What would cause this?
Old May 4, 2003 | 02:41 PM
Bricklayer's Avatar
Default What would cause this?
I know a guy with a 95 or 96 prelude Vtec that he has been working with because its doesn't run right. First heres a basically what he has done, it's sleeved bored out to 2.6L built bottom end built head, with a T3/T04ef turbo I don't know the specs on the turbo, but his problem is that he generates 1psi at idle and at 2500-3000rpms he is already boosting between 10-15psi, he thinks the turbo is too small for 2.6L so now he is going bigger with a T60-1 turbo or something around that size. I am nowhere near knowing how to figure this out. Does anyone know what it might be?
Old May 4, 2003 | 03:12 PM
Shift!'s Avatar
Default Re: What would cause this? (Bricklayer)
well maybe his wastegate is bad or something, shouldnt there be vacuum at idle?
Old May 4, 2003 | 03:39 PM
lazerus's Avatar
Default Re: What would cause this? (Shift!)
must not be a t3/t04e turbo if it's makin 1 psi at idle.
Old May 4, 2003 | 04:13 PM
Bricklayer's Avatar
Default Re: What would cause this? (lazerus)
It is a T3/T04ef, but somebody mentioned once that he may have made his own exhaust manifold in which case he could have mislocated the wastegate causing it to not function properly. I am stumped I don't even know where to begin on this.
teddy_dc2
Jan 12, 2006 03:18 PM
teddy_dc2
Jan 12, 2006 02:00 PM
tranceologist
Sep 17, 2005 12:58 AM
MNsnowdaboy
Jun 28, 2004 04:41 AM
97integraLST
Nov 29, 2001 11:31 AM
