What is wrong? Went to the dyno
Old Jun 1, 2005 | 08:56 AM
  #126
s1ngle's Avatar
Default Re: (meltman1234)
let us know what the problem ends up being.. i have a very similar wastegate dump setup, and would be interested in knowing if that is the problem.
Old Jun 1, 2005 | 08:58 AM
  #127
SOHC_MShue's Avatar
Default Re: (boonacka)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boonacka &raquo;</TD></TR><TR><TD CLASS="quote">what year is the motor? it very well might need some good ole TLC just like above mentioned. I also heard seafoam works well and run some BG44k in your tank (fuel system cleaner)( the good ish)(expensive too...) it will only be beneficial for your motor anyway. good luck.</TD></TR></TABLE>
its an 01 i believe.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meltman1234 &raquo;</TD></TR><TR><TD CLASS="quote">Alright we need to check the timing belt next time I come over Matt. I have work Thursday, Friday, and Saturday and I have ******* SAT's Saturday morning but we could probably do it Saturday afternoon or Sunday.</TD></TR></TABLE>
i'm going to be pretty busy this week man. I have work thursday-saturday from 9-3 and I am doing a head swap on my car.
Old Jun 1, 2005 | 09:37 AM
  #128
meltman1234's Avatar
Default Re: (SOHC_MShue)
Ehhh, Sunday? What are you swapping on? And where are you working?
Old Jun 1, 2005 | 10:11 AM
  #129
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meltman1234 &raquo;</TD></TR><TR><TD CLASS="quote">Ehhh, Sunday? What are you swapping on? And where are you working?</TD></TR></TABLE>
I don't know man. I'm trying to get my car back together as soon as possible. I'm working on it at my house.
Old Jun 1, 2005 | 10:32 AM
  #130
boonacka's Avatar
you have a spare y8 or z6 head?
Old Jun 1, 2005 | 10:56 AM
  #131
SOHC_MShue's Avatar
I will have a spare y8 head after this, but i'm going to keep it just incase this z6head/y8block combo doesn't work out to well. A guy told me today that he had a y7block/z6head combo and had oil delivery problems and burned up two heads
Old Jun 1, 2005 | 11:00 AM
  #132
Well good luck with that. I'll give you a call sometime at the end of this week/weekend to see when we can do it.
Old Jun 1, 2005 | 11:06 AM
  #133
boonacka's Avatar
the Y7 is nonvtec right? if so, he didnt take out the oil control jet. I'm going by the old school A6/z6 - y8 minime swap info. they always mentioned taking out the oil control jet to help facilitate proper oil pressure for the new vtec component.
Old Jun 6, 2005 | 06:10 AM
  #134
s1ngle's Avatar
you guys ever figure out what the problem was?
Old Jun 6, 2005 | 06:54 AM
  #135
Default Re: (s1ngle)
No not yet, I'm still waiting on the wastegate to come in(it was on backorder and they didn't tell me ) But I replaced the coil with a new one, it pulls a little better but I haven't really gotten on it to hard. Once the wastegate comes in and I put that in, hopefully I can get on it and feel the difference. If not I guess we are going to make sure the timing belt didn't jump any teeth. That's all the ideas so far.
I WILL UPDATE WHEN WE FIGURE OUT THE PROBLEM.
Sorry to anyone who needs the info because their car is doing the same thing, but the damn wastegate was on backorder.
Old Jun 6, 2005 | 07:32 AM
  #136
boonacka's Avatar
so after replacing the coil, does it still misfire up top?
Old Jun 6, 2005 | 08:00 AM
  #137
I don't know, Matt has the wideband and the computer and all that.
Old Jun 6, 2005 | 08:16 AM
  #138
s1ngle's Avatar
yeah i am interested, my dyno had some of the same problems, just kinda seeing what your resolution is.
Old Jun 6, 2005 | 08:17 AM
  #139
graphic's Avatar
man i had a similar problem w/ my h22 i had a f-max kit w/ the stupid dumptube was like 1 in and then back into the dp. on 6 psi i only made 180whp..and my graph was all shitty like yours w/ power falling off after vtec...so i dropped my plug gap down to .018 and chnaged to a new rotor and upgraded the ignition to msd 6 box w/ a ssblaster coil and 8mm wires then i had a custom dumptube made that is open loop and i am still using that shitty fmax log manifold and a even small dp then you mine is 2.25in and jeff evans managed to pull 380whp outta my setup w/ around 19degrees total timing..
here is the dyno:
Old Jun 6, 2005 | 08:31 AM
  #140
s1ngle's Avatar
Default Re: (graphic)
wait, so graphic was was your actual problem? ignition, dumptube, or both?
