White Smoke?
Old Jul 31, 2005 | 09:19 AM
DelSolMike's Avatar
Default White Smoke?
Alright so my car blows a lot of white smoke out of the exhaust only when I hit boost. It idles fine and drives without hitting boost perfectly normal. At first I thought the seals in the turbo were bad so I took off the intercooler piping and there was no oil in there, so the turbo isn't leaking any oil. So now I think its due to my head lifting at boost causing it to leak coolant. Wouldn't the pressure push air into the coolant jackets and not suck coolant into the combustion chamber? Well Im not exactly sure what to think of it at the moment... Anyone have any advice?
-Mike
Old Jul 31, 2005 | 12:15 PM
DelSolMike's Avatar
anyone?
Old Jul 31, 2005 | 12:40 PM
B00STED Si's Avatar
Default Re: (DelSolMike)
what about a blown headgasket? any overheating problems? foamy coolant, darker colored coolant? what you really need to do is get a leakdown test as well as a compression test and post up the results, any local shop can do it. what block do you have, and is it stock or built? post up your mods.
Old Jul 31, 2005 | 12:43 PM
hondaguyef's Avatar
Default Re: (B00STED Si)
No need for a lekadown. Just do a compression test. Make sure there isn't 2 cylinders that are right next to each other that are low. If the compression test checks out OK then get some head studs or use a higher torque on the headstuds. Is this an SOHC?
Phil
Old Jul 31, 2005 | 05:44 PM
DelSolMike's Avatar
This is a stock d16y8 (sohc) motor. There are no overheating problems, and the coolant and oil are completely fine.
Old Jul 31, 2005 | 06:16 PM
hondaguyef's Avatar
Sounds like the head is lifting to me
Old Jul 31, 2005 | 06:19 PM
s2kdre's Avatar
Default Re: (hondaguyef)
i had the same problem, only in boost it had white smoke, my number 4 and 3 cylinder had coolant goin in.
Old Jul 31, 2005 | 06:51 PM
DelSolMike's Avatar
My return line is also a little kinked, nothing bad though. Could this be part of the reason too?
Old Aug 1, 2005 | 02:57 AM
B00STED Si's Avatar
you definitely wanna get that fixed as well, that'll lead to other problems with the turbo itself
Old Aug 1, 2005 | 07:03 AM
vaporboy12's Avatar
im going to say its the head lifting
Old Aug 1, 2005 | 10:19 AM
B00STED Si's Avatar
Default Re: (vaporboy12)
agreed, it does sound like head lift. although doesnt it overheat under boost with head lift??
93califerio
Nov 20, 2011 12:26 AM
Driven
11
Oct 29, 2004 11:41 AM
buck02
May 28, 2004 09:12 AM
t616
Jun 21, 2003 02:35 PM
riceburnah
May 29, 2003 09:31 AM
