 hose (use 3/8" or 1/2" NPT bungs for this). its budget, but functions just as well. i prefer the clean look though...
Old Jun 29, 2006 | 02:00 PM
  #39
alpha's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">Those are all dry sump tanks. Here's my catch can, got tired of the endyn one puking oil everywhere.
That's a hot setup Tony
Old Jun 29, 2006 | 04:00 PM
  #40
T4eg's Avatar
Default Re: Whose catch can do you use? (0x64)
Im using the endyn catch..i welded 2 more -10 ports on it I welded stock plugs -10 and 2 -10 off valve cover.seems to be working fine. Well over 700whp no problems yet.
Old Jun 29, 2006 | 04:01 PM
  #41
tony1's Avatar
Default Re: Whose catch can do you use? (T4eg)
How fast have you run at the track? I never had problems on the dyno, only at the track. What turbo are you running?
Old Jun 29, 2006 | 08:19 PM
  #42
HamiltonRex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">That's a BDL T/B, no problems here, on mine or Art's car.
Im going to have to see if i can play with mine.. when i hold it up to light i can see gap around only 1 half (side) and other not.. maybe its not pefectly centered.
Mines a 70mm im stuck with the stock 52mm or whatever :/
Sorry i misunderstood your catchcan setup, mine does dump a bit after a hard pull down the track.. But im not running nearly as fast as you.
Old Jun 29, 2006 | 08:32 PM
  #43
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T4eg &raquo;</TD></TR><TR><TD CLASS="quote">Im using the endyn catch..i welded 2 more -10 ports on it I welded stock plugs -10 and 2 -10 off valve cover.seems to be working fine. Well over 700whp no problems yet. </TD></TR></TABLE>
yea chris when is that beast hitting the track? I'm gonna need to come out and watch.
Old Jun 29, 2006 | 08:40 PM
  #44
miller's Avatar
Default Re: Whose catch can do you use? (SOHC_MShue)
damn tony, im in the process of building my breather tank in the same exact location and was planning on running the lines almost the same way. it looks good, almost as good as it did in my head
Old Jun 30, 2006 | 05:27 AM
  #45
bamboosted's Avatar
Default Re: Whose catch can do you use? (miller)
thats one crazy beather tank tony.
Old Jun 30, 2006 | 06:53 AM
  #46
boostfeen's Avatar
Default Re: Whose catch can do you use? (bamboosted)
Nice Tony.. it came out clean.
...and i thought i had the gangster breather system
Old Jun 30, 2006 | 08:48 AM
  #47
turboedc2's Avatar
Default Re: Whose catch can do you use? (boostfeen)
that breather is lookin crazy...
Old Jun 30, 2006 | 11:35 AM
  #48
redboost10's Avatar
Default Re: Whose catch can do you use? (TurboEM1)
anyone have anything to say about the z10 breather kit?
Old Jun 30, 2006 | 01:28 PM
  #49
turboedc2's Avatar
Default Re: Whose catch can do you use? (tgh99si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgh99si &raquo;</TD></TR><TR><TD CLASS="quote">anyone have anything to say about the z10 breather kit?</TD></TR></TABLE>interested as well...
Old Jun 30, 2006 | 03:07 PM
  #50
boostfeen's Avatar
...Z10 makes a nice breather kit but for boosted cars makin big H.P. you might wanna get two of em. one for the valve cover and one for the block, You can see that setup in the pic. of Joe Simpons car. OR you can go crazy like the one Tony made.
