fuel pump set up for hondata
Old Oct 30, 2001 | 05:47 PM
Mikex25's Avatar
New User
Default fuel pump set up for hondata
would it be o.k to use the MSD in line pump that the rev hard kit gave me with a Walbro intank pump to be used with a hondata or would I need a better in-line pump like a Bosch?
[Modified by Mikex25, 2:48 AM 10/31/2001]
Old Oct 30, 2001 | 06:05 PM
InfamousRS's Avatar
Default Re: fuel pump set up for hondata (Mikex25)
Im also curious on the fuel pump setup to use with hondata?
Old Oct 30, 2001 | 06:48 PM
Suprdave's Avatar
The Bosch is good cus it can sustain high Fuel Pressures....unlike some others...
If your going Standalone (Hondata), then you dont need more ~50-60PSI of Rail Pressure ever...cus your using bigger injectors...So You don't NEED a Bosch, but they are still nice pumps.
Suprdave
Old Oct 30, 2001 | 09:10 PM
adam's Avatar
Default Re: fuel pump set up for hondata (BLK94RS)
I have a BBK (Walbro) 255lph intank. Works like a charm, it's even surprisingly quiet
Old Oct 30, 2001 | 09:14 PM
InfamousRS's Avatar
Default Re: fuel pump set up for hondata (adam)
So you can still use a bosch or Walbro when you have a standalone cant you?
Old Oct 30, 2001 | 09:19 PM
adam's Avatar
If you have a Hondata you ONLY need the intank Walbro pump, just be sure to get some bigger injectors.
Old Oct 30, 2001 | 09:21 PM
InfamousRS's Avatar
SO all I need is Walbro fuel pump (what do they cost?) Hondata, and 440's or 550's? Do you still need a fmu or does the stand alone controle the amout of fuel for every psi of boost?
Old Oct 30, 2001 | 09:26 PM
adam's Avatar
Depends on boost. I run 440s (6-8psi). No you don't need the FMU, only the pump, which is about 120 bucks.
Old Oct 30, 2001 | 09:32 PM
InfamousRS's Avatar
What is the max amount of boost you can run with 440's and 550's?
Old Oct 30, 2001 | 09:40 PM
adam's Avatar
Go read the FAQs on http://www.hondata.com. It will answer this question as well as the ones you have about standalones.
Old Oct 30, 2001 | 09:50 PM
98hx99b18c's Avatar
Hmm I think you could run up to 15psi with 440cc w/o a problem if not more. The walbro 255lph intank fuel pump with the hondata is great too.
g2turbo
Nov 30, 2002 05:03 PM
LEON
Apr 16, 2002 06:51 AM
BLKCRX
Feb 7, 2002 03:38 AM
Trajic
Oct 9, 2001 10:37 AM
