Where would be the cheapest place to get a gm 3 bar map sensor???
New User
I need a gm 3 bar map sensor... where is the cheapest place to get it.. can i get it from hondata? thanks guys..
Re: Where would be the cheapest place to get a gm 3 bar map sensor??? (Damon501)
check with http://www.roadraceengineering.com I think their's is around 70 bucks..
or go to local checvy dealership...., look up the part number from hondata and asked around..
stan
stan
I actually wont be needing the one I just bougt. $50shipped if you are interested.
-gordon
-gordon
Re: Where would be the cheapest place to get a gm 3 bar map sensor??? (Flamenco-T)
Actually there's an MSD 3 bar map sensor. Looks exactly like the GM part and has the same part number. It's around $40.00. Thanks to liam821.
https://honda-tech.com/zerothread?id=97004
What are you using that much boost on? 2 bar is more than 29 lbs of boost.
Re: Where would be the cheapest place to get a gm 3 bar map sensor??? (earl)
http://www.motec.com Guess what? MoTeC actually sells 1,2 and 3 bar MAP sensor, they also sell the connectors too. Give them a look, a 3 bar plus a connector can be had for around $60
earl... once again you have gone and shown exactly how clueless you really are. A 2 bar Map sensor is what stock honda's come with and are only capable of reading 1 bar of boost (before they break)
A 3 bar map sensor can read 2 bar of positive pressure, which is the 29 lbs you speak of.
Plus, most stand alone units are comfigured to use a 3bar map sensor
New User
no. Remember, a MAP sensor has to read vaccum as well as boost. So a 3 bar map sensor will read one bar in vaccum, and two bar of boost. A two bar map sensor can read around 14lbs of boost.
I also picked up the MSD 3 bar for 40 bucks. Its the exact same thing everybody else sells for 60-85 bucks.
[Modified by VaporTrail, 3:02 PM 12/20/2001]
New User
Re: Where would be the cheapest place to get a gm 3 bar map sensor??? (mikvtec)
no. The Honda ECM is not calibrated for the 3 bar. Not to mention a stock Honda ECM cannot read and compensate for boost. You need a http://www.hondata.com system to use it properly.
Re: Where would be the cheapest place to get a gm 3 bar map sensor??? (TurboR616)
I may be clueless but I have run a 10.25 @ 134 with my CRX and I built the engine myself. What have you done?
Ok guys before this gets out of control, Im locking this tread. The answer for the topic has been answered so we are moving on.
art
art
