Fuel pump setup
Old Sep 22, 2009 | 06:08 PM
PRO1's Avatar
Default Fuel pump setup
Heres my fuel fuel setup Weldon pump aeromotive filter 10an Line 8an return
Advice welcome
thanks
Before
after
Old Sep 22, 2009 | 06:20 PM
Desir Performance's Avatar
Default Re: Fuel pump setup
Why did you mount the pump upside down? I placed mine upright on the Left rear shock area, as high as possible to avoid damage.
Old Sep 22, 2009 | 06:31 PM
PRO1's Avatar
I didnt know you could mount it that way? and i couldnt figure out were To mount it besides a slip on mount with a brace.. so i mounted this way?
any input pros and cons?
Old Sep 22, 2009 | 06:33 PM
PRO1's Avatar
Did u run a weldon also?
Old Sep 23, 2009 | 11:59 AM
Yeah I run the weldon 2025. These pump are sucker stlye pumps, unlike the aeromotive pums they work upside down or up right. they dont rely on gravity for the fuel ( thats why i bought mine). Theres really no cons the way you have it except it might get caught on somthing if its to low.
Old Sep 23, 2009 | 12:19 PM
PRO1's Avatar
YEah its about an inch an half lower then the fuel cell So it shouldnt be an issue i hope
Old Sep 23, 2009 | 02:04 PM
boostedcivicsir's Avatar
Mr. Badwrench
whoa holy non ground clearance.......
same pump, different filters now but same mounting position. no issues. fits under stock bumper:
with the new pre and post filters:
Old Sep 23, 2009 | 02:22 PM
redboost10's Avatar
i run the weldon 2035, just make a bracket that cradles it. you got all sorts of moutning points on that fuel pump.
Old Sep 23, 2009 | 02:53 PM
PRO1's Avatar
YEah that looks good i mit try somthing like that also
Old Sep 23, 2009 | 02:59 PM
Adrnlnjunky's Avatar
Looks good. How does the Weldon compare to an SX?
Old Sep 23, 2009 | 06:23 PM
Mr. Badwrench
i havent used the sx, but as for customer service, i had an issue with the pump, and when i called weldon to fix, jim craig gave me his personal cell #, told me who to go to to get parts, gave me wholesale on the parts, and when they came in, walked me through fixing the pump.
their pumps are bad ***, their customer service is top notch.
Old Sep 23, 2009 | 06:51 PM
redboost10's Avatar
mikey, did you by any chance break the little plastic screws on the sides of the top of the pump that hold the contacts in?
Old Sep 23, 2009 | 07:01 PM
bads2k's Avatar
wha are these weldon pumps with say 1600cc or even the new ID2000's good for power wise? Are these pumps better than say two bosch 044's?
Old Sep 24, 2009 | 05:07 PM
Mr. Badwrench
no i actually didnt vent the tank properly, and the pump was caving the tank in. and broke the drive coupler. or the lovejoy. it is a coupler between the pump motor and pump drive. it is a fuse. and is designed to do that. call weldon, ask for jim craig. see what he says.
Old Sep 24, 2009 | 05:10 PM
Mr. Badwrench
from weldons site: this is the db2015a. the 2025 and 2035 flow more and make moew power.
Maximum HP:
1000 hp @ 14V EFI (500 hp on Methanol)
1050 hp @14V carb (525 hp on Methanol) GPH/PSI Range:
85-115 GPH / 0-160 PSI
i dont think a 100 base is out of the question.
i personally dont like running 2 pumps. but people use it and have made it work.
Old Sep 24, 2009 | 05:33 PM
racergti's Avatar
We got hooked up with SX Performance fuel systems and have had awesome results since the changover. Not that Walbro was bad, but now we have some headroom for future development where we were near the end of the capacity of the old pump.
http://www.sx-performance.com/
The fuel cell is right behind the passenger headlight and the fuel rail is centered just behind the radiator so everything is close and easy to take care of.
Old Sep 24, 2009 | 05:42 PM
redboost10's Avatar
yeah i already called him. they dont make their pumps like that anymore. i just epoxied it together and it is holding up fine
Old Sep 24, 2009 | 06:04 PM
PRO1's Avatar
Where you running a fuel cell or sumped tank?
Old Sep 24, 2009 | 06:28 PM
Mr. Badwrench
sumped tank. i have dealt with the issue. he hee. live and learn.
vr6chris
Jan 4, 2005 09:17 AM
vr6chris
Jan 4, 2005 07:45 AM
edgar306
Dec 29, 2004 08:43 PM
slwazgsr
Oct 12, 2002 07:37 AM
