What is wrong? Went to the dyno
Old Oct 20, 2005 | 11:52 AM
  #251
SOHC_MShue's Avatar
Default Re: (pwl)
Yea i think your right. The small *** turbo and log manifold are probably causing so much exhaust gas reversion that its killing the power and causing that knock that was accuring with the more agressive timing. If he had some adjustable cam gears to dial out the overlap we could probably gain a good deal of power with this small turbo, but i think for now we are going to try the large turbo and see how it does
Old Oct 20, 2005 | 02:24 PM
  #252
JDMs1eeper's Avatar
Default Re: (SOHC_MShue)
their is no reason why that shouldnt help. A t3 on a gsr on 10psi makes less than 200 but with a larger turbo makes 270-300+.
THat turbo made 243 and 200ftlbs on my LS on only 8.5psi so Im motr than sure that is the problem. T3's make **** for power unless you have a small 1.5-1.6 sohc.
Go see how many sub 200 dyno's youll see in the search feature using a small t3. I think the next dyno will show that what im sayin is right. He's runnin stock cams, no stock came (Deffinaly Vtec) is going to have so much over lap that you are gonna run into power loss issues. His engine would sound like a drag car and wouldnt idle if it were that bad.
Old Oct 20, 2005 | 09:29 PM
  #253
SOHC_MShue's Avatar
Default Re: (JDM S1eeper)
I'm talking about overlap in boost. The small turbo and log manifold are causing the exhaust gases to revert back into the combustion chamber and contaminate the new charge which causes loss in power. With adjustable cam gears you could probably somewhat correct this.
Old Oct 21, 2005 | 03:42 AM
  #254
JDMs1eeper's Avatar
so why deal with it if his turbo will be maxed out by 250 anyways. He has a much better turbo now. Lets see him make 300+ next go around
I know what your sayin tho.
Old Oct 21, 2005 | 05:02 AM
  #255
meltman1234's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM S1eeper &raquo;</TD></TR><TR><TD CLASS="quote">so why deal with it if his turbo will be maxed out by 250 anyways. He has a much better turbo now. Lets see him make 300+ next go around
I know what your sayin tho.</TD></TR></TABLE>
I hope to make that much, I want to get an equal length manifold while I'm at it, but I just don't have the money right now. I do but if I bought one I'd be left with like $200. But running open dump, no a/c and a 3" dp should help too
Old Oct 21, 2005 | 06:42 AM
  #256
SOHC_MShue's Avatar
No **** i'm the one that told him to buy your turbo
Old Oct 21, 2005 | 06:46 AM
  #257
93preludes's Avatar
i wonder if this is also my issue, i've got a t3/t4 52trim... was able to barely squeeze 210 out of it.
Old Oct 21, 2005 | 06:55 AM
  #258
SOHC_MShue's Avatar
Default Re: (93preludes)
your turbo sounds like it should be large enough.
Old Oct 21, 2005 | 06:58 AM
  #259
93preludes's Avatar
so you all are running a straight t3? i probably have other issues... sucks :-/
Old Oct 21, 2005 | 07:17 AM
  #260
SOHC_MShue's Avatar
i believe so. The turbo is tiny.
Old Oct 21, 2005 | 09:42 AM
  #261
booja's Avatar
too small or not.... it should still make more power.
greddy kits and the 18g at 10psi make more power
Old Oct 21, 2005 | 10:18 AM
  #262
theblkrascal's Avatar
i smoke rocks
Old Oct 21, 2005 | 12:08 PM
  #263
Default Re: (booja)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by booja &raquo;</TD></TR><TR><TD CLASS="quote">too small or not.... it should still make more power.
greddy kits and the 18g at 10psi make more power</TD></TR></TABLE>
This turbo is also from a kit I got for christmas from ebay. (SSautochrome parts, etc.) And so far I've had to replace everything in the kit and the turbo still remains from the kit. So it could be a shitty turbo. Yea it works, but shittily.
Old Oct 21, 2005 | 01:21 PM
  #264
graphic's Avatar
Default Re: (meltman1234)
dude try disabling the secondaries...
also mess around w/ cam timing like stated above.
just for reference, my h22's intake is -3degrees and the exhaust cam is 0degrees
Old Oct 21, 2005 | 01:26 PM
  #265
SOHC_MShue's Avatar
Default Re: (graphic)
IAB control is disabled. We are using a p28 ecu. Also he doesn't have any adjustable cam gears.
Psychoteen101
May 18, 2017 12:48 PM
b00stedbyFastrax
May 19, 2008 09:48 AM
VSBB6
26
Jan 4, 2007 07:54 PM
85
Aug 18, 2006 08:27 AM
Blaze45
Feb 19, 2003 01:21 PM
