What is wrong? Went to the dyno
Old Jul 7, 2005 | 01:27 PM
  #176
meltman1234's Avatar
Default Re: (DLB1994)
Well Matt and I tested the wastegate placement and it didn't help. It ran just about the same. I really don't know what I want to do with it.
Old Jul 7, 2005 | 01:57 PM
  #177
menkio's Avatar
Default Re: (meltman1234)
mhhmm
Old Jul 7, 2005 | 02:01 PM
  #178
Antilag's Avatar
If your dump tube is dumping next to the compressor inlet or near it. I can guarantee your losing 70-90 whp. As for the mapping I didn't read the hole thread but at first, damn 35 is alot for idle and 15 is too low. I like to idle at 24, it will go up as far as 26 just under light throttle. and start dropping for every 10-15 + map pressure. 18 would be lowest for a street tune. plugs for your set up should be around 24. This is for a map with a t3/t4 setup as well. H series likes the 4554 ngk's as well. Im not saying this is the preferred way, but you tried everything else. Just trying to help.
Old Jul 7, 2005 | 07:49 PM
  #179
SOHC_MShue's Avatar
Default Re: (9sech22civic)
His dumptube is running back into the downpipe. Its not an open dump. Also what are you talking about with idle numbers? Timing? The stock base timing for the h22 is 15* which i have it set at. If you are seeing a 35 thats probably because i posted the hi cam map. I'm not sure if thats what you meant or not.
Modified by SOHC_MShue at 12:21 AM 7/8/2005
Old Jul 7, 2005 | 08:34 PM
  #180
Antilag's Avatar
Default Re: (SOHC_MShue)
ahhh gotcha
Old Jul 7, 2005 | 08:40 PM
  #181
lodo1's Avatar
hmm, very interesting problem. bump for a logical solution
Old Jul 7, 2005 | 08:59 PM
  #182
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9sech22civic &raquo;</TD></TR><TR><TD CLASS="quote">ahhh gotcha </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tdocrx &raquo;</TD></TR><TR><TD CLASS="quote">hmm, very interesting problem. bump for a logical solution</TD></TR></TABLE>
yea seriously. We've tried everything. The plugs are gapped right, the afr's are fine, and i've tried all kinds of timing combinations(well the best i could do without a dyno), which made the car feel no different. It feels great up until about 3500 rpms and then its just a slug. I still suspect that it may not be getting good spark or something because the datalogs always showed random lean spikes off and on that look like little misfires.
Old Jul 7, 2005 | 10:21 PM
  #183
lodo1's Avatar
you guys have swapped out the dizzy right? possible wires gone bad? i have heard of wires being the culprit also
Old Jul 8, 2005 | 12:17 AM
  #184
abnaasefmb's Avatar
Default Re: (tdocrx)
sounds like my n/a b16 with a bad ignitor. if someone around has a good dizzy try swapping the whole thing out and see if it makes a dif.
Old Jul 8, 2005 | 07:16 AM
  #185
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tdocrx &raquo;</TD></TR><TR><TD CLASS="quote">you guys have swapped out the dizzy right? possible wires gone bad? i have heard of wires being the culprit also</TD></TR></TABLE>
nah we haven't yet. We did swap out the wires, plugs, rotar, and coil though.
Old Jul 8, 2005 | 07:39 AM
  #186
SOHC_MShue's Avatar
Alright well i may have figured out one cause for the loss in power we are having. I just realized that with the p28 ecu we are running his IAB's don't even work so i guess they are stuck closed. Does anybody know which vacuum line to unplug so they stay open all the time? Have any pics?
Old Jul 8, 2005 | 09:44 AM
  #187
boonacka's Avatar
ahhh.. preludes have dual runners like the gsr's right?
Old Jul 8, 2005 | 10:02 AM
  #188
SOHC_MShue's Avatar
Default Re: (boonacka)
yup. I never even thought about it
Old Jul 8, 2005 | 11:25 AM
  #189
turboH22Aakkord's Avatar
Default Re: (nonvtecD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvtecD &raquo;</TD></TR><TR><TD CLASS="quote">does the car even feel faster? The boost gauge is showing 10 psi? Doesn't even look like the turbo added much if any power.</TD></TR></TABLE>
i was gona say the same... those look like stock hp numbers for an h22...
Old Jul 8, 2005 | 11:33 AM
  #190
SOHC_MShue's Avatar
Default Re: (turboH22Aakkord)
basically...
Old Jul 8, 2005 | 12:07 PM
  #191
GaRn's Avatar
I don't have any pics, but its on the side opposite of the TB, and its a big 2" round solenoid/diaghram thing mounted on the side of the IM..
Old Jul 8, 2005 | 01:12 PM
  #192
Default Re: (GaRn)
Edit: I'm dumb
Modified by meltman1234 at 6:25 PM 7/8/2005
Old Jul 8, 2005 | 01:20 PM
  #193
SOHC_MShue's Avatar
No that is your map sensor david. He sais its on the other side of the intake manifold.
Old Jul 8, 2005 | 01:24 PM
  #194
Ok found it, do I just pull the vacuum line off the top of it?
Old Jul 8, 2005 | 01:38 PM
  #195
SOHC_MShue's Avatar
I guess so. Make sure you plug up the vacuum line so you don't have a leak.
Old Jul 8, 2005 | 01:55 PM
  #196
EVIL TYPE R's Avatar
Default Re: What is wrong? Went to the dyno (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">bump. Anybody else have an idea about what this could be? </TD></TR></TABLE>
Try cam gears and dial out the overlap when VTEC hits.
Old Jul 8, 2005 | 01:57 PM
  #197
SOHC_MShue's Avatar
Default Re: What is wrong? Went to the dyno (EVIL TYPE R)
it feels like **** way before vtec.
Old Jul 8, 2005 | 02:10 PM
  #198
check the timing belt...seen this happen before...once fixed the car should run good till vtec hits then it won't pull again...then add the cam gears and retune. let me know how it goes.
Old Jul 8, 2005 | 02:19 PM
  #199
SOHC_MShue's Avatar
Yea i guess we should check the timing belt. What is it something with the auto tensioner on h22's that causes it to slip?
Old Jul 8, 2005 | 02:22 PM
  #200
possibly or the belts just old and stretches
