tons of white smoke
Old May 28, 2003 | 07:45 PM
riceburnah's Avatar
Default tons of white smoke
Here's another post guys, I did a fmax turbo on my 97 ls and just pours out white smoke and coolant is leaking out the exhaust (leaking between cat and exhaust), we swapped the stock headgasket for a cometic gasket and still same problem. Got the head inspected and pressure tested by a shop and everything is fine. The sleeves on the block look fine what is going on?.. other things that are doing on besides the white smoke is we are getting a lot by blow-by and the oil in the head was milky sludge, doesn't boost, I have 94 ls block I can swap if needed sorry for the long post.
Old May 28, 2003 | 08:53 PM
InTeGrA B18b1's Avatar
Default Re: tons of white smoke (ihaterice8)
is ur turbo water cooled? maybe ur leaking coolant.
Old May 28, 2003 | 11:45 PM
PrecisionH23a's Avatar
So is the turbo water cooled?
Honestly if you are leaking coolant out of your exhaust i would think that one of your sleeves may be cracked, but you said your sleeves LOOK ok. Did you make sure there are not any hairline fractures in the cylinder walls or any unusual abrasive patterns? Have you done a compression test or cylinder leakdown test on the motor yet? Since you swapped the headgasket and the problem is still there, i would put my money that internal damage has occured or the deck of your block is warped near one of the water jackets. It is quite possible that your piston has been damaged as well. Let us know what your compression numbers yield and if your turbo is water cooled and we'll go from there.
Old May 28, 2003 | 11:52 PM
TypeDC4's Avatar
Default Re: tons of white smoke (GudeH23a)
how bout if theres milky substance on the radiator cap?
Old May 29, 2003 | 12:56 AM
MiraiZ's Avatar
If he's got a bog standard FMAX, then his tubo is a turbonetics t3/t4 (probably a AR .48)...so its oil cooled.
I suspect that everthing looks good in the HG area, it could be one or more of the following:
1. hairline crack in the sleeves
2. head bolts are stretched
3. sheer coincence or bad luck (another bad HG??)
Old May 29, 2003 | 01:46 AM
sak's Avatar
sak
Default Re: tons of white smoke (MiraiZ)
Check your oil to see if its even oil in there. You may have to start up the car to see, but if its just watery instead of oily, then most likely you have a blown headgasket and coolent is making itsway into the motor and mixing with the oil. That usually gives clouds of white smokr from the rear of the car.
Old May 29, 2003 | 09:24 AM
riceburnah's Avatar
Default Re: tons of white smoke (InTeGrA B18b1)
the turbo isn't water cooled, and the compression with the fmax headgasket from cylinder 1-4 reads 60,70,150,100 terrible
Old May 29, 2003 | 09:31 AM
I Like Boost's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ihaterice8 &raquo;</TD></TR><TR><TD CLASS="quote">the turbo isn't water cooled, and the compression with the fmax headgasket from cylinder 1-4 reads 60,70,150,100 terrible</TD></TR></TABLE>
thats not good, time for a rebuild
pepperdk
Honda CR-V & Element
Jun 11, 2015 03:10 PM
tony_yang
May 13, 2010 07:18 AM
DelSolMike
Aug 1, 2005 10:19 AM
greekspeed
Sep 26, 2004 06:02 AM
bretx0r
Aug 8, 2002 08:13 PM
