When should you get a re-tune
Old Jul 1, 2009 | 11:20 AM
1DayIllBFast's Avatar
Default When should you get a re-tune
With my wastegate spring its only letting me boost to 5psi and thats what i got tuned at. If i get a new spring or MBC and boost at 8psi do i need to go back for a re-tune?
Old Jul 1, 2009 | 11:34 AM
turbo-crx's Avatar
Default Re: When should you get a re-tune
yes.
Old Jul 1, 2009 | 11:36 AM
EARLdaSQUIRREL's Avatar
official honda whore
yes
Old Jul 1, 2009 | 11:38 AM
omgwtfbbq's Avatar
yes
Old Jul 1, 2009 | 11:39 AM
thanks i guess that answers that question what about this one. Since i am not boosting that much what BOV spring should i have because my tial came with the 11psi spring and im sure thats to stiff because i cant even here it blow off. All i here is the compressor surge. Should i get a 9psi or 7psi spring?
Old Jul 1, 2009 | 11:55 AM
tial bov spring depends on what your vacuum is at idle, not how much boost you are running (although i would run the 9psi spring if i was you)
Old Jul 1, 2009 | 11:58 AM
well my vaccum at idle is about 21in/hg which is what the 11psi is rated at but its way to stiff for my setup. Thanks i think im going to order the 9psi now because im pretty sure the 7psi will be to low?
Old Jul 1, 2009 | 12:42 PM
SD_Lurker's Avatar
HT White Ops
Originally Posted by 1DayIllBFast
thanks i guess that answers that question what about this one. Since i am not boosting that much what BOV spring should i have because my tial came with the 11psi spring and im sure thats to stiff because i cant even here it blow off. All i here is the wastegate flutter. Should i get a 9psi or 7psi spring?
haha I'm pretty sure that's not your wastegate fluttering. Sounds to be like comp surge since your BOV isn't opening.
Old Jul 1, 2009 | 01:03 PM
yeah i know its compressor surge ha its just what it sounds like ha yeah i just ordered the 9psi
Old Jul 6, 2009 | 02:08 PM
ok so i bought the 9psi spring and put it in and i still have compressor surge, any ideas why this is?
Old Jul 6, 2009 | 03:14 PM
blinx9900's Avatar
honestly at 5psi you don't even need a bov, nearly all bov's will flutter around 0-5psi, its no big deal, now if your surging at higher boost levels on boost you have a serious problem.
Old Jul 7, 2009 | 12:27 PM
ok well thats good to know. thanks a lot.
justYncredible
May 15, 2012 01:01 PM
JLHDOHC
Aug 2, 2006 05:43 PM
boostedcivicsir
Jan 27, 2006 06:35 PM
h22 civic
Jan 30, 2005 12:40 PM
Machine1
Nov 5, 2004 07:13 PM