Old Jun 6, 2005 | 09:13 AM
  #141
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by graphic &raquo;</TD></TR><TR><TD CLASS="quote">man i had a similar problem w/ my h22 i had a f-max kit w/ the stupid dumptube was like 1 in and then back into the dp. on 6 psi i only made 180whp..and my graph was all shitty like yours w/ power falling off after vtec...so i dropped my plug gap down to .018 and chnaged to a new rotor and upgraded the ignition to msd 6 box w/ a ssblaster coil and 8mm wires then i had a custom dumptube made that is open loop and i am still using that shitty fmax log manifold and a even small dp then you mine is 2.25in and jeff evans managed to pull 380whp outta my setup w/ around 19degrees total timing..</TD></TR></TABLE>
Yea my dumptube setup is questionable,
But Anthony(who fabricated my kit) said he has seen it done like that many times. I dunno.
But almost all of my ignition is brand new, new coil, wires, plugs and rotor. I'm on about 10 pounds at .028 gap I think. Does that sound about right?
And I was on 10 psi and made only 190.
But everything has smoothed out, it's not just that I don't make any power.
Old Jun 6, 2005 | 10:50 AM
  #142
s1ngle's Avatar
yeah dude, i'm starting to think that could be a problem, my dumptube is very similar and i'm having a similar problem. I have stock ignition, but my dyno graph isnt really choppy. although i guess i'm not sure on teh smoothing factor for mine.
Old Jun 6, 2005 | 10:59 AM
  #143
Yea I'm thinking of calling Antony and asking him to make me a new dumptube setup to see if it yields any power gains. And if it does create more power than I won't pay him, but if there is no effect I will pay him. Something like that.
Old Jun 6, 2005 | 11:03 AM
  #144
graphic's Avatar
what is your exhaust setup??? are you running a cat??
my h22 was acting all goofy..so goofy that when we tried to turn up the boost we lost power
the engine was choking out after 4250, i'm not sure what the exact cause was, but i do know this to be a fact that when we put the wastegate open loop we gained like 100whp and like 80lbft.
... after i made these changes it seemed to respond really well..
also note that we disabled the secondaries and vtec was set to 5500
Old Jun 6, 2005 | 11:20 AM
  #145
VTEC is set at 52-5500 on mine also.
The exhaust is 3" kteller piping, kteller high flow cat, and magnaflow muffler.
Open loop? Never heard it reffered to like that before? You mean like open dumptube? Because I have seen gains of up to 40whp from switching from dumping back into the downpipe, to an open dumptube setup.
Old Jun 6, 2005 | 01:31 PM
  #146
s1ngle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meltman1234 &raquo;</TD></TR><TR><TD CLASS="quote"> I have seen gains of up to 40whp from switching from dumping back into the downpipe, to an open dumptube setup.</TD></TR></TABLE>
dang guys, i'm definitely gonna have to look into doing this for myself. meltman, I would recommend it also.
Old Jun 6, 2005 | 05:35 PM
  #147
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by graphic &raquo;</TD></TR><TR><TD CLASS="quote">what is your exhaust setup??? are you running a cat??
also note that we disabled the secondaries and vtec was set to 5500</TD></TR></TABLE>
how close to the turbo was your dump tube dumping? I suspect that this is his problem because he sais that when he has switched to open loop it ran drastically different. His is actually dumping a few inches off of the turbo outlet. Its super close.
Old Jun 6, 2005 | 06:17 PM
  #148
Hey Matt, I'm getting the wastegate in on Wednesday and putting it on. Can we tune/check timing belt Friday?
Old Jun 6, 2005 | 08:26 PM
  #149
SOHC_MShue's Avatar
i don't think my laptop will be back by then. One of my mom's coworkers is using it while they are out of town on business. We can maybe check your timing belt though. I'm pretty damn sure thats not the problem though. I think if your timing belt was off a tooth your car would feel like a complete turd even out of boost.
Old Jun 7, 2005 | 05:08 AM
  #150
boonacka's Avatar
test the coil theory first before you change anyhting else. that way you know for sure what worked and what didnt. i guess your waiting for your WG first huh. slap it on and tell us if it feels any better.
