White smoke (coolant issue??)
Old Oct 12, 2011 | 05:56 PM
Mikeedubb's Avatar
Default White smoke (coolant issue??)
Okay so I'm driving a 1990 integra boosted with a b18a1 running 6psi.
i notice that when I'm under full boost and the car hits around 5500rpm i puff white smoke out the exhaust. White smoke i know is coolant so i was thinking possibly turbo seals are gone? ( I plan on swapping the turbo out for another setup over the winter so thats not a concern for me ) Although i did notice on long drives that the car would start to overheat when driving at 130-140 km/h, could this be an issue with the white smoke?
If anyone could help me out that would be great, thanks!
Old Oct 12, 2011 | 06:29 PM
Hidenplanvew's Avatar
Default Re: White smoke (coolant issue??)
white smoke can also be oil, when looking out the mirror.... could be a ton of diffrent stuff... Seals on a turbo would make it smoke more then just at a certain rpm
Could be
Valve seals
oil rings
Old Oct 13, 2011 | 10:41 PM
Mikeedubb's Avatar
Could be
Valve seals
oil rings
So your saying valve seals or oil rings??
anybody else have anything??
bump
Old Oct 14, 2011 | 03:57 AM
cleansi's Avatar
do a compression test followed by a leak down what color are your plugs keep to the basics check the turbo for play
dailyekhatch
Aug 15, 2011 06:45 AM
v8killaz
Sep 4, 2010 05:29 PM
Joeski99Si
Aug 2, 2009 11:25 AM
powwie
Apr 20, 2006 08:58 PM
Boring
17
May 9, 2005 09:09 AM
