Whats a good and quiet fuel pump I could use with hondata
New User
I was looking for a good and quiet fuel pump that will work well with lnormal psi since im using a hondata. I was thinking of the bosch are those loud
[Modified by Trajic, 8:09 AM 10/9/2001]
Re: Whats a good and quiet fuel pump I could use with hondata (VaporTrail)
stock........standalones usually dont' require added fuel flow until you start boosting higher than 12~14 or so.......At least my Zdyne doesn't but I do have an integra pump assembly that'll i'll install later.......i'm still kinda weary wether the stock fuel pumps flow any different b/t civics and 'tegs?
New User
Re: Whats a good and quiet fuel pump I could use with hondata (Speed PHreak)
so if i want to boost 8 pounds max w/ hondata 2b/440cc injectors i can still use the stock fuel pump safely?
Re: Whats a good and quiet fuel pump I could use with hondata (smoothludey2)
Sounds fine to me, i've got a Zdyne SECU with mistu 450cc's about to go on. I'll prolly change out to my 'teg fuel pump........but I think Autozone.com lists the same part number for all the fuel pumps for most hondas (civics and 'tegs).....
~steven
~steven
Re: Whats a good and quiet fuel pump I could use with hondata (TurboT)
bosch loud?
hahahha
try the paxton or aeromotive pumps... sheesh
wha???
hahahha
wha???
