Whose catch can do you use?
Old Jul 20, 2006 | 04:16 PM
  #126
TurboEM1's Avatar
Default Re: (kordenbrock motorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kordenbrock motorsports &raquo;</TD></TR><TR><TD CLASS="quote">thanks duncan, glad it worked out for you. i have the volumes (you can view them on our breathers/products page) if you still need them. thanks, lates
brett</TD></TR></TABLE>
I pmed you!
Old Jul 20, 2006 | 04:21 PM
  #127
A.E Motoring's Avatar
Default Re: (tepid1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tepid1 &raquo;</TD></TR><TR><TD CLASS="quote">
But the question is how much power are you making and how do you drive the car?</TD></TR></TABLE>
just making a lil over 300 seems like ppl with alot more have this problem, and i dont drive it hard at all
Old Jul 20, 2006 | 04:30 PM
  #128
tepid1's Avatar
Default Re: (SPNFEDEH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPNFEDEH &raquo;</TD></TR><TR><TD CLASS="quote">
just making a lil over 300 seems like ppl with alot more have this problem, and i dont drive it hard at all</TD></TR></TABLE>
That's why you don't have this problem.... You don't drive hard and you don't make a BUTTLOAD of power.
Old Jul 20, 2006 | 04:38 PM
  #129
sweet, lol, i guess i will end up putting the 2 on the valve cover when it comes for that
Old Jul 20, 2006 | 07:36 PM
  #130
xtremeness101's Avatar
hey tepid or tony1, do you have a picture or drawing of what the inside of the catch tank looks like?
Old Jul 21, 2006 | 09:40 AM
  #131
kordenbrock motorsports's Avatar
pm replied
Old Jul 26, 2006 | 06:09 AM
  #132
redboost10's Avatar
Default Re: Whose catch can do you use? (TurboEM1)
anyone got a pic of the baffling?
or do you just put like a ball of steel wool at the bottom of the can?
Old Jul 26, 2006 | 10:51 AM
  #133
tepid1's Avatar
Default Re: Whose catch can do you use? (tgh99si)
I don't have any internal pic shots....
And I personally would never use steel wool. That **** rusts fast and will contaminate your oil.
In all reality you probibly won't need to baffle a setup like this. It is so large that after your run it won't even be 1/4 full. Then when you let off it will drain back. I might make another box (this one only cost me what the fittings cost and the filters, maybe $50) and try it unbaffled to see what the results are.
Old Jul 26, 2006 | 10:54 AM
  #134
TehMan's Avatar
Default Re: (mattcivic)
mine is a light fixture from a house...in this pic is right next to my dizzy
fully functional. silicone it shut...drill a hold on one side and put a screw in it to empty it out and out a breather filter on the other side.
Modified by TehMan at 12:55 PM 7/26/2006
Old Nov 8, 2006 | 08:46 PM
  #135
redboost10's Avatar
Default Re: (TehMan)
anybody got pictures of the baffling or is it needed?
Old Nov 8, 2006 | 09:00 PM
  #136
B18Flip's Avatar
Default Re: (redboost10)
subscribing...looks like i'll have to try out my friends TIG
Old Nov 9, 2006 | 04:36 AM
  #137
mike1114's Avatar
Default Re: (B18Flip)
for baffeling, use one of those foofy things girls use in the shower. Its plastics so it won't rust or come apart in little pieces.
this is what I have in my two catch cans.
Old Nov 9, 2006 | 07:11 AM
  #138
methos713's Avatar
Default Re: (mike1114)
subscribing...cool setups people got on here
Old Nov 9, 2006 | 09:37 AM
  #139
slow poke's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 &raquo;</TD></TR><TR><TD CLASS="quote">for baffeling, use one of those foofy things girls use in the shower. Its plastics so it won't rust or come apart in little pieces.
this is what I have in my two catch cans.</TD></TR></TABLE>
But that could melt with the 180deg oil temps no?
Old Nov 9, 2006 | 09:57 AM
  #140
DarkBB4's Avatar
Default Re: (slow poke)
hey, just got a question
I plan on making 250-300hp on my h22 this year and I would like to run a simple catch can setup... Therefore, i will run it like so (seen in picture)
I also plan on using a Greddy Setup (w/ breather and steele wool) or and edyn/moroso setup
but does the mounting of the catch can matter? can it be below, how long can the lines be? Do i have this correct?
Old Nov 9, 2006 | 09:06 PM
  #141
redboost10's Avatar
Default Re: (DarkBB4)
any pictures of the inside? or any details on the baffling?
Old Nov 27, 2006 | 03:30 PM
  #142
0554's Avatar
saving post
Old Nov 27, 2006 | 03:55 PM
  #143
AJxr's Avatar
Default Re: Whose catch can do you use? (0554)
here is my $5 catch setup
Old Nov 28, 2006 | 06:14 PM
  #144
redboost10's Avatar
no baffling pictures yet? does anyone have any?
Old Nov 28, 2006 | 06:30 PM
  #145
vtec.dc2's Avatar
i use no catch can.. i have 3 baffled vents through valve cover. the other is through pcv valve into intake manifold but with check valve in between to prevent pressure back into the engine.
i'm not sure if using catch can with breather setup is sufficient enough to allow all that pressure to get through.. lets compare it to exhaust, the longer/smaller the exhaust, the harder it is for pressure to escape.. this should be similar for engine ventilation. instead of exposing the vent straight to air, you limit it to small long hose that goes inside small container with breather filter that eventuall gets clogged up and becomes a restriction. end result maybe you're not letting enough pressure out.
i do run lines from 2 of the vents on valve cover - they point down into the ground.. however, i'm thinking of just removing these as i might be able to evacuate pressure better without the lines. they point towards air filter and thats somewhat of concern..
Old Nov 29, 2006 | 07:32 AM
  #146
ExVtec's Avatar
Default Re: Whose catch can do you use? (vtec.dc2)
I am putting down 450whp on the "little black box"
I have a vent on the valve cover to a small baffled can w/no problems thus far...
Gets a little from time to time..nothing major.
Old Dec 5, 2006 | 10:38 PM
  #147
aleks77's Avatar
The greddy oil catch can has no breather, is this needed? Im gonna be running 350whp, turbo setup on my F22 accord, im collecting parts for the built and catch can is one of them, i thought it was a simple line into a a can kinda deal, but you guys are talking about breathers, return to the block? Is this all necessary....
Old Dec 5, 2006 | 10:48 PM
  #148
qfast817's Avatar
Default Re: Whose catch can do you use? (Turbo-charged)
i like my endyn, i had the lil black box but it would have to much blow by and blue smoke at wot
Old Dec 5, 2006 | 10:54 PM
  #149
Wideopentuning's Avatar
Default Re: (dunkd)
I just picked up one of these. Looks huge in the pics but its only 2"X7"
Old Dec 6, 2006 | 06:08 AM
  #150
Revi's Avatar
Default Re: (Wideopentuning)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wideopentuning &raquo;</TD></TR><TR><TD CLASS="quote">I just picked up one of these. Looks huge in the pics but its only 2"X7"
Where? How Much?
