What WG spring with MBC????
Old May 6, 2008 | 06:24 AM
turbo boost's Avatar
Default What WG spring with MBC????
hey i have a lsvtec stock sleeves..ramhorn,3''dp 60-1 stage 5 .82ar and im going for 400whp...my question is i have 2 WG springs a 7psi and 14.5 psi and i have a hallman pro MBC...which spring should i put in the wg..the 7 or 14.5?? im guessing it will take 16+psi to get around 400whp on pump gas(91 octane)??
thanks
Old May 6, 2008 | 11:01 AM
Default Re: What WG spring with MBC???? (turbo boost)
bump
Old May 6, 2008 | 11:07 AM
chimmike's Avatar
If you can, get something like a 9psi spring. the disparity between 7 and 14.7psi is a lil too much, IMO.
Old May 6, 2008 | 11:10 AM
Default Re: What WG spring with MBC???? (chimmike)
these is the only two springs i have...
Old May 6, 2008 | 12:32 PM
chimmike's Avatar
Like I said, get a 9psi spring if you can. You generally don't want to run significantly more boost than your wg spring with a controller. I don't know as though I'd run as high as 14.7psi as your base boost though.
Get what I mean?
Old May 6, 2008 | 12:40 PM
then it would be better to run the 14.5 psi spring and use the controller to add the diff i need to reach my goal?
Old May 6, 2008 | 01:41 PM
anyone eles??
Old May 6, 2008 | 02:20 PM
chimmike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo boost &raquo;</TD></TR><TR><TD CLASS="quote">then it would be better to run the 14.5 psi spring and use the controller to add the diff i need to reach my goal?</TD></TR></TABLE>
If you want that much boost daily, I guess.
Old May 6, 2008 | 04:31 PM
yes i plan on tuning it to 400whp and leaving it...
Old May 6, 2008 | 04:35 PM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
i would think anything at all lower than the boost level you desire would work?
ntoxicatedtigah
Apr 26, 2009 01:24 PM
radeon
Jul 9, 2007 03:22 AM
dunkd
Feb 3, 2005 11:45 AM
9deuce9rr
Mar 28, 2004 12:32 PM
redboost10
Nov 16, 2003 02:07 PM
