White smoke (coolant issue??)
Old 10-12-2011, 05:56 PM
Mikeedubb's Avatar
Default White smoke (coolant issue??)
Okay so I'm driving a 1990 integra boosted with a b18a1 running 6psi.
i notice that when I'm under full boost and the car hits around 5500rpm i puff white smoke out the exhaust. White smoke i know is coolant so i was thinking possibly turbo seals are gone? ( I plan on swapping the turbo out for another setup over the winter so thats not a concern for me ) Although i did notice on long drives that the car would start to overheat when driving at 130-140 km/h, could this be an issue with the white smoke?
If anyone could help me out that would be great, thanks!
Old 10-12-2011, 06:29 PM
Hidenplanvew's Avatar
Default Re: White smoke (coolant issue??)
white smoke can also be oil, when looking out the mirror.... could be a ton of diffrent stuff... Seals on a turbo would make it smoke more then just at a certain rpm
Could be
Valve seals
oil rings
Old 10-13-2011, 10:41 PM
Mikeedubb's Avatar
Could be
Valve seals
oil rings
So your saying valve seals or oil rings??
anybody else have anything??
bump
Old 10-14-2011, 03:57 AM
cleansi's Avatar
do a compression test followed by a leak down what color are your plugs keep to the basics check the turbo for play
dailyekhatch
08-15-2011 06:45 AM
v8killaz
09-04-2010 05:29 PM
Joeski99Si
08-02-2009 11:25 AM
powwie
04-20-2006 08:58 PM
Boring
17
05-09-2005 09:09 AM
Quick Reply: White smoke (coolant issue??)
