White smoke ? HELP ?
Old May 6, 2009 | 01:26 PM
Joeski99Si's Avatar
Default White smoke ? HELP ?
I have a EM1 that is turbo'd. It is blowing white smoke, im thinking the turbo oil seals are bad ? ? I just put a new head gasket and ARP's on it, so im almost positve thats not the prob.
The smoke smells like oil, not coolant. If i get on it and hit full boost, my friend said it doesn;t smoke but it's after i stop or park it smokes.
Does that sound like, turbo seals?
Or maybe build up on the oil seal rings on the pistons ?
Old May 6, 2009 | 04:27 PM
wkpmichael's Avatar
Default Re: White smoke ? HELP ?
turbo seal it sounds like, my buddy spec v had that same problem. I would check all the seals first. then possibly ur rings. if it were the rings it would be bluish
Old May 6, 2009 | 05:51 PM
Joeski99Si's Avatar
i keep hearing that white smoke is coolant . . .
also i heard if it was turbo seals it would smoke more under fullthrottle/ full boost ?
Old May 6, 2009 | 05:54 PM
iwanttokillgod's Avatar
oil dosent burn white only water or coolant
Old May 6, 2009 | 06:37 PM
PNK SLP's Avatar
mine was puffing white smoke (when parked or idle)when the rings were goin bad
Old May 6, 2009 | 06:44 PM
you must have the holly grail because oil dosent burn white
Old May 7, 2009 | 06:41 PM
Joeski99Si's Avatar
i dont know if this would make a diff.,i dont see how it would, but i do have a blown oil pan gasket.
Old Aug 1, 2009 | 11:27 PM
EK9-T's Avatar
Did you find the problem?
Asking because I have the same issue, white smoke when parked or stationary for longer period of time, water heats up a little more.
Just got the head gasket changed but that wasnt the problem. Still smoking white..
Old Aug 2, 2009 | 04:00 AM
kreatekustomz's Avatar
turbo seals would make great sense if we knew if it was oil or water cooled...
Othe wise you may have a different problem, under full boost you are increasing cylinder pressures thefore not giving cooland the ability to enter the combustion chamber, but under decel the coolant returning and is burnt (white smoke.)
Does you coolant look like it has oil in it?
Pull your dip stick, does it look milky??
Old Aug 2, 2009 | 04:35 AM
amrodtech's Avatar
Pull the downpipe and chargepipe off. Check and see if you have oil in either or. If there is nothing there, sounds like a headgasket problem.
Old Aug 2, 2009 | 11:04 AM
cjordan's Avatar
thats exactly what i was thinking, white smoke sounds like water... when i blew my GT35R up, it was only blew smoke that came out of it.
Old Aug 2, 2009 | 11:25 AM
mrharmonic's Avatar
oil does burn white and high temp. it's the rings dude homie's EG hatch was boosting and it whould smoke during idle turned out his rings where gone. and for some pople what to take **** to me oil burnes white when its farley fresh and hot. once agin dont beleve me show planes that fly in the sky use oil on the muffler or on the ex manifold to make the white smoke.
codyweiss97
Mar 8, 2014 11:04 AM
Mikeedubb
Oct 14, 2011 03:57 AM
v8killaz
Sep 4, 2010 05:29 PM
GReddy_Civic
Aug 11, 2008 11:42 AM
Layziebtnh055
10
Apr 16, 2004 02:22 PM
