What wastegate and BOV for 25-30psi
BCICAN
Just like the title says. What BOV will support 25-30 psi, will the HKS SS do it?
Also for the wastegate, the only boost controller I will use is a gear based controller.
Re: What wastegate and BOV for 25-30psi (B20TDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20TDC2 »</TD></TR><TR><TD CLASS="quote">i would say tial i use both and have nothing but good to say about them</TD></TR></TABLE>
Id run tial, and i do run tials, for both on my car.
liam
liam
Re: What wastegate and BOV for 25-30psi (liam821)
Im using tial 44 wastegate and greddy type-r stiff spring BOV
Both the tial wastegate and BOV are awesome choices. and will work for what u want to do.
Chris
Chris
Re: What wastegate and BOV for 25-30psi (BlueHatch00)
yea i'm pretty sure the hks ss will support that seeing how many high hp supra's use that bov and if i remember correctly an ex member hear motormatrix used that bov and he was boostin upwards of those psi numbers. As for the size of the tial wastegate i have mixed thoughts..
Tial had some info on there site before stating that when running higher boost levels smaller tial can be utilized since less exhuast gas will be passing through the wastegate. but for some reason on here people tend to think that the more you boost the bigger your wastegate has to be...
Re: (rextec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rextec »</TD></TR><TR><TD CLASS="quote">how much will my 35mm tial support</TD></TR></TABLE>
I made 380whp with my 35mm - but i couldnt get the boost to go higher then 24psi. Im gonna try my roommates 38mm with a 1bar spring and see if i can hold more then 24psi.
liam
liam
Turbosmart Ultragate all the way here. Comes race gas ready and includes all the springs. Plus, the body is investment cast instead of sand cast, so it will never rust or corrode.
